 Quote by catellus
ThomasT,
This thread has been inactive for a bit, but I hadn't been following it at the time and wanted to make a observation.
From your post #389
Under an LR theory, isn't it impossible for particle B (say) to tell whether the detection that's happening is individual or coincidental? If that's right, then you can't have different parameters or relationships controlling what happens in individual vs. coincidental detections. Certainly it might be combination of factors, but it has to be the same combination every time.
(edited to correct a small typo)
What you and lugita are not understanding is that the answers to the following questions are different:
(1) what is the probability of a hit at station A
(2) what is the probability of a hit at station A given that a hit was registered at station B
The reason the answers are different is not because the second one involves any non-local influence but because in (2), the fact that a hit has been registered at B, severly limits the domain within which the probability of A should now be calculated. In other words a logical dependence between the the two stations is introduced simply because you chose to consider them together as coincidental results.
