A classical challenge to Bell's Theorem?
The discussion revolves around a classical reinterpretation of Bell's Theorem, specifically examining the implications of using classical sources in a Bell-test setup. Participants explore the nature of randomness in quantum mechanics versus classical systems, the calculation of expectation values in a classical context, and the conditions under which the CHSH inequality can be applied. The scope includes theoretical analysis and mathematical reasoning related to quantum entanglement and classical correlations.
  • Some participants argue that quantum mechanics introduces intrinsic randomness, contrasting it with classical randomness, which they describe as deterministic but practically unpredictable.
  • One participant proposes a classical scenario involving correlated light pulses sent to two observers, Alice and Bob, and requests calculations related to the CHSH inequality under these conditions.
  • Another participant points out the necessity of defining specific functions for A(a,x), B(b,x), and ρ(x) to perform the requested calculations, emphasizing that the values of A and B can only yield certain outcomes based on their definitions.
  • A later reply questions the nature of quantum events, suggesting that they may lack upstream causes, which complicates the understanding of measurement in quantum mechanics.
  • One participant introduces a hypothetical scenario involving a mystical being that governs a parameter affecting measurement outcomes, questioning how this would relate to the CHSH inequality.
  • There is a discussion about whether the CHSH inequality would yield the same maximum value in the classical setting as in quantum scenarios, with some participants expressing uncertainty about the implications of their proposed changes to the original setup.
Participants express differing views on the implications of classical versus quantum randomness, the necessity of specific function definitions for calculations, and the interpretation of the CHSH inequality in classical contexts. The discussion remains unresolved, with multiple competing views present.
Participants note limitations in the discussion, such as the need for specific definitions of functions and the assumptions underlying the classical scenario. There is also an acknowledgment of the complexity introduced by the nature of quantum measurements and the hypothetical scenarios presented.
  • #181
De Raedt et al. use the coincidence loophole. With a small coincidence window, many particles are not matched with a partner.
It is a cute trick. Each pair of particles agrees in advance what pair of settings it wants to see. If either sees the "wrong" setting, it arranges that its detection time is a little earlier or a little later than "normal". If both see the wrong setting the time interval between their arrival times is lenthened to something larger than the coincidence window. This way you can bias the correlations just how you like.
The important efficiciency parameter in experiments where the measurement times are co-determined by the particles is the chance that a particle detected in one wing of the experiment has a detected partner on the other side, ie the chance that a detected particle s part of a detected pair. If this chance is smaller than 100% you can violate CHSH. The smaller the chance, ie the more unpaired events, the bigger a deviation from the CHSH bound of 2 can be manufacturds. At about 95% you can get to 2 sqrt 2 in CHSH. In principle, you can recover the singlet correlations in this way.
The arrival times are correlated with the local hidden variables. The experimenter creates non-local correlation by selecting pairs on the basis of the arrival times.
arXiv:quant-ph/0312035
Bell's inequality and the coincidence-time loophole
Jan-Ake Larsson, Richard Gill
Europhysics Letters, vol 67, pp. 707-713 (2004)
  • #182
PS to Bill Schnieder: Christian's model comes in several variants. In all of them, the actual outcomes are perfectly anti-correlated whatever the settings. He claims to get -a.b only after dividing the covariance of -1 by two bivector standard deviations. (Already quite an absurd idea). And then he makes a simple sign mistake while doing this calculation, probably confused by his own ambiguous notation. In some versions of his model, he fixes the mistake by changing the postulates. The new postulates are mutually incompatible. ie the model is empty, the axioms cannot be satisfied. These errors have been known by him for four years or more yet he continues trying to hide them. No single paper by him on his model has been published in a peer reviewed journal.
Kracklauer uses the detection loophole and/or the coincidence loophole, just like de Raedt. Accardi uses the detection loophole. Hess and Phillip's very elaborate model was built around a little but well hidden mathematical error, dropping a crucial index in going from one formula to another.
And so on, and so on.
  • #183
billschnieder said:
You do not know that so why do you state it as though you do? [..]
