New Reply
Magnetic Field involving solenoids
Share Thread Thread Tools
Apr3-12, 01:00 AM   #1
1. The problem statement, all variables and given/known data
Two long ideal solenoids (with radii 20 mm and 30 mm respectively) carry the same number of turnes of wire per unit length. The smaller solenoid is mounted inside the larger, along a common axis. It is observed that the magnetic field within the inner solenoid is zero. The current in the inner solenoid must be:
A. two-thirds the current in the outer solenoid
B. one-third the current in the outer solenoid
C. twice the current in the outer solenoid
D. half the current in the outer solenoid
E. the same as the current in the outer solenoid
This one is hard. If you could please provide an explanation with the answer so I could better understand this.
THanks in advance.
2. Relevant equations
n/a
3. The attempt at a solution
Right now I'm ruling out answer A.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr3-12, 04:16 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi McAfee!
Quote by McAfee View Post
Call the currents I and J.
Hint: what is the formula for the magnetic field inside a current-carrying solenoid?
And can we just add the fields?
Apr3-12, 08:52 AM   #3
Quote by tiny-tim View Post
Hi McAfee!
The formula is B = μ_o*i*n
n is the number of turns
and yes
Apr3-12, 08:57 AM   #4
Recognitions:
yup!
so what's the total equation, and is it A B C D or E ?
Apr3-12, 09:28 AM   #5
20mm = .02
30mm = .03
assuming that I can ignore n because it will be the same for both.
Would it be E because the radii doesn't play a role in the equation?
Apr4-12, 05:29 PM   #6
Recognitions:
sorry, i missed your post
yes the radii don't matter,
so if (case E) the currents are equal (and opposite), then the magnetic field inside the inner solenoid will be zero
New Reply
Thread Tools
Similar Threads for: Magnetic Field involving solenoids
Thread Forum Replies
Magnetic Field and solenoids Introductory Physics Homework 2
Ratio magnetic induction between 2 solenoids Introductory Physics Homework 2
maxwell equation involving the magnetic field Advanced Physics Homework 0
Help finding magnetic flux, EMF, magnetic fields of solenoids Advanced Physics Homework 0
magnetic field between two solenoids.. General Physics 2
