| New Reply |
Reverse Carnot - Refrigeration Cycle problem |
Share Thread | Thread Tools |
| Mar7-12, 08:45 PM | #1 |
Hi guys, I have difficulties understanding the what I need to do in this problem. I have a ideal refrigeration cycle. first part is standard calculations, work of compressor and such. Results are Temperature range between -23 and 60 degrees C. Second part is the one that i do not understand. it says: "Assume an expanded control volume where cooling space is at 0 degrees C and the heat rejection space is at 20 degrees C and with the dead state of 20 deg C and 100 kPa. Do a second law analysis of the system." What am i supposed to do here? Is this a cycle in a cycle that runs between o and 20 deg C? or is it a simple ideal reverse Carnot that fits inside the dome? or something else...
thanks |
| Mar7-12, 10:13 PM | #2 |
Recognitions:
It is not clear from this what is meant by "expanded control volume". It might help to give us the entire first problem. AM |
| Mar8-12, 06:42 AM | #3 |
AM Thanks for your quick response.
I will post the text of the problem below, and doing the first part of it is not a big deal. I am confused with the same thing you are, 2nd part of it - "expanded control volume". What does that mean? text of the problem: A refrigerator uses refrigerant-134a as the working fluid and operates on the ideal vapor-compression refrigeration cycle except for the compression process. The refrigerant enters the evaporator with a quality of 30 % and leaves the compressor at 60 C Compressor work is 0.45 kW. a) The mass flow rate of the refrigerant, the condenser pressure, and the COP of the refrigerator are to be determined. b) Assume an expanded control volume where cooling space is at 0 degrees C and the heat rejection space is at 20 degrees C and with the dead state of 20 deg C and 100 kPa. Do a second law analysis of the system |
| Mar11-12, 06:00 PM | #4 |
bump
| Mar12-12, 02:26 PM | #5 |
Recognitions:
Refrigerant enters the control volume at less than 0C and leaves this space at or close to 0 C. The refrigerant then enters the compressor. It leaves the compressor as a liquid at 60C and is then placed in thermal contact with the hot reservoir (the heat rejection space) which is at 20C. It leaves the heat rejection space at close to 20C. It is then put through the throttle valve causing it to expand/evaporate and cool. It then again enters the control volume and the cycle repeats. Does that help? AM |
| Mar12-12, 02:37 PM | #6 |
Andrew, thanks again for your help.
To me it does make sense what you have described. But how do i proceed with the 2nd law analysis? I do have dead state at 20 deg C and 100 kPa. How am i supposed to use this information? Restricted Dead State is used for Exergy calculation on system as a whole. Do I use the 0 and 20 deg C as dead states to calculate waste energy for evaporator and condenser as separate equipment? Using 0 deg for evaporator and 20 for condenser? In that case how should i analyze valve? |
| Mar12-12, 02:54 PM | #7 |
Recognitions:
AM |
| New Reply |
| Thread Tools | |
Similar Threads for: Reverse Carnot - Refrigeration Cycle problem
| Thread | Forum | Replies | ||
| Refrigeration Cycle | Introductory Physics Homework | 8 | ||
| Ideal Gas Carnot engine refrigeration | Introductory Physics Homework | 3 | ||
| Reversible(Carnot) Cycle Temperature Equilibrium Problem | Advanced Physics Homework | 4 | ||
| Question about the refrigeration cycle | General Physics | 4 | ||
| Reverse of carnot cycle | Classical Physics | 5 | ||