I did not realize that until recently; the latest discussions on the different forums clarified this for me beyond reasonable doubt, in part thanks to Christian himself. However, all that is off topic here (you can send me a PM).
  • #184
Gordon Watson said:
[itex]E(AB)_{Aspect(2004)} = E(AB)_Y = \int d\lambda \rho (\lambda ) (AB)_Y <br /> <br /> = \int d\lambda \rho (\lambda )A(\textbf{a}, \lambda )B(\textbf{b}, \lambda )_Y[/itex]
[itex] <br /> = \int d\lambda \rho (\lambda )[ 2 \cdot P(B^+|Y,\,A^+) - 1] <br /> <br /> = \int d\lambda \rho (\lambda)[2⋅cos^2(\textbf{a}, \textbf{b}) - 1][/itex]
[itex] <br /> = cos[2(\textbf{a}, \textbf{b})] = QED![/itex]
GW,
Sorry but this is not a derivation, this is wishful thinking. While individual bits and pieces may look sort of all right, the steps do not follow one from another at all.
[itex]E(AB)_Y = \int d\lambda \rho (\lambda ) (AB)_Y <br /> = \int d\lambda \rho (\lambda )A(\textbf{a}, \lambda )B(\textbf{b}, \lambda )_Y[/itex]
That's Bell's LR condition all right. Fair enough.
[itex]= \int d\lambda \rho (\lambda )[ 2 \cdot P(B^+|Y,\,A^+) - 1][/itex]
What the heck is that? Why are you integrating over λ a probability which is not a function of λ, what is that supposed to mean? (Thankfully there is no harm done, but it is just pointless and conceptually wrong thing to do, as P(B|A) is itself an implicit integral over all possible λ. I assume you are integrating the whole thing and not just multiplying ∫ρ(λ)dλ by the expression in the square brackets, which would be equally silly) Where did Y come from?
But crucially ... how did you get here form there?
I mean I sort of know where you got this expression from, don't bother telling me, but... you didn't actually derive it from the previous line of your 'proof', did you? I mean, you did not actually start with the first expression and somehow transmogrify it into the second one by applying strict rules of math, did you?
You do understand that there is no connection whatsoever between what you just did and the previous line, don't you? That the two expressions were written under different set of assumptions, specifically that the second line describes all possible set-ups where certain symmetry conditions are met while the first one only applies to LR ones? That it is incorrect in general to put equal sign between them? That there are plenty of counter-examples where [itex]2 \cdot P(B^+|Y,\,A^+) - 1[/itex] cannot be factorized into [itex]A(\textbf{a}, \lambda )B(\textbf{b}, \lambda) \rho(\lambda)[/itex]? etc. etc.
[itex]= \int d\lambda \rho (\lambda)[2⋅cos^2(\textbf{a}, \textbf{b}) - 1][/itex]
Now, this [itex]cos^2[/itex] was taken from Aspect paper, where it was obtained as a prediction of QM. This happens to be exactly the case I mentioned earlier which cannot be factorized into [itex]A(\textbf{a}, \lambda )B(\textbf{b}, \lambda) \rho(\lambda)[/itex]. And so your 'derivation' instead of being 'incorrect in general' becomes just 'wrong' .
  • #185
From what I understand, V represents the experimental conditions.
[itex]E(AB)_V = \int_{\Lambda} (A^\lambda \cdot B^\lambda)_V \, \rho (\lambda )_V \, d\lambda[/itex]
Instead of integrating over continuous variables λ, we can instead do a summation over discrete outcomes
[itex]E(AB)_V = \sum_{ij} (A^i\cdot B^j)P(A^iB^j|V), \;\;\;\; ij \in [++, +-, -+, --][/itex]
Note that the only difference between the discrete case and above case is that [itex]A^\lambda[/itex] is a function of λ, and [itex]A^i[/itex] is an outcome. But in both equations, we have the separable product [itex]A \cdot B[/itex] satisfying the locality condition.
