New Reply
Burst test calculation help
Share Thread Thread Tools
Mar14-12, 07:44 AM   #1
Not really a homework question, but it could be. Working on making a burst test chamber and need some calculations that says it is safe enough. Sorry for my poor english, it's not my first language.
1. The problem statement, all variables and given/known data
The setup: First a brass fitting would be fitted inside a chamber, and then pressurize until burst. I would like to know how much stress the bursting object gives to the surface of the chamber.
My current numbers:
Fitting weight: 202grams.
Pressure: 150bar (=15000kPa)
Diameter inside the pressurehose: 15.23mm
Length to nearest surface: 5cm
Length to bottom of chamber: 15cm
Do I/you need more numbers?
How thick stainless steel plate will I need so the 202gram object pressurized at 150bar won't give dents?
Thank you!
2. Relevant equations
P=F/A
3. The attempt at a solution
Not sure....
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
New Reply
Thread Tools
Similar Threads for: Burst test calculation help
Thread Forum Replies
burst operation Electrical Engineering 0
burst of 40Khz Engineering Systems & Design 2
how do we tell how far away a gamma burst was? General Astronomy 10
Gamma ray burst General Astronomy 17
