Proving Injection in Composite Functions
  • Thread starter Thread starter dijkarte
    Injective
The discussion revolves around proving the injectivity of a function f given that the composite function g ° f is injective. Participants explore the implications of this relationship between the functions f and g.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the need to show that f(a) = f(b) implies a = b, questioning whether the injectivity of g is necessary for this proof. Some attempt to use function mapping diagrams to illustrate their points.
The discussion is active with various interpretations being explored. Some participants suggest that a contradiction approach could be used, while others argue against the necessity of g being injective. Guidance has been offered regarding the logical steps needed to establish the injectivity of f.
There is mention of the problem being posed by a professor, indicating that it may not be a traditional homework assignment. Participants express uncertainty about the requirements and the nature of the proof.
dijkarte
Given two functions:
f:A --> B
g:B --> C
How to show that if the (g ° f) is injection, then f is injection?
I tried this:
We need to show that g(f(a)) = g(f(b)) ==> a = b holds true for all a, b in A. But there's nothing said about function g.
I've tried using function mapping diagrams and actually it showed this proposition is wrong.
(g ° f) injective ==> g and f are injective.
No, you don't need to show that, that's given.
You need to show that f is an injection. That is: f(a)=f(b) ==> a=b. That is what you need to show.
You are absolutely right, my bad expressing the problem...
And yeah my post should have been moved under elementary school math ;)
But it's not a homework either, it's a question my professor did not have time to clarify well!
Doesn't really matter. It's the style of homework, so it belongs here. It's irrelevant whether it is actually homework.
So, got any ideas??
You have f(a)=f(b) and you need to prove a=b.
Convert it to g(f(a))=g(f(b)) in some way.
But I think in order to show that f(a) = f(b) ==> a = b, g has to be given as injection as well, though I could prove that both functions g and f are injections using function mapping diagram.
No, you don't need that g is an injection.
And if gf is an injection, then it does NOT imply that g is an injection.
Ok I could prove it by contradiction. Assuming f(x) is not injection, then
Then there's the case where f(a) = f(b) and a != b for some a, b
Then g(f(a)) = g(f(b)) where a != b, which contradicts the given argument.
That is ok. But there is no need for a contradiction argument.
If f(a)=f(b). Taking g of both sides, we get g(f(a))=g(f(b)). By hypothesis, this implies a=b.
Got it! Any good reference that helps with doing proper proofs?
Thanks.
The book "How to think like a mathematician" by Kevin Houston is a good book.