[itex]= P(A^+B^+|V) - P(A^+B^-|V) - P(A^-B^+|V) + P(A^-B^-|V)[/itex]
[itex]= P(A^+|V)P(B^+|V,\,A^+) - P(A^+|V)P(B^-|V,\,A^+) - P(A^-|V)P(B^+|V,\,A^-) + P(A^-|V)P(B^+|V,\,A^-)[/itex]
[itex]= P(A^+|V)\left [P(B^+|V,\,A^+) - P(B^-|V,\,A^+) \right ]- P(A^-|V) \left [P(B^+|V,\,A^-) - P(B^-|V,\,A^-) \right ][/itex]
Since:
[itex]P(A^+|V) = P(A^-|V) = \frac{1}{2}[/itex]
and
[itex]P(B^+|W,\,{A^+}) + P(B^-|W,\,{A^+}) = 1[/itex]
[itex]P(B^+|W,\,{A^-}) + P(B^-|W,\,{A^-}) = 1[/itex]
Therefore substituting above, we get
[itex]E(AB)_V = 2 \cdot P(B^+|V,\,A^+) - 1[/itex]
[itex]E(AB)_V = -2 \cdot P(B^+|V,\,A^-) + 1[/itex]
All that remains now is to use Malus law to get [itex]P(B^+|V,\,A^+)[/itex] (or [itex]P(B^+|V,\,A^-)[/itex] for the case where A(·) = - B(·)) according to the experimental conditions V.
  • #186
Delta Kilo said:
GW,
That's Bell's LR condition all right. Fair enough.What the heck is that? Why are you integrating over λ a probability which is not a function of λ, what is that supposed to mean? (Thankfully there is no harm done, but it is just pointless and conceptually wrong thing to do, as P(B|A) is itself an implicit integral over all possible λ. I assume you are integrating the whole thing and not just multiplying ∫ρ(λ)dλ by the expression in the square brackets, which would be equally silly) Where did Y come from?
But crucially ... how did you get here FROM there? [GW EDIT]
You do understand that there is no connection whatsoever between what you just did and the previous line, don't you? That the two expressions were written under different set of assumptions, specifically that the second line describes all possible set-ups where certain symmetry conditions are met while the first one only applies to LR ones? That it is incorrect in general to put equal sign between them? That there are plenty of counter-examples where [itex]2 \cdot P(B^+|Y,\,A^+) - 1[/itex] cannot be factorized into [itex]A(\textbf{a}, \lambda )B(\textbf{b}, \lambda) \rho(\lambda)[/itex]? etc. etc.Now, this [itex]cos^2[/itex] was taken from Aspect paper, where it was obtained as a prediction of QM. This happens to be exactly the case I mentioned earlier which cannot be factorized into [itex]A(\textbf{a}, \lambda )B(\textbf{b}, \lambda) \rho(\lambda)[/itex]. And so your 'derivation' instead of being 'incorrect in general' becomes just 'wrong' .[GW emphasis added]
Delta Kilo, thanks for continuing to engage with the maths here and their physical significance. I am keen to learn of errors and will not hide from them. However, you seem to be a bit time-pressured (like me) at the moment: You appear to have missed the links that I put in my post (specifically for you):
1. The following link was to remind you of "the Malus Method." We use "the Malus Method" -- just like the famous Malus of old -- in that we study the results of experiments and draw conclusions in the form of equations. NB: "Malus' Law" (as such) is strictly limited to W (s = 1): We can generalise over s = 1/2 and s = 1; AND TO MULTI-PARTICLE EXPERIMENTS which were unknown to him!
LINK: "This was explained [edit: POORLY] in my reference to Malus, which I believe is central to addressing some of your concerns: https://www.physicsforums.com/showpost.php?p=3879566&postcount=112
2. LINK: Also see posts leading to, and including: https://www.physicsforums.com/showpost.php?p=3874480&postcount=102
3. This next link was meant to prevent your: What the heck is that? It's what I term "Bill's generalised short-cut."
LINK: "For example (using Bill's generalised short-cut: https://www.physicsforums.com/showpost.php?p=3878616&postcount=110 recalling that V is the general conditional for the style of experiments that we are analysing):"
SO would you mind reviewing your position, please, then commenting on what does not flow correctly for you? I will then provide a detailed mathematical analysis, with no short-cuts.
