| New Reply |
Prove this function on metric space X is onto! |
Share Thread | Thread Tools |
| Mar7-12, 10:24 AM | #1 |
(1) (X,d) is a COMPACT metric space.
(2) f:X->X is a function such that d(f(x),f(y))=d(x,y) for all x and y in (X,d) Prove f is onto. Things I know: (2) => f is one-one. (2) => f is uniformly continuous. I tried to proceed by assuming the existence of y in X such that y has no pre-image. That, and the fact that f is 1-1, implies that the sequence y(n)={f applied to y n times} is a sequence of distinct points. X is compact and hence y(n) has a convergent subsequence. Also, X, f(X), f(f(X)),....and so on are all closed and nested (because f is continuous and X is compact?). Their intersection is non-empty because y(n) has a limit point which should be in the intersection? So, f restricted to the intersection is a continuous bijection. Note: the case where X is finite can be solved by using the pigeonhole principle to show that Image(f) =/= X implies f is not one-one. And, loosely, compactness can be thought of as a generalization of finiteness....so.......?? I really don't think i'm getting anywhere... WHERE ARE YOU CONTRADICTION!?! Please help. This is really bugging me. |
| Mar7-12, 11:37 AM | #2 |
Let d(x,f(X))=ε. We know that ε>0 (why?).
We can cover X with sets of radius smaller than ε. Let's say we cover it with N sets and that we can't cover it with N-1 sets. Can you prove that f(X) can be covered with N-1 sets?? Can you deduce that X can be covered with N-1 sets of radius smaller than ε?? |
| Mar7-12, 11:58 AM | #3 |
f(X) is closed. So, if x is not in f(X), it is not a limit point and distance from f(X) is more than 0. Say the distance is 'e'.
{B(z,e/2) / z in X} is an open cover for X. Let {B(z_i,e/2) / i=1,2.....N} be a minimal subcover. Say, x is in B(z_k,e/2). This open ball is contained in B(x,e) and hence it doesn't intersect f(X). So we can chuck this from the finite subcover and still be left with an open cover for f(X) with N-1 sets. I'm a bit confused about what to do next... |
| Mar7-12, 12:01 PM | #4 |
Take the pre-image of the open sets. Do these pre-images have size <epsilon?
| Mar7-12, 12:13 PM | #5 |
The pre-images are open and have diameter less than e because of condition (2).
And if p is in X, it must be contained in the pre-image of whatever e/2 ball its image is in. So the pre-images are an open cover of X with only N-1 sets. But these pre-images are not necessarily sets in the infinite cover I started with...... I used the assumption that my particular infinite subcover did not admit a finite subcover of less than N-1 sets. |
| Mar7-12, 12:19 PM | #6 |
| Mar7-12, 12:22 PM | #7 |
Yes, that would fix it....
Thank you! |
| New Reply |
| Thread Tools | |
Similar Threads for: Prove this function on metric space X is onto!
| Thread | Forum | Replies | ||
| Let f be a continuous real function on a metric space X. Let ... | Calculus & Beyond Homework | 4 | ||
| Prove a set is closed and bounded but not compact in metric space | Calculus & Beyond Homework | 2 | ||
| Construct a continuous function in metric space | Calculus & Beyond Homework | 4 | ||
| Prove metric space | Calculus & Beyond Homework | 2 | ||
| Prove this Metric Space | Differential Geometry | 1 | ||
