New Reply
What is the strongest known bendable material?
Share Thread Thread Tools
Apr5-12, 08:15 PM   #1
By "bendable" I mean "you can run it through a pulley and it retains tension", and by "strong" I refer to tensile yield strength.
Thanks in advance.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Apr5-12, 09:36 PM   #2
Mentor
Carbon nano-tubes I suppose - could you provide some context, though?
Apr6-12, 06:44 AM   #3
Quote by russ_watters View Post
Strongest crossbow string, basically.
Apr6-12, 07:20 AM   #4
I would have said a chain, but for a crossbow that might not be the best choice.
There are very strong fibers like Zylon.
http://en.wikipedia.org/wiki/Zylon
Apr6-12, 07:52 AM   #5
So is Zylon usable as rope/flexible string?
Apr6-12, 08:02 AM   #6
Don't know. I have only seen it used soaked with epoxy to reinforce high-field magnets. Off the spool the stuff is a bit ... hairy, so for a string you'd have to insert it into some kind of shell, the way climbing ropes are built.
Apr7-12, 09:00 PM   #7
Mentor
The question seems odd - a crossbow isn't that demanding of an application, so you really don't need anything close to the strongest.
Apr8-12, 07:51 AM   #8
That depends on the draw weight. There isn't really a limit on how stiff you can make the prods, after all. I was trying to work out if you could build a 10 ton draw-weight crossbow.
Apr14-12, 06:48 PM   #9
Ive seen this done, some guys I worked with years ago built a crossbow based on plans for a trigger they found online. They used a leaf spring from an old van and a 10t cable as the string. The arrow was 20mm dia stainless rod, with a ground tungsten carbide tip brazed on the end. Long story short, it needed to be cocked with the overhead crane and fired from a vice, it shot straight through a solid brick wall, then it was declared evil and promptly dismantled.
Apr19-12, 01:25 AM   #10
Carbon nanotubes
New Reply
Thread Tools
Similar Threads for: What is the strongest known bendable material?
Thread Forum Replies
Strongest material conformation Materials & Chemical Engineering 2
Material that is bendable in certain conditions Materials & Chemical Engineering 2
Which is strongest base? Biology, Chemistry & Other Homework 1
What's the best/strongest material for RC car models? Mechanical Engineering 10
What is the strongest electrolyte? Materials & Chemical Engineering 0