I am confident that the derivations are sound; every relevant element of the physical reality included in the equations: their physical significance at one with Einstein-locality.
Thanks again, GW
PS: Bill's neat post (above) contains some TYPOS that he might like to fix. So I suggest you hold off on commenting there until they're fixed. Thanks.
  • #187
Yes, sure we can. But why don't we actually try to prove it instead of just saying it?
To make the transition explicit we can split [itex]\Lambda[/itex] into non-overlapping subsets corresponding to distinct outcomes:
[itex]\Lambda = \bigcup_{ij} \Lambda_{ij|V}: \forall \lambda \in \Lambda_{ij|V} \Rightarrow A(\lambda,V)=A_i, B(\lambda,V)=B_j[/itex],
and then show that the integral can be rewritten as a sum of integrals over these subsets:
[itex]\int_{\Lambda} A(\lambda,V) B(\lambda,V) \rho (\lambda) d\lambda =[/itex]
[itex]= \sum_{ij}\int_{\Lambda_{ij|V}} A(\lambda,V) B(\lambda,V) \rho (\lambda) d\lambda =[/itex]
[itex]= \sum_{ij}A_i B_j \int_{\Lambda_{ij|V}} \rho (\lambda) d\lambda =[/itex]
[itex]= \sum_{ij} A_i B_j P(A_iB_j|V)[/itex]
where
[itex]P(A_i,B_j|V) = \int_{\Lambda_{ij|V}} \rho(\lambda) d\lambda[/itex]
The probability integral can be rewritten as
[itex]P(A_i,B_j|V) = \int_{\Lambda_{ij|V}} \rho(\lambda) d\lambda = \int_\Lambda \textbf{1}_{\Lambda_{ij|V}}(\lambda) \rho(\lambda) d\lambda = \int_\Lambda \delta(A(\lambda,V)-A_i) \delta(B(\lambda,V)-B_j) \rho(\lambda) d\lambda[/itex]
(1X(x)= {1 when x∈X, else 0} is a set membership indicator function , δ is a Kronecker delta)
Note, this expression for the probability P(Ai,Bi|V), is part of the derivation. You cannot simply disregard it later on. Your expression for E(AB) as a sum of probabilities is only valid if the probability can be expressed in this particular form.
No, we don't. We don't have separate local settings a and b. Instead we have global V which presumably includes a and b along with any other settings and both A and B depend on the entire V.
Now, if we repeat the derivation above but starting from proper LR condition
[itex]E(a,b)=\int A(a,\lambda) B(b,\lambda) \rho(\lambda) d \lambda[/itex]
We will eventually get the same expression for E(a,b)
[itex]E(a,b)=\sum_{ij} A_i B_j P(A_i,B_j|a,b)[/itex]
but the expression for the probability will look slightly different:
[itex]P(A_i,B_j|a,b) = \int_\Lambda \delta(A(a,\lambda)-A_i) \delta(B(b,\lambda)-B_j) \rho(\lambda) d\lambda[/itex]
The difference is of course that A does not depend on b and vice versa.
Now, QM predicts [itex]P(A=1,B=1|a,b) = \frac{1}{2}cos^2(a-b)[/itex].
I can easily concoct the ingredients to make the probability to come out right in the general case:
[itex]P(A=1,B=1|V) =\int_\Lambda \delta(A(\lambda,V)-1) \delta(B(\lambda,V)-1) \rho(\lambda) d\lambda[/itex]
For example:
[itex]V = a-b[/itex]
[itex]\lambda \in [-1..1], \rho(\lambda)=\frac{1}{2}[/itex]
[itex]A(\lambda,V) = sign(\lambda)[/itex]
[itex]B((\lambda,V) = sign(\lambda) sign(cos^2(V) - |\lambda|)[/itex]
If I now substitute all that into the integral and take it, the answer is going to be
[itex]P(A=1,B=1|a,b)=\frac{1}{2}cos^2(a-b)[/itex]
However, you will notice that B depends on V which includes both a and b.
