Can Magnet Doors Launch a Spaceshuttle into Outer Space Without Using Fuel?
  • Context: Graduate
  • Thread starter Thread starter partisar1
    Magnet
The discussion revolves around the hypothetical concept of using powerful magnets to launch a space shuttle into outer space without expending fuel. Participants explore the feasibility of this idea, touching on principles of magnetism, energy requirements, and the nature of magnetic fields.
  • One participant proposes a scenario involving two mega-magnets, one on Earth and one in space, suggesting that closing a door could allow the shuttle to be pulled by the magnet in space without using fuel.
  • Another participant points out that magnetic attraction is mutual, meaning that while the magnet pulls the shuttle up, the shuttle simultaneously pulls the magnet down, referencing Newton's Third Law.
  • Concerns are raised about the impossibility of focusing a magnetic field in the manner described in the hypothesis.
  • A participant mentions previous calculations indicating that the energy required to operate such a system would be impractically high, suggesting a solar array of significant size would be needed to power the magnet.
  • It is noted that permanent magnets cannot be used to extract work without an external energy source, as they generate a static field.
  • Some participants discuss the theoretical possibility of shielding magnetic fields but emphasize that such shielding would require energy and is not feasible without it.
  • There is mention of superconductors and their potential to shield magnetic fields, but it is acknowledged that no room-temperature superconductor has been observed yet.
  • Participants discuss the shielding properties of hard drive magnets, questioning the nature of the shielding and how it works.
  • One participant shares personal experiences with hard drive magnets, explaining their magnetization pattern and the effect of shielding on magnetic flux.
Participants express multiple competing views regarding the feasibility of using magnets for launching a shuttle, with no consensus reached on the validity of the original hypothesis or the technical claims made.
Limitations include the assumption that magnetic fields can be focused or shielded in the proposed manner, as well as the dependence on hypothetical materials that may not exist. The discussion also highlights unresolved questions about energy requirements and the nature of magnetic interactions.
partisar1
I don't have a physics background but a debunking to this irrational thought process of mine would be much appreciated. I understand perpetual motion/energy is an old, dried, and silly topic, but I can't make sense of this, so thank you in advance for answering (and yes, it's to do with magnets).
This hypothesis doesn't rely entirely on perpetual motion, but consists primarily of it. I'm sure there's something basic I don't understand.
Hypothesis:
There are two mega-magnets with incredible magnetic pull, and an extremely focused, narrow scope (capable of pulling specific objects from within Earth's atmosphere from outer space). For the example imagine two identical mega magnets, M1 & M2.
M1 is positioned on Earth's surface, M2 is orbiting in outer space with just enough fuel to always keep it at an exact parallel with M1, but in outer space. For the example consider both magnets have the pulling power to pull a heavy object of equal distance to one another.
There is a giant spaceshuttle made of ferromagnetic material, sufficient enough in quantity to be attracted to either magnet if the other didn't exist (ie: if the shuttle was in the position of M1, but M1 didn't exist, M2 could pull it to itself, and vice versa).
Consider a scenario where M1 is built in such a way that it's based deep in the earth, with a giant non-ferromagnetic door that is capable of blocking the magnetic attraction. This door is capable of opening and closing independently of the magnet (using traditional power/electricity), and serves simply to block M1's pull. The same situation exists for M2 somehow (let's say instead of outer space it's based deep within the moon with the same door complex).
In order to move the shuttle from the surface of the Earth into outer space expending no fuel from the shuttle, would one not just need to close the door on M1's side, eliminating its magnetic influence on the shuttle and allowing M2 to pull? And when it's time to land, to put the door over M2 and allow M1 to pull?
Thanks.
One problem with your scenario is that magnetic pull goes both ways. If a magnet in space can pull the shuttle UP, the shuttle will, at the same time, be pulling the magnet DOWN. This is covered by Newton's Third law, which applies to attractions as much as it does to collisions.
As much as the shuttle is attracted to the magnet, the magnet will be attracted to the shuttle.
If I'm not mistaken, you cannot "focus" the magnetic field in such a manner either.
