New Reply
Is there a difference between a car fuel pump and a water pump
Share Thread Thread Tools
Apr13-12, 12:43 PM   #1
I am going crazy!
These websites appear to contradict one another...
The lowering of the diaphragm makes the inlet valve of the fuel pump open. With this valve open, fuel is drawn from the gas tank and into the pump. At the same time, the lowering of the diaphragm closes an outlet valve.
Read more: How Car Fuel Pumps Work | eHow.com http://www.ehow.com/how-does_5004513...#ixzz1rwSrcgdV
A vacuum is created inside the pump casing each time the diaphragm is raised (see figure below). This opens the inlet valve and seals the discharge valve allowing water and air to enter the pump. When the diaphragm is lowered the resulting pressure seals the inlet and opens the outlet valve purging the pump housing of water and air..
http://www.pumps-in-stock.com/diaphr...p_designs.html
So which way round is it? When the diaphragm is raised does this open the inlet and close the outlet or the reverse or do these pumps work differently?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Apr13-12, 02:21 PM   #2
Would you consider the orientation of the diaphram pump to be the reason for your confusion - do a flip of 180 degrees of one pump described and it acts exactly just as the other. What would the text say if the diaphram pump was operated in a 'sideways' orientation?
Apr15-12, 10:19 AM   #3
Thanks. The other question is if the check valve jams and stays closed why is it less force will be required to move the piston down?
New Reply
Thread Tools
Similar Threads for: Is there a difference between a car fuel pump and a water pump
Thread Forum Replies
Submersible Water Pump, 4.3 amps, must work in the water, General Physics 1
Aircraft Fuel Booster Pump - Centrifugal & Immersed in Fuel Mechanical Engineering 1
A flex-fuel pump in every gas station Current Events 42
Water Pump Flow General Physics 1
Difference between a fan and a pump? Mechanical Engineering 16
