New Reply
in BJT Ie=Ib+Ic ; Ie-emitter current; Ib-base current; Ic-collector current
Share Thread Thread Tools
Apr8-12, 01:36 AM   #1
I have three doubts in BJT:
1). in BJT Ie=Ib+Ic ; Ie-emitter current; Ib-base current; Ic-collector current
then i find in many circuits, collector current is given to load, if the emitter current is greater than the collector current, we can connect the emitter terminal to the load, to get more current...
2). why the collector region is large in BJT
3). why the collector region is moderately doped when compared to highly doped emitter
Please help me in this
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Apr8-12, 05:32 AM   #2
Quote by kpraneethin00 View Post
Sometimes we connect the load to emitter, Google emitter follower. But then we lose the voltage gain.
Also kept in mind that the emitter current is greater than the collector current just by a small amount of a base current. So for BJT that have a large current gain β the difference is not significant. Ic/Ie = β/(β+1) for β = 100 -->Ic/Ie = 100/101 = 0.990099009
Apr8-12, 08:55 AM   #3
Recognitions:
Gold Membership Gold Member
http://hyperphysics.phy-astr.gsu.edu...ds/trans2.html
Apr8-12, 12:37 PM   #4
You have to be careful in how the BJT works. Collector current IS CONTROLLED by the emitter current. You design the circuit to setup the emitter current to get the collector current. Collector has very high output impedance where emitter is very low output impedance. Collector is a controlled current source and emitter is a voltage source. Collector current is controlled by the Vbe drop. Yes, Ie=Ib+Ic, but
[tex]I_c=I_s e^{[\frac{V_{BE}}{V_T}]}[/tex]
Emitter being a voltage source, the current is govern by the voltage drop across the resistor connects to the emitter. Collector current reflects the emitter current.
New Reply
Thread Tools
Similar Threads for: in BJT Ie=Ib+Ic ; Ie-emitter current; Ib-base current; Ic-collector current
Thread Forum Replies
what happens if emitter-base & base-collector junctions are forward biased with 0.7V? Electrical Engineering 10
Transistor Base/Collector Current mystery Electrical Engineering 20
collector,emitter and base Electrical Engineering 3
Collector Current through BJT Circuit Engineering, Comp Sci, & Technology Homework 2
Collector current Electrical Engineering 2
