Understanding GHZ Entanglement
  • Context: Graduate
  • Thread starter Thread starter StevieTNZ
    Entanglement
The discussion centers around the concept of GHZ (Greenberger-Horne-Zeilinger) entanglement, particularly in the context of three-photon entanglement and the implications of measuring photons at different polarization angles. Participants explore the relationships between photon states, measurement outcomes, and the interpretation of quantum states.
  • One participant questions the implications of measuring one photon in H polarization and its effect on the other two photons, suggesting a potential misunderstanding of the measurement process and superposition.
  • Another participant acknowledges a misinterpretation related to the measurement direction and its clarity in the source material.
  • Several participants discuss the GHZ state representation and the implications of measuring photons at specific angles, particularly focusing on whether photons 2 and 3 take on opposite polarizations when photons 1 and 4 are measured.
  • There is a suggestion to express |H> and |V> in terms of |45> and |135>, with some participants debating the correct method for this transformation.
  • Participants express uncertainty about the conditions under which certain combinations of states can occur, particularly regarding odd numbers of |45> states.
Participants do not reach a consensus on the implications of the measurements or the correct method for expanding the quantum states. Multiple competing views and interpretations remain present throughout the discussion.
There are limitations in clarity regarding the assumptions made about photon states and the measurement process, as well as the mathematical steps involved in expanding the quantum states.
StevieTNZ
Hi there,
I was looking through Zeilinger's "Dance of the Photons" where I re-read the section of three-photon entanglement. If one photon is measured in H polarisation, the other two take on H - likewise with V polarisation.
What I find interesting is if we measure one photon and its H polarisation, another (delayed) at 45 degrees, and the last at vertical - when the first photon takes on H polarisation, don't the other two? So when the last photon meets the V polarised filter, shouldn't it fail? But according to GHZ results, it should be vertical.
So the other two photons are NOT in H polarisation when the first one meets the polariser? Or the first photon is NOT in H polarisation - evolves as a superposition in accord with Scrodinger equation (no collapse occurs).
Unless I've mis-understood something?
I see where I have mis-interpretated it. The author doesn't make it clear under the diagram he is measuring in another polaristion direction before the photon becomes V or H polarised. v' h' and all that stuff just makes it more confusing.
If we have the GHZ state: |V>|H>|H>|V> + |H>|V>|V>|H>, if photons 1 and 4 take on polarisation 135, do photons 2 and 3 take on the opposite - 45 polarisation?
To find the answer to this, all you need to do is write |H> and |V| in terms of |45> and |135>.
So replace |H> with |45> and |V> with |135> ?
Because expanding |H> to include |45> and |135>, I'm not sure if they have to match (i.e. with the other |H>)
No, write |H> and |V> as linear combinations of |45> and |135>. Each of them will have an expression that's something like (1/√2)(|45>+|135>). I don't remember the exact expressions off the top of my head.
So |45>|135>|135>|45> + |135>|45>|45>|135> ?
No, that's not how it's done.
How is it done? Do photons 1 and 4 share the same polarisation, likewise with 2 and 3? (e.g. in |H>|V>|V>|H>).
Do we expand it as |45>|45>|45>|45>+|45>|135>|135>|45>+|135>|45>|135>|135> etc.?
Yes, that's how it's done. We write |H> and |V> in terms of |45> and |135>, and so we expand the whole quantum state as a sum of products like |45>|45>|45>|45>.
"Combinations with odd numbers of |45> do not occur".
But you can write those from |V>|H>|H>|V>+|H>|V>|V>|H>?
I told you, just write |H> and |V> in terms of |45> and |135>. Then just expand out the products using the distributive property, like |45>(|45>+|135>)=|45>|45>+|45>|135>
  • · Replies 51 ·
  • · Replies 38 ·
  • · Replies 41 ·
  • · Replies 80 ·
9K
  • · Replies 19 ·
  • · Replies 58 ·
  • · Replies 61 ·