It turns out to be is impossible to find such A and B for the LR case:
  • #188
There is nothing to prove here. The two expressions are equivalent!
Wikipedia said:
In probability theory, the expected value (or expectation, or mathematical expectation, or mean, or the first moment) of a random variable is the weighted average of all possible values that this random variable can take on. The weights used in computing this average correspond to the probabilities in case of a discrete random variable, or densities in case of a continuous random variable. From a rigorous theoretical standpoint, the expected value is the integral of the random variable with respect to its probability measure.
  • #189
Your argument is essentially that [itex]P(A^+B^+|V)= P(A^+|V)P(B^+|V,\,A^+)[/itex] violates locality, but this is false. You want [itex]P(A^+B^+|V)= P(A^+|V)P(B^+|V)[/itex], but even a simple thought experiment will show how wrong this is. Consider for example the simple experiment (T) which involves coin tosses by two people (heads = +, tails = -)
A B
What is [itex]P(A^+B^+|T)[/itex]??
what is [itex]P(A^+|T)[/itex]?
what is [itex]P(B^+|T)[/itex]?
Still think [itex]P(A^+B^+|V)= P(A^+|V)P(B^+|V,\,A^+)[/itex] violates locality? Still think the probability must be separable if LR is true? Or do you think the coin toss example is non-local?
Note that [itex]P(B^+|V,\,A^+)[/itex] simply means for a given experiment V, we find all the pairs for which A+ was observed on one side, and calculate the fraction of B+ within the same set of pairs, that was observed on the other side. It does not mean there is a non-local influence between A+ and B+.
I should also correct a typo in the previous post where I used W instead of V.
  • #190
This is an interesting statement because it applies to EVERY experiment that has ever been performed on this issue. So you are essentially criticizing Aspect et al for treating their data in a non-local way.
Which of these expressions do you think experimentalists use to calculate [itex]P(A^+B^+|V)[/itex]
OR
[itex]P(A^+B^+|V)= P(A^+|V)P(B^+|V)[/itex]?
Certainly they can only use one of the above, not knowing anything about λ.
  • #191
billschnieder said:
[..] [itex]P(B^+|V,\,A^+)[/itex] simply means for a given experiment V, we find all the pairs for which A+ was observed on one side [..].
Here you refer to the statistical analysis of a small sample. However, P usually stands for probability. As in your coin toss example, the probability of head (fair coin) P=0.5 even if you throw for example heads twice.
  • #192
I did not say the coin was fair and what if the experimnent T can never be repeated because the coins were so fragile that they could only be tossed 7 times. That is why the calculation has to be conditioned on the specific experimental conditions T whose outcomes you have.
T = "two coins tossed 7 times by two people A and B giving outcomes [++, -+, + -, - +, + +, - -, - +]"
Calculate [itex]P(A^+B^+|T)[/itex].
then calculate [itex]P(A^+|T)P(B^+|T,A^+)[/itex] and [itex]P(A^+|T)P(B^+|T)[/itex] and verify that it is not possible to reason correctly in such a simple experiment if you adopt to so called "locality condition" being suggested.
BTW, are you implying that what I'm asking is not a probability?
  • #193
I totally agree! But, with respect, because I much appreciate your engagement with the issues here: You (Delta Kilo), often breach of your own suggestion. Too often (and beyond my humble opinion) your strong opinions are NOT supported by strong analysis (as has been shown on occasion). A recent example is addressed below.
I will be attempting to address my own short-comings too! I am currently under extreme time-pressures. My goal is to keep any consequences out of my posts from here on in: with apologies for recent indiscretions!
NB: I have modified the conditionals in what follows: From V to W°Y (W XOR Y) so that we are addressing specific experiments (W°Y) and not a general one (V). I'd like to see this notation used here from now on; or let W and Y be used alone, as the argument requires.
I'll also stick to λ and λ' as the hidden-variables in all cases; trusting we all agree that some pair-wise function
FW°Y(λ, λ') = 0 is implied in all our studies: λ' being the HV sent to Bob.
