| New Reply |
Moment of intertia for corrugated pipes |
Share Thread |
| Mar4-12, 10:58 PM | #1 |
Hi,
I am struggling to find forumula for Moment of Inertia for corrugated hollow pipes somewhat as shown in the picture. Main Pipe is made of Solid wall construction over which smaller diameter hollow plastic pipe is spairally welded. Any approximate calculations will also help. Thanks, Aktan
| Mar5-12, 10:35 AM | #2 |
That's a bellows that's designed to be flexible, why do you want a MOI for it?
| Mar6-12, 06:13 AM | #3 |
Thanks |
| Mar18-12, 05:47 AM | #4 |
Normally you'd just calculate the a unit moment of inertia, in^4/in and depending on how perfect you want the value, you either approximate it as the inner tube if it is a simple pipe with the corrugations applied to the outside as stiffeners, and use parallel axis theory to combine. Most commerically produced pipe have tables published with all this data.
http://www.dot.ca.gov/hq/esc/techpub.../section12.pdf |
| New Reply |
Similar discussions for: Moment of intertia for corrugated pipes
| Thread | Forum | Replies | ||
| Moment of intertia | Calculus & Beyond Homework | 2 | ||
| Moment of intertia | Calculus & Beyond Homework | 1 | ||
| Moment of Intertia | Introductory Physics Homework | 3 | ||
| moment of intertia for rod with weight on one end | Introductory Physics Homework | 5 | ||
| Motorcycle Intertia Dyno - Moment of Intertia for various objects? | Introductory Physics Homework | 1 | ||
