| New Reply |
What happens in the restframe with lightsource? |
Share Thread | Thread Tools |
| Mar7-12, 05:23 AM | #52 |
Are you looking at the current English version of the wikipedia.org article on Time Dilation? I cannot see much of what you say you are seeing.
| Mar7-12, 05:53 AM | #53 |
| Mar7-12, 05:37 PM | #54 |
My simple proof. An observer in motion observers a photon to travel straight out in a line a distance cΔt'. An observer at rest measures the photon to travel out at an angle along with the objects direction of motion cΔt. The observer at rest also measures the object to travel a distance vΔt. This gives three sides of a right triangle and then the relation to how they measure Δt can be found. (ct')^2+(vΔt)^2=(cΔt)^2 a^2+b^2=c^2 c^2Δt'^2=c^2Δt^2-v^2Δt^2 distribute the square and subtract both sides by (v^2Δt^2) Δt'^2=(c^2Δt^2-v^2Δt^2)/c^2 divide both sides by c^2 Δt'^2=c^2Δt^2(1-v^2/c^2)/c^2 factor out a (c^2Δt^2) from (c^2Δt^2-v^2t^2) Δt'=Δt√(1-v^2/c^2) the c^2 cancels and take the square root of both sides It then follows that the Michealson-Morley experiment also measured the photon to travel out in a straight line even though the experiment was under constant acceleration due to the Earths movement. So then, the distance traveled by the object in constant acceleration can be replaced with Δt(vi+vo)/2. s=Δtvo+(aΔt^2)/2 s=Δtvo+(Δt^2(vi-vo)/t)/2 substitute from a=(vi-vo)/Δt s=Δtvo+(Δtvi-Δtvo)/2 cancel a Δt from the substitution and distribute the Δt s=2Δtvo/2+Δtvi/2-Δtvo/2 multiply Δtvo by 2/2 and seperate the factor s=Δt(vi+vo)/2 add like terms and factor out Δt (cΔt')^2+(Δt(vi+vo)/2)^2 = (cΔt)^2 Pythagorean Theorem c^2Δt'^2 = c^2Δt^2 - Δt^2(vi+vo)^2/4 distribute the square c^2Δt'^2 = c^2Δt^2(1-(vi+vo)^2/4c^2) factor out c^2Δt^2 from the right side Δt'^2 = Δt^2(1-(vi+vo)^2/4c^2) divide both sides by c^2 Δt'=Δt√(1-(vi+vo)^2/4c^2) take the square root Then you have an equation for the relation between time dialation and constant acceleration. I noticed that by adding the initial velocity and the final velocity that you can get double that amount of velocity than just the time dialation equation alone. Then when it is squared it comes to be counteracted by the 4 in the denominator. This is because 2 in the acceleration equation is squared to give 4. So you have 4c^2 instead of just c^2, that seems to work out. But my proof seems to imply that as a velocity becomes c then the amount of time that is dialated comes to zero instead of being undefined. |
| Mar8-12, 10:03 AM | #55 |
There is nothing wrong with the article but, as I said before, you have to understand what their variables stand for. If you think there is something wrong with the article, please don't mix up your complaint with your own version, just point out where you think it is in error and we can deal with that separately from your own version. First off, I know that you cannot observe a photon or measure its progress so you're going to have to show me how you plan on doing this before I can get motivated to try to understand the rest of your proof. Secondly, it seems like you have it backwards. Why do you say an observer in motion observes the photon traveling straight out but the observer at rest measures it at an angle? I'm trying to associate your scenarios with the diagrams in the wiki article and maybe that's a mistake. Maybe you are presenting something totally different. So I cannot make sense of your equations that follow. You need to provide your own pictures and relate your equations to them so that I can follow your proof. But remember, you cannot observe the motion of a photon so deal with that before continuing on. |
| Mar8-12, 04:09 PM | #56 |
It is Newton's equation for distance... I don't really know what more there is to say about it. d=vt. I am saying that you can replace v with the speed of light in order to find the distance the photon has traveled. Both observers would then use their own time to measure this distance. So then if the photon traveled for one secound then you would multiply that times the velocity and get about 300,000 km.