[itex]E(AB)_{W°Y} = \sum_{ij} (A^i\cdot B^j)P(A^iB^j|W°Y), \;\;\;\; ij \in [++, +-, -+, --][/itex]
I agree, with no surprises. The study here of the continuous case, per Bell's (1964) protocol, shows that Bell's analysis may be reduced to the discrete case with no loss of integrity. I personally favour Bell's approach; and will probably stick with it.
Delta Kilo said:
No, we don't. We don't have separate local settings a and b. Instead we have global W°Y which presumably includes a and b along with any other settings and both A and B depend on the entire W°Y.
Delta Kilo, please reconsider. What you write is surely wrong?
1. a is the setting of Alice's device, b is the setting of Bob's device. The devices are cleared separated. If you mean that a and b are just arbitrary orientations in 3-space, just say so. But there are NO other settings POSSiBLE, imho! So what do you mean by "any other settings"?
2. You write: "both A and B depend on the entire W°Y." But this is surely false?
Consistent with Einstein-locality and Bell's protocol: A(a, λ) = ±1, B(b, λ') = ±1. There is no dependency of A on B or b or λ'; NOR of B on A or a or λ.
So what do you mean ... in this critical area of analysis so central to our discussions?
In relation to the challenge in the OP, here are my functions A and B for W, X, Y and Z; any new terms*** here being defined by their well-known associates; there being no suggestion here that [itex]\lambda = {\textbf{a}}^+\bigoplus {\textbf{a}}^-[/itex], etc., prior to the relevant Einstein-local particle-device interaction. Rather, the delta-functions put the "quantum-jumps" in the equations and not just in the talk, representing dynamical processes in dynamically defined conditions ... in line with Bell's hope (2004, p. 118):
In short-hand:
A(a, λ) = ∫dλ δ(λ - a+°a-) cos[2s(a, λ) = ±1.
B(b, λ') = ∫dλ δ(λ' - b+°b-) cos[2s(b, λ') = ±1.
Or better:
[itex]A({\textbf{a}}, \lambda) = \int d\lambda\delta (\lambda - {\textbf{a}}^+\bigoplus {\textbf{a}}^-) cos[2s({\textbf{a}}, \lambda)] = \pm 1.<br /> [/itex]
[itex]B({\textbf{b}}, \lambda') = \int d\lambda'\delta (\lambda' - {\textbf{b}}^+\bigoplus {\textbf{b}}^-) cos[2s({\textbf{b}}, \lambda')] = \pm 1.[/itex]
Where [itex]\bigoplus[/itex] = XOR; s = intrinsic spin.
Do you see a problem with these functions? If not, how does your integral proceed, please, with them?
***Edit: Footnote added:
PS:
a+ = a for s = 1/2 or 1; etc.
a- = -a for s = 1/2; etc.
a- = a ± π/2 for s = 1; etc.
The above reflect the related orthogonalities for photons and spin-half particles.
Thanks,
GW
  • #194
Bill, to cover ALL the specific experiments under discussion (W, X, Y, Z), I suggest it is better to state the general case:
All that remains now is to use Malus' Method to get [itex]P(B^+|Q,\,A^+)[/itex] (or [itex]P(B^+|Q,\,A^-)[/itex] according to the experimental conditions Q (be they W, X, Y or Z).
By Malus' Method I mean: Following Malus' example (ca 1808-1812, as I recall), we study the results of experiments and write equations to capture the underlying generalities.
Cheers, GW
  • #195
Where [itex]\bigoplus[/itex] = XOR.
Thanks,
GW
I think you forgot to mention that s is the spin. Is that correct?
  • #196
No in general they are not.
[itex]E(a,b)=\sum_{ij} A_iB_j P(A_i,B_j|a,b)[/itex]
is applicable to any discrete random values A, B with no restrictions whatsoever, while
[itex]E(a,b)=\int_\Lambda A(a,\lambda) B(b,\lambda) \rho(\lambda) d\lambda[/itex]
describes a particular LR setup, where A and B are both functions of random variable λ.
