New Reply
A problem with solution
Share Thread Thread Tools
Mar3-12, 06:05 PM   #1
Have an equation;
d2y(t)/dt2 + 5d2y(t)/dt2 + 4y(t) = 2e-2t
Solved the complementary(homogenous) part and the function and got the roots of -1 and -4
so the yh(t) is A1.e-4t + A2.e-t
Forcing function is 2.e-2t so yparticular(t) is A.e-2t
Am I right here ? Or am I supposed to use Ate-2t
Well, if I use the first one, the resultant function doesn't give me the 2.e-2t when I put it into the differential equation, so there is something wrong obviously.
However F(t) or one of its derivatives are not identical to terms in the homogenous solution, so I think I have to use the first option, which is A.e-2t
After proceeding I ended up with yp(t) = 1/3.e-2t
Initial values are y(0) = 0 and y(1)(0) = 0
so, K1 = -1/9 and K2 = -2/9
Still couldn't find where I am wrong
Appreciate if you help me.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar3-12, 07:39 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by zoom1 View Post
Have an equation;
For the differential equation you posted, the above roots are not correct. Did you intend for there to be two second order terms in the equation when you posted it?
Mar4-12, 04:36 AM   #3
Quote by gulfcoastfella View Post
Ohh, pardon me, the second term is not the second derivative, it had to be first derivative.
Mar4-12, 04:42 AM   #4
Recognitions:
Homework Helper Homework Help
You should double check your calculation for Ae-2t
Mar4-12, 05:31 AM   #5
Quote by Office_Shredder View Post
Got it! Thank you ;)
Mar4-12, 06:37 PM   #6
Recognitions:
I got a particular solution of y[itex]_{p}[/itex] = -e[itex]^{-2t}[/itex]. See if you get the same.
Mar4-12, 08:20 PM   #7
I get [itex]A_1=\frac{1}{3}[/itex] and [itex]A_2=\frac{3}{2}[/itex]. The particular solution given above is correct.
Double-check your calculations.
New Reply
Thread Tools
Similar Threads for: A problem with solution
Thread Forum Replies
solution of an initial value problem and general solution of differential equation Calculus & Beyond Homework 5
Maths Problem: Connect the towns solution (Motorway Problem) General Discussion 3
Finding the solution to an IVP Problem. Basic Differential Equations problem. Calculus & Beyond Homework 4
General solution of initial value problem --dont understand problem is asking me?? Calculus & Beyond Homework 1