So then say Michealson stays with his experiment and then measures the speed of light traveling in it. All he would have to do is find the amount of time it took to travel across the experiment and the distance across the experiment to find the speed of light. So then c=d/t. Now say Morley pass's the experiment in his car and watches it through the window. He notices that the experiment still measured the photons to travel in a straight line in the experiment to reach the end at the same time. Traveling at a relative velocity doesn't effect the outcome of the experiment. He then draws the path of the photon on his car window as it passes by with a magic marker. The line he just drew was moveing at an angle along with the motion of the car. Morley then concludes that the photon traveled a larger distance in his frame of reference so then he solves for the speed of light. So then he takes this longer distance and the time he measured it to take for it to travel and he gets the same answer for the speed of light. So then light has been seen to travel two different distances and comes out to be the same speed. They then compare their watches to find that the amount of time it took to reach across the experiment was different when Morley was in the car. So then they could both set up a right triangle to give their relation to the time that is experienced in the car and just sitting next to the experiment. But, this could get too confusing because I switched the observer at rest and the observer in motion, so I will stop here. But the point is mainly that the observer in motion wouldn't observe the results of this experiement to come out differently. In Einsteins world the experiment would have been seen to shoot the photon at an arc, but that wasn't the case. An observe in motion can't change the outcome of a Michealson-Morley experiment just by accelerating and looking at it from afar or by accelerating the experiment further. That is one of the main differences of my theory. |
| Mar8-12, 04:27 PM | #57 |
| Mar8-12, 04:43 PM | #58 |
| Mar8-12, 07:47 PM | #59 |
You guys are really no fun at all, I wasn't aware that physics forums was not to include anything about the scientific process. You need to go back to high school and relearn the first property of physics, I fear this is just going to be way over your head...
| Mar8-12, 07:54 PM | #60 |
| Mar8-12, 09:54 PM | #61 |
Okay, a pitcher throws a ball it takes 2s to reach the catcher. He threw the ball at 10m/s. How far is the catcher from the pitcher? (2s)(10m/s) = 20 meters The value for secounds cancels and then you are left with only the unit meters... |
| Mar8-12, 10:01 PM | #62 |
| Mar8-12, 10:19 PM | #63 |
But when Michelson's experiment emits a flash of light, how does he see it to know when that happened? When the light pulse hits the other end of the experiment, how does he see it to know when it arrived? He can only watch it with light, correct? So I need for you to tell me how he can factor out the light travel time from those two events so that he can get a meaningful measurement. |
| Mar9-12, 01:04 AM | #64 |
He could move an entanglement experiment next to the Michealson-Morley experiment and then put an atomic clock on the end of it. Then have a switch linked to both experiments so that it is the same distance to each. When the switch turns on it measures the entangled particle and turns on the Michealson-Morley experiment. The atomic clock would then have a detector to see when the photon reaches it, it then turns on when the other entangled particle changes it's spin from being measured on the other side. The atomic clock stops and read time when the photon reaches the detector. That would be a bunch of trouble just to find that a particle follows d=vt. I thought it should be a given. Or he could just shoot a photon at a piece of material that alters when hit and then time how long it takes it to do it, other way could be a lot of trouble. I thought they already have done this and should be a given. Like when they found the wave properties of light. Why does it take over a hundred years for everyone to know that it was measured to always travel at the same speed? Why would particles travel with anything other than their velocity? Is there some kind of particle velocity I have not heard about? Maybe you could try using my equation to find the velocity in respect to time and get the same answer as the velocity you originally put into it and find that the other equation doesn't. If v=v', then gamma will always cancel so then it doesn't matter if you used the equation for dialated time or not they will reduce to the same equations. Sounds like that should be something you should see wrong with accepted equation.
| Mar9-12, 01:22 AM | #65 |
I found one link to particle velocity but I don't think it applies here, because I said it was in a vacuum with no resistance. Laws of motion don't even take into account resistance anyways....
http://en.wikipedia.org/wiki/Particle_velocity |
| Mar9-12, 01:26 AM | #66 |
http://en.wikipedia.org/wiki/Particle_acceleration
Here is another link, do these equations look familiar? |
| Mar9-12, 03:08 AM | #67 |
Gamma was proposed by scientists prior to Einstein as a way to explain how the measurement of light would always yield the same answer even though they thought light was only traveling at c in a fixed ether medium. So if the photon travels at a fixed speed with respect to the ether, that could cause the time for the photon to travel from the gun to the reflector to be shorter than the return trip or vice versa. |
| Mar9-12, 03:30 AM | #68 |
| New Reply |
| Thread Tools | |
Similar Threads for: What happens in the restframe with lightsource?
| Thread | Forum | Replies | ||
| As you move away from a lightsource.... | Introductory Physics Homework | 4 | ||
