New Reply
Why doesn't light interact with dark matter?
Share Thread Thread Tools
Apr2-12, 06:29 AM   #1
Namaste,
Do we understand why light doesn't interact with dark matter? If a photon were to collide with a dark particle, would they be unaffected?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr2-12, 11:28 AM   #2
Recognitions:
In first approximation anything interacting with electromagnetic fields needs some dipole moment. That means it should not be electrically neutral. When having a closer look even particles which are neutral only on average (think about a simple hydrogen atom for example) may interact with light due to fluctuations which induce temporary dipole moments. However, particles which do not carry any electric charge at all will not interact with light and are thus dark. Neutrinos are a good example for that.
Apr2-12, 11:34 AM   #3
but ive read some where that neutrinos do .
even if it has to travel great lengths.
but probability tells me it could also happen twice in a short distance maybe
i read that if a neutrino were to go through lead it could go many light years in distance before actually doing so.if this is true then is this not still frequent in the grand size of things?
Apr2-12, 12:14 PM   #4
Recognitions:
Gold Membership Gold Member
Quote by lostprophets View Post
Neutrinos have nothing to do with dark matter.
Apr2-12, 12:20 PM   #5
mfb
Mentor
Neutrinos do interact - but not with photons. They interact via the weak interaction (and gravity), which is the exchange of W- and Z-bosons.
As the weak interaction is weak, these reactions are very unlikely. A neutrino has a very small probability to interact with an object in its way.
"If a photon were to collide with a dark particle"
There is no collision. They just continue to fly in their direction, without any interaction.
Dark matter does not interact with photons because it is uncharged. Charged particles can be seen, therefore they are not called "dark matter" (which is quite trivial, once you think about it ;) ).
Apr2-12, 07:06 PM   #6
Recognitions:
Let's look at another example. One could ask why electrons aren't affected by the strong nuclear force. While I'm sure there's some complicated answer involving all kinds of quantum mechanics, the simple answer is that they simply don't interact via that force. Similarly, dark matter doesn't interact via the electromagnetic force.
Apr4-12, 03:41 AM   #7
Recognitions:
Quote by uniquestring View Post
Namaste,
Namaste. Welcome to Physics Forums!
Of course light DOES interact with dark matter! Gravitational lensing is the most convincing evidence.
"That's what Dan Coe and his colleagues at JPL have done in their study of Abell 1689. The cluster's mass bent the surrounding space time and thus the light from even more distant galaxies behind it produced warped and greatly magnified images of those galaxies. Coe and company were able to analyze those distorted images and estimate how much dark matter should be present within the cluster. And the image definitely provides further evidence that dark matter does, indeed, exist; if the gravitational effects were only due to the visible matter, the lensing effect would be much weaker, with less distortion."
http://news.discovery.com/space/mapp...smic-lens.html
Apr4-12, 08:06 PM   #8
Recognitions:
Quote by Bobbywhy View Post
Well, this is unfair, since this is a gravitational rather than electromagnetic interaction. Surely the OP is aware that dark matter interacts gravitationally, so the fact that lensing takes place is obvious.
Apr5-12, 02:29 AM   #9
Recognitions:
Quote by Nabeshin View Post
I am not presumptuous enough to know “Surely the OP is aware” of anything.
Two questions were posted in the OP. The first, “Do we understand why light doesn't interact with dark matter?” is not ambiguous. The answer to that question, as in my post #7, is that light does interact with dark matter during the gravitational lensing process. If that was an incorrect answer then I await correction from more educated members here.
The second question in the OP, “If a photon were to collide with a dark particle, would they be unaffected?” apparently requires a different answer. I suspect that since no one knows the nature of that “dark particle” it is impossible to answer this question definitively.
Apr5-12, 03:09 AM   #10
Recognitions:
Except that current theories say that light simply doesn't interact with dark matter at all. So we can say that pretty definitively.
Apr5-12, 04:26 AM   #11
Recognitions:
Quote by Drakkith View Post
Definition: Interact: to act one upon another
Statement: The curvature of space-time near any gravitating mass (including dark matter) deflects passing rays of light - observably shifting, distorting and magnifying the images of background galaxies.
Therefore: Light interacts with dark matter.
Dark matter appears not to interact via the electromagnetic force, and therefore neither emits nor reflects light.
Apr5-12, 06:15 AM   #12
Recognitions:
Sorry, I meant "Doesn't interact with dark matter, other than gravity, at all".
Apr6-12, 12:00 AM   #13
Recognitions:
No problemo! What is important is that OP gets answered...correctly, if at all possible.
Cheers,
Bobbywhy
Apr6-12, 12:48 AM   #14
Question: gluons are electrically neutral. So, a glueball should not scatter light, should it? Or, are there radiative corrections of quark-antiquark virtual pairs, which carry electric charge, that would lead to some sattering?
Come to think of it, similar corrections for the neutrino due to charged W vector bosons should make the neutrino scatter light, shouldn't they?
Apr8-12, 11:13 PM   #15
Recognitions:
Eh, this is fine. I just don't want the OP to be confused and think dark matter couples to the electromagnetic force, that's all.
Apr9-12, 06:31 AM   #16
mfb
Mentor
Quote by Dickfore View Post
Maybe you can get some dipole moment out of the calculation. Similar for neutrinos. Maybe.
But I think you would have to do the actual calculations for this. Maybe positive and negative contributions just cancel each other, and the result is 0.
Apr9-12, 11:38 PM   #17
Recognitions:
The reason it is called dark matter is because it does not appear to interact with photons, ordinary matter or even other dark matter particles.
New Reply
Tags
dark matter, light
Thread Tools
Similar Threads for: Why doesn't light interact with dark matter?
Thread Forum Replies
Could dark matter be light Cosmology 2
Why doesn't dark matter fall into black holes ? Astrophysics 4
do black holes interact with dark matter/energy? Cosmology 12
dark energy = dark matter*speed of light squared? General Astronomy 14
dark matter doesn't (or what's the matter with dark matter? or pick your lame pun) General Physics 4
