New Reply
Question about auto-volt adapters for electrical appliances
Share Thread
Apr25-12, 04:47 AM   #1
Some appliances have built in auto-volt transformers that enable them to be used in different countries with different voltage standards for power transmission. Do the auto-volt transformers use a coil spring coupled, motor controlled tap that can change the number of turns from the secondary inductor that the load is connected to depending on the voltage fed to the motor or is it possible to use a solid state control on the auto-volt transformer?
PhysOrg.com engineering news on PhysOrg.com
>> Multiview 3-D photography made simple
>> Giant 3-D printed bugs shed light on insect anatomy
>> A microphone that listens with light
Apr25-12, 08:21 AM   #2
Recognitions:
Homework Helper Homework Help
What appliances do you have in mind? I'm sure there is no moving part. But I don't know how it is achieved. It could be entirely managed on the secondary, so that the DC output voltage is maintained at a set value. The appliances you have in mind all use DC, don't they? They probably convert the mains AC → DC → high freq AC → transformer → switching DC regulator
Apr25-12, 08:55 AM   #3
Engineering 2012
Recognitions:
Gold Membership Gold Member
many modern switching supplies can handle such a wide range of input voltage that they dont care what is input voltage so long as it's between about 100-300 volts. They immediately rectify it to DC then step that down to whatever they want with a high frequency switching regulator. Read up on switch mode power supply, SMPS.
Daughter's 120 volt flatscreen Vizio TV used a 450 volt capacitor in its SMPS. 450/√2 = 318 volts, so it could easily handle 240.
Apr25-12, 11:05 AM   #4
Quote by jim hardy View Post
The problem is not in the voltage threshold of the power supply itself but the appliance it is going to power. The appliance needs a specific low voltage to operate so how does the auto-volt transformer ensure that the output stays fixed at this level even as the voltage is increased?
There is this type of transistor that supposedly switches off the current from the power supply when current is delivered to the base. It acts like a NOT gate so that when current is delivered to it through the base, there will be no electrical output. It is denoted by a circle in front of the base terminal.
May it be possible then, to use this transistor, in addition to a conventional transistor, to control the output of the secondary inductor? The NOT transistor will be connected to the one of the terminals of the inductor while the regular transistor will be connected to a tap which is then connected to the center of the inductor.
The transistors will have resistors connected to their base terminals to modify the threshold voltages so that if a low voltage goes into the transistors, the terminal connected to the NOT transistor will be switched on and the terminal connected to the center tap will be switched off, allowing the full number of turns of the inductor to be used when the source voltage is low.
But when sufficiently high voltage goes into the transistors, the NOT transistor will switch off the connection to one of the terminals and the regular transistor will switch on the connection to the center tap, causing the high input voltage to be sufficiently lowered to the fixed output voltage by halving the number of turns of the output inductor.
The circuit diagram is below:
Apr25-12, 11:23 AM   #5
Recognitions:
There is no autotransformer, the power pack is way too light to contain that. A switching power supply is the name of a specific type of power processor. http://www.physicsforums.com/showpos...77&postcount=2
Apr25-12, 11:43 AM   #6
Engineering 2012
Recognitions:
please start here
http://en.wikipedia.org/wiki/Switched-mode_power_supply
it's a concatenation of very simple devices. Study and understand them one at a time.
old jim
Apr25-12, 11:47 AM   #7
But circuit diagrams for electronic auto-volt adapters show that AC adapters have transformers.
Additionally, there are variable voltage AC adapters that use manually operated variable voltage transformers that are controlled by a dial.
These transformers, whether manual or automatic have a low wattage rating so they are very small.
Apr26-12, 02:59 AM   #8
Recognitions:
Quote by Bararontok View Post
The two-winding transformer is usually a safety measure, it is included to isolate the user side from the mains. An autotransformer (50/60Hz) is unlikely here because it adds cost and weight while affording no isolation, so no safety.
By a switch, aren't they? I think you'll find these switch an extra number of turns in/out of the primary winding to accommodate the different line voltages--it's still basically a two winding transformer.
The transformers you see in modern AC adapters are high frequency transformers, and so can be small and light weight while offering comparatively high power transfer. They are integral to the switched-mode power supply.
That said, I see no reason why it shouldn't be possible to devise a low power tap-changing arrangement to regulate the AC on the secondary of a multi-winding 50/60Hz isolation transformer. MOSFETs would make good bipolar tap-changing switches. It would be costly and require specially wound transformers. Except for niche applications, I doubt that it is done.
It was not clear whether your original post was a concept idea from your imagination, or based on an actual design you had read about. Which?
Apr26-12, 08:37 AM   #9
Engineering 2012
Recognitions:
http://www.variac.com/
Apr27-12, 12:03 AM   #10
Quote by NascentOxygen View Post
The circuit is an original design used for the conceptualization of a variable transformer operated by solid state switches.
These types of variable transformers are mechanically operated. Is there one that is automatic and transistor operated?
Apr27-12, 12:19 AM   #11
Engineering 2012
Recognitions:
I've seen them motor operated.
And i've seen industrial transformers that have multiple taps with thyristor switches to select among the taps.
The Sola/Hevi-Duty “SOLATRON PLUS” Line Voltage Regulator is designed
to provide a tightly regulated, isolated voltage source to sensitive loads,
increasing reliability, improving efficiency and extending the useful life of
protected loads. Input Voltages of +15%/–25% are corrected to +/-3% typical
(+/-5% maximum) with a response time of 1 cycle (typical). Output voltage
regulation is accomplished using silicon rectifier switches and a multi-tap
transformer arrangement. Tap transitions are made in a secondary control circuit
and at less than full load current eliminating voltage notching during each
transition.
There are no brushes or moving parts to replace.
http://www.google.com/url?sa=t&rct=j...vxoHfUSwJwD_aA
But appliances within my experience are much simpler and operate as in post #6.
see if this link works.
http://www.google.com/url?sa=t&rct=j...L6u_l9JB_gvTSQ
It should get you to Solatron's "Power Solutions Desk Reference" .
They pretty much "wrote the book".
New Reply
Similar discussions for: Question about auto-volt adapters for electrical appliances
Thread Forum Replies
What is the use of the grounding terminal in the plugs of some electrical appliances? Electrical Engineering 8
DC adapters Electrical Engineering 8
Gripe, and a question...electronics in appliances. Electrical Engineering 13
