Finding the Radius and Interval of Convergence of a Series
The discussion revolves around finding the radius and interval of convergence for the series defined as (n(x-4)^n) / (n^3 + 1) from n=1 to infinity. Participants are exploring convergence tests and the implications of their calculations on the convergence behavior of the series.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting the ratio test and discussing the limits involved in their calculations. There are questions about the correctness of their expressions and the interpretation of the limits as n approaches infinity.
The discussion is ongoing, with participants providing feedback on each other's approaches and calculations. Some guidance has been offered regarding the evaluation of limits and the application of the ratio test, but there is no consensus on the final outcome or the correct interpretation of the results.
There are indications of confusion regarding the application of the ratio test and the evaluation of limits at infinity, as well as the need to clarify the conditions under which the series converges or diverges.
  • #61
Looks good!
  • #62
ok great! so can i like write exactly what i have there for my homework?
  • #63
What you wrote was fine, but a little more verbose and roundabout than necessary. This is how I would say it.
arl146 said:
ok well
we need [itex]\frac{n}{n^3+1}[/itex] < [itex]\frac{1}{n^2}[/itex] for the test
and that can be proven by:
[itex]\frac{n}{n^3+1}[/itex] = [itex]\frac{n(1)}{n(n^2+1/n)}[/itex] = [itex]\frac{1}{n^2+1/n}[/itex]
Now, since n2 + 1/n > n2, for all n >= 1,
then 1/(n2 + 1/n) < 1/n2, for all n >= 1.
Therefore, n/(n3 + 1) < 1/n2, for all n >= 1.
This shows that each term of the series in question is smaller than the corresponding term of the convergent p-series Ʃ1/n2.
arl146 said:
so now we are looking at [itex]\frac{1}{n^2+1/n}[/itex] < [itex]\frac{1}{n^2}[/itex] for my series to be convergent since [itex]\frac{1}{n^2}[/itex] converges.
looking at the denominators: n2+[itex]\frac{1}{n}[/itex] is > n2
thus making [itex]\frac{n}{n^3+1}[/itex] = [itex]\frac{1}{n^2+1/n}[/itex] < [itex]\frac{1}{n^2}[/itex] this true
is that good enough?
  • #64
ok awesome. that is a lot shorter. and the endpoint check for x=3 is just the same concept so i think i got that. thanks a lot guys!
  • #65
hmm i have another question (hopefully short) ... why do we check the endpoints for convergence? what's the purpose of doing that? do i always do that if the question asks for an interval of convergence and/or radius of convergence?
does checking the endpoints change anything if its convergent or divergent?
  • #66
The radius of convergence is the same whether the series converges at neither, either, or both endpoints. What does change is the interval of convergence, which could look like (a, b), (a, b], [a, b), or [a, b].
If the question asks for the interval of convergence, you need to check both endpoints.
  • #67
ok yea i just figured that out right as i posted that.. so if they ask just to find the radius of convergence, since that answer comes before finding the interval of convergence, i won't have to check the endpoints since i don't even have to find the interval. correct?
  • · Replies 24 ·