If you treat the two formulas above as a system of equations, and solve it with respect to P(..) you will get the answer:
[itex]P(A_i,B_j|a,b)=\int_\Lambda \delta_{A(a,\lambda),A_i} \delta_{B(b,\lambda),B_j}\rho(\lambda) d\lambda[/itex]
In fact, given any two of the above formulas you can derive the third.
So for the first two formulas to be true simultaneously, the probability has to be representable in this particular form. Malus law cannot be represented is this form.
  • #197
Thanks Bill, now fixed. Along with a few other fixes and expansions that occurred to me on my way back to the office. Your comments on them, especially the delta-functions, would be welcome. GW
  • #198
DK, might it help if you included the general conditional Q in each equation, where Q is an element of {W, X, Y, Z}? GW
EDIT:
PS: I think Bill meant "Malus' Method" -- Malus' Law being strictly limited to W? GW
  • #199
Of course you understood that I did not mean generally, we are discussing Bell, and in this case the two are equivalent. The expectation value [itex]E(AB)_V[/itex] is defined over any probability measure of the probability space V. You can pick anyone you like and you will get the same result. ρ(λ) is just as valid a probability measure over V as ρ(ij), ij ∈ [++,+−,−+,−−]. The latter just makes it easier to compare with how E(AB) is calculated in real experiments. So you cannot think the calculation is wrong without claiming the same about how the Bell-test experimentalists analyse their data.
I do not agree with that characterization. The chain rule of probability theory, P(AB|X) = P(A|X)P(B|X,A), is valid generally. P(AB|X) = P(A|X)P(B|X) is ONLY valid in the limited case in which P(B|X,A) = P(B|X) and even then the chain rule is still valid (ie, the two expressions give you the exact same result). There will never be a situation in which P(AB|X) = P(A|X)P(B|X) would be valid while P(AB|X) = P(A|X)P(B|X,A) is not. In any case, as demonstrated in the coin-toss example a few posts back, separability of the probability is not a requirement for locality.
It now appears you are saying Malus law is non-local. Did I understand that correctly?
  • #200
If you postulate that the two forms are equivalent, then it immediately and automatically follows from the math that the probability has this particular form I have given you.
I am now totally confused. What is V? Earlier it appeared to be either a label identifying particular experimental setup, or a set of parameters including settings a and b. Now you tell me it is a probability space? And ρ(λ) is defined over V?. And the most important, where did the settings a and b go? Can we please get the notation straight, so that E(a,b) is a function of a and b as it should be?
billschnieder said:
The chain rule of probability theory, P(AB|X) = P(A|X)P(B|X,A), is valid generally. P(AB|X) = P(A|X)P(B|X) is ONLY valid in the limited case in which P(B|X,A) = P(B|X) and even then the chain rule is still valid (ie, the two expressions give you the exact same result). ...
Where did I say anything at all about P(AB|X) = P(A|X)P(B|X)? I didn't, obviously, because this condition just means "for a given X, A|X and B|X are independent", which is clearly not true. Instead I said there must exist such A(a,λ), B(b,λ) and ρ(λ) so that the probability can be expressed as
or in more general form:
[itex]P(A_i,B_j|a,b)=\int_\Lambda P(A_i|a,\lambda) P(B_j|b,\lambda)\rho(\lambda) d\lambda[/itex]
where in our particular case
[itex]P(A_i|a,\lambda)=\delta_{A(a,\lambda),A_i}[/itex], [itex]P(B_i|b,\lambda)=\delta_{B(b,\lambda),B_j}[/itex]
See the difference?
That really is a matter of physical interpretation. Say you have a physical process described by a bunch of equations. Suppose you can assign regions of space-time to each physical quantity. Then if you can massage the equations in a way so that each value in the LHS in the intersections of past light-cones of all values in the RHS, then it is local-realistic, otherwise it is not.
  • #201
Yes, I do see a problem. The LHS is a function of λ, while the RHS is not, as the λ has been integrated over.
  • #202
Sorry, your short reply has me mystified:
LHS satisfies Bell's formulation.
MIDDLE satisfies formal definition of a function.
RHS satisfies Bell's requirement.
