No, that's not what effective potential means. You get effective potentials when you go into a accelerating reference frame. In case of central potentials, it's usually rotating frame, but it's more general than that. Central potential is most commonly used when talking about orbital motion. So lets look at such a case. Imagine a body orbiting in central potential along some elliptic path. In general, you have r(t) and θ(t). Now, lets go into a frame that rotates at the same rate as the orbiting body. In that frame, θ'(t)=0 and r'(t)=r(t). So now we only need one coordinate to describe the motion.
What forces act on the body for r(t) to vary? There is still the gravitational force, Fg=-GMm/r², but because we are now in a rotating frame, there are also the centrifugal and Coreolis forces. The later is irrelevant, since it's along θ. That gives us the total force acting on the body F=ω²r-GMm/r². But ω can depend on r, so that needs to be looked after. Fortunately, we know that angular momentum L=mωr² is a constant, so ω=L/(mr²), which lets you rewrite formula for force. F=L²/(m²r³)-GMm/r². This force does happen to be conservative, which means there is a potential that satisfies F=-dU/dr. Usually, you also take U→0 as r→∞. A potential that satisfies both is Ueff=L²/(2m²r²)-GMm/r. That's your effective potential.
Basically, it's the potential that allows motion in an accelerated frame of reference as if it was an inertial frame of reference. Specifically, in this case, it's a potential in which body would move in one dimension, along r, the way a body is supposed to move when in orbit.
Edit: It arises a little more naturally in Lagrangian mechanics, but it's the same exact principle, and you'd use roughly the same kind of logic to derive it. Unfortunately, in my experience, both high school and university mechanics courses are really inadequate in covering accelerated reference frames. This is just an example of such inadequacy. You should have better foundation in accelerated frames before you dive into orbital mechanics using effective potentials.
