| New Reply |
ferrite magnet as toroid transformer |
Share Thread | Thread Tools |
| Apr30-12, 10:23 PM | #1 |
Dear Experts
I have a 1.5 cm ring magnet, you know, the black color type of common low magnetic power magnet. I wrapped 5 turns of copper wire around it on one side and then wrapped 10 rounds of another copper wire around it . I connected 5v battery to the 2 ends of the primary coil which is the 5 turn winding. I then measured with volt meter the secondary coil. I did not see the output voltage at the secondary coil increase. This is my noobie attempt. Please comment what could be wrong. Can a ferrite magnet be used to step up voltage? I want to step up the voltage by around 2 volts. Many Thanks. regards Ramone |
| Apr30-12, 10:34 PM | #2 |
Recognitions:
Transformers only work on AC signals, so you would have to switch your battery current on and off through the primary winding to see anything on the secondary.
However, a ferrite magnet would be a poor choice for a transformer core. Better options would be normal ferrite or soft iron laminations from a transformer. |
| Apr30-12, 11:21 PM | #3 |
Are you talking about a toroidal "refrigerator" permanent magnet made of "hard" ferrite? You will need up to 300,000 amp-turns per meter. See attached table from http://www.what-are-magnets.com/10STRONTIUMCERAMIC.HTM
| May2-12, 08:45 AM | #4 |
Dear Experts
So , what is the recommended way to stepup a 5v dc battery pack to 8volts, occupying minimal space? Kindly please offer me an idea. I have sen videos demonstrating how a joule thief can light up a 3v led using just 1.5v. I wonder can this toroid be modified/ used as-is to function as transformer ? Yes, i am using a toroidal fridge magnet. its ferrite but permanently magnetised, i think. Is the effect different than a non-magnetised ferrite? Cheers |
| May2-12, 12:42 PM | #5 |
Other mfgrs also make similar chips. |
| May5-12, 12:31 PM | #6 |
Thanks so much Bob S. I will get a ferrite toroid and try again.
Cheers :) |
| May5-12, 12:57 PM | #7 |
| May7-12, 09:03 AM | #8 |
Dear Bob
Thanks for your reply. I am looking at output of as high as 500 milliamps, input voltage of any between 9v to 12 v and output of 5.5 to 6v. Is it possible to get free samples of 1 or 2 units for testing? Thanks. Regards Ramone |
| May7-12, 10:59 AM | #9 |
Recognitions:
You get free samples if someone thinks you might buy $500 worth of something. So, they ask who you work for and what your position is.
So, unless you are likely to buy a lot of something, you shouldn't ask for free samples. Almost free, though, are these on Ebay: http://www.ebay.com.au/itm/DC-DC-Con...item3f154a0adc Synchronous rectification, Max efficiency up to 98%. Input: 4.75-24V. Output: 0.93V-18V ( Buck Mode, the input must be 2V higher than output ). Output Current: continuous 2.5A ( Peak 4A). Price about $3.50 US. Which country are you in? |
| New Reply |
| Thread Tools | |
Similar Threads for: ferrite magnet as toroid transformer
| Thread | Forum | Replies | ||
| magnetising a permenant ferrite magnet | Electrical Engineering | 1 | ||
| Confused about Ferrite Beads | Electrical Engineering | 6 | ||
| How do ferrite beads work? | General Physics | 1 | ||
| Finding start of ferrite transformer | Electrical Engineering | 6 | ||
| RFID Antennas with ferrite Rod | Electrical Engineering | 0 | ||