What am I missing? Thanks.
  • #203
billschnieder asked: It now appears you are saying Malus law is non-local. Did I understand that correctly?
DK, your position is not at all clear to me. Would you mind explaining your view in the context of W? Thanks, GW
  • #204
LHS says A is a function of λ, however MIDDLE is not a function of λ. Also, s appears to be a function of two arguments, but it is not defined anywhere.
  • #205
1. s is defined several places, including the cut that you quoted??
2. That is: s = intrinsic spin of the relevant particle.
3. Why is MIDDLE not a function of λ? In detail, please, for I'm missing your point.
Thanks, GW
  • #206
s appears to be a function of two arguments s=s(a,λ). Where is the definition of this function?
Because λ is the integration variable. This is the way integrals work. It is the same as, for example, [itex]f(x)=\sum_{i=0}^N A_ix^i[/itex] is not a function of i.
  • #207
billschnieder said:
I did not say the coin was fair and what if the experimnent T can never be repeated because the coins were so fragile that they could only be tossed 7 times. That is why the calculation has to be conditioned on the specific experimental conditions T whose outcomes you have.[..] BTW, are you implying that what I'm asking is not a probability?
Indeed, I merely gave my example of a special case of your example as I wrote:
"Here you refer to the statistical analysis of a small sample. However, P usually stands for probability. As in your coin toss example, the probability of head (fair coin) P=0.5 even if you throw for example heads twice."
To elaborate, you could have the following statistical sequence:
While the statistical result of a few throws was ++ for all throws, this does certainly not mean that the probability of throwing ++ is 1.
- http://en.wikipedia.org/wiki/Law_of_large_numbers
- http://en.wikipedia.org/wiki/Student's_t-distribution
  • #208
Gordon Watson said:
[..] All that remains now is to use Malus' Method to get [itex]P(B^+|Q,\,A^+)[/itex] (or [itex]P(B^+|Q,\,A^-)[/itex] according to the experimental conditions Q (be they W, X, Y or Z).
By Malus' Method I mean: Following Malus' example (ca 1808-1812, as I recall), we study the results of experiments and write equations to capture the underlying generalities. [..]
Likely this is indeed the main issue. For this is basically what QM did. And doing so does not provide a mechanism for how this may be possible.
The purpose of such derivations as the one you are doing, should be to determine if the same is true for a similar law about the correlation between the detections of two light rays at far away places. Merely including experimental results does not do that. Malus law for the detected light intensity of a light ray going into one direction can be easily explained with cause and effect models, but this is not done by writing down Malus law.
PS. Your "Note in passing" that "Einstein-locality is maintained through every step of the analysis", is the main point that is to be proved, as Bell claimed to have disproved it; it can't be a "note in passing".
  • #209
I'm quite surprised that you too are playing these types of tricks. If I say
T = an urn with N balls, M of which are red and M-N of which are white and ask you to calculate P(Red|T), will you then tell me that because of law of large numbers ..., won't you simply use basic probability theory and say P(Red|T) = M/N
Now if I tell you that N is actually 2. will you tell me that my sample is too small? Surely you know better, that if you want to use law of large numbers you MUST consider T as the population from which you are drawing infinitely and then you can't escape my question.
So when I say:
Do you still believe that P(A^+B^+|T) is factorable into P(A^+|T) and P(B^+|T), and does that mean the situation is non-local?
  • #210
It looked as if you were tricking yourself (but perhaps it's just a misunderstanding of what you mean?); don't shoot the messenger!
Good - that was my point. :smile:
Now if I tell you that N is actually 2. will you tell me that my sample is too small? [..]
Depending on your conclusions from the outcomes - such as concluding a probability rule from a very small data set - I may warn you again not to confuse statistics with probability, as explained in the provided references.
And since this mathematical issue comes up regularly we should discuss it in the mathematics forum. Please start it as a topic there with a link from here.
  • · Replies 50 ·
  • · Replies 80 ·
9K
  • · Replies 93 ·
  • · Replies 16 ·
  • · Replies 64 ·
  • · Replies 220 ·
24K
