New Reply
Pairing gap equation weak coupling
Share Thread
Apr4-12, 03:18 PM   #1
In the limit of weak coupling, [itex]G\overline{ρ}<<1[/itex], the BCS pairing gap equation gives that [itex]Δ \propto exp(-1/G\overline{ρ})[/itex]. [itex]\overline{ρ}[/itex] is the level density.This cannot be developed as a power series in the interaction strength G. Does this imply that there is a phase transition between a superfluid and a normal fluid state? If so, how exactly?
PhysOrg.com physics news on PhysOrg.com
>> Surprising turns in magnetic thin films could lead to better data storage
>> Novel synthesis technique for high efficiency conversion of source gas to diamond
>> Scientists capture crystallization of materials in nanoseconds
Apr5-12, 02:02 AM   #2
Recognitions:
Yes, there is a phase transition. The order parameter is the cooper pair density and the phase transition breaks electromagnetic U(1) symmetry (in the case of superconductors). The mechanism has been transfered to other systems, so the symmetry broken, and the particles forming the condensate will depend on the system.
New Reply
Similar discussions for: Pairing gap equation weak coupling
Thread Forum Replies
Running coupling of the weak interactions High Energy, Nuclear, Particle Physics 5
Running of the weak coupling High Energy, Nuclear, Particle Physics 1
The weak force and effective coupling High Energy, Nuclear, Particle Physics 2
Weak angle coupling constant High Energy, Nuclear, Particle Physics 10
Weak coupling strength constant High Energy, Nuclear, Particle Physics 1
