| New Reply |
HELP! determine work needed to push a crate up a ramp at constant speed |
Share Thread | Thread Tools |
| Mar14-12, 05:02 PM | #1 |
1. The problem statement, all variables and given/known data
A ramp leading up to a loading platform is 3 m long and 1 m high at its highest point. If the friction is ignored, what work is needed to slide a 600-kg crate up the ramp at a constant speed? a) 2.00 *10^2 J b) 5.89 *10^2 J c) 1.80 *10^3 J d) 5.88 *10^3 J I believe the answer is d) but I would just like someone to explain the answer to me and correct me if d) isn't the answer. THANK YOU SO MUCH, in advance :) 2. Relevant equations a=0 Fnet=0..... because its at a constant speed W=Ffriction=mg 3. The attempt at a solution W=600kg*9.8m/s^2= 5.88*10^3J |
| Mar14-12, 06:09 PM | #2 |
hi dani123!
![]() (try using the X2 button just above the Reply box )![]() work done equals the change in energy, so you need an equation relating W and potential energy
| Mar14-12, 06:19 PM | #3 |
Ok so this may be a stupid question but is there a difference between force and energy? If so how am I suppose to calculate the energy in order to get the work required to push the crate up the ramp! Thanks so much for your time
| Mar14-12, 06:28 PM | #4 |
HELP! determine work needed to push a crate up a ramp at constant speed![]() big difference energy = work = force times distance (for example, mg is force, mgh is energy) you need to go back to your book, and read those chapters again, before trying any more of these questions! |
| Mar14-12, 06:32 PM | #5 |
ops! lol its been a long day haha thank you
| New Reply |
| Thread Tools | |
Similar Threads for: HELP! determine work needed to push a crate up a ramp at constant speed
| Thread | Forum | Replies | ||
| Crate on a frictionless ramp, constant speed. | Introductory Physics Homework | 11 | ||
| Power needed to push an object vertical at constant velocity | Introductory Physics Homework | 6 | ||
| Calculating 'Push' Force to Maintain Constant Speed | Introductory Physics Homework | 4 | ||
| How hard must you push a box to move it with a constant speed? | Introductory Physics Homework | 4 | ||
| Work Required to Push/Pull a Crate | Introductory Physics Homework | 8 | ||