I had a nice 2 page write-up where I did all the math proving that this wouldn't be effective at all, comparing the energy uses to that of the shuttle et al. Also considering various outfits for M2 the satellite electromagnet, but when I submitted it, PF asked me to "please log in" and lost the whole post. So here is a little diagram that was part of it showing the work required to lift an object, provided you have a 100% efficient conversion through the different "types" of energy (which you never do). I do have a few of the final numbers written down, one of which was for the orbiting satellite to simply power the magnet (100% efficiency) it would require a solar array of 8 square miles, at 10-15% efficiency per cell.
What a bummer, I was proud of that post, and spent the better part of an hour writing it.
You cannot extract 'work' from a permanent magnet. It is a static field. You can temporarily get 'work' from a static field, like gravity, but, it is strictly temporary without an external energy source.
If you could shield a permanent magnet without using energy, then you could have perpetual motion. Think about how electromagnets are used. They simply turn on and off at certain times, and can be used as an engine, to propel a roller coaster etc. If you shielded and unshielded a permanent magnet you could do the same thing.
But, it would take energy to shield the magnetic field. Whatever it is you use to shield the magnetic field, would need to repel the magnetic field which would be a force acting on both the magnet and the shield.
QuarkCharmer said:
Also considering various outfits for M2 the satellite electromagnet...
His magnets are permanent magnets, though. He turns them on or off by means of a fictional non-ferromagnetic door that can block the magnetic field. No such material exists, which is another thing wrong with the scenario.
There is no known material that can completely shield anything from a magnetic, or gravitational field.
but you can distort the field with a ferromagnet, yes? that can do it to some effect
That is an unrelated effect to what is being discussed.
You can shield a magnet with a superconductor, but not for free.
What about hard drive magnets? they are shielded on one side,disassemble one and check it out.
In theory, a superconductor could exist at room temperature. Unfortunately, such a material has never been observed.
Here's an interesting article about magnetic cloaking.
To test the antimagnet, the Slovak group cooled the cloak with liquid nitrogen to activate the superconductor, and placed it in a static, uniform magnetic field with a strength of 40 millitesla. Using a measuring device called a Hall probe to map the magnetic field, the researchers found that the field lines did not enter the cloak, even through from the outside they appeared to pass straight through. They say that theirs is an 'exact' cloak — one for which the cloaking could, in principle, be made perfect using currently available materials.
http://www.nature.com/news/antimagnet-renders-magnets-invisible-1.10292
Is that shielding for magnetic fields, or from EM radiation?
Its a shield for a magnetic field,if you take a hard drive apart you will see the neodymium magnet is super strong on one side and the otherside with the piece of metal on it has no magnetism at all. Don't ask me how it works I would like to know myself?
Those magnets are magnetized in two places, toward the ends. The poles are switched. Hold it with the magnet side facing you and you will have a North pole at one end, a South at the other. There is a corresponding South and North pole on the other side of the magnet where the "shield" is. The magnetic flux on that side is confined to the metal. I've pried the metal off on several of them and confirmed the magnetization pattern with a compass.
zoobyshoe said:
Those magnets are magnetized in two places, toward the ends. The poles are switched. Hold it with the magnet side facing you and you will have a North pole at one end, a South at the other. There is a corresponding South and North pole on the other side of the magnet where the "shield" is. The magnetic flux on that side is confined to the metal. I've peeled the metal off on several of them and confirmed the magnetization pattern with a compass.
mmmm!very interesting. I will check it out when I'm feeling a bit better, I just broke a bone in my foot aaaaagh!
Wow. Better get that taken care of.
Ive taken a painkiller an anti inflammatory and I've got my foot elevated on a cushion, I won't be using magnets to try and cure it that for sure.LOL
It doesn't shield it, its redistributed. So the field is no weaker, its just being bent around again. Look at http://en.wikipedia.org/wiki/Halbach_array this redirects the field very effectivley. A fridge magnet does the same to a much weaker extent. The HD mags can be taken off by simply twisting the ferrous plate. You will then find that the magnet is just as strong of either side and the plate is still not magnetic. Very interesting plate material for being so thin.
No, a hard drive magnet with plate attached has nothing to do with a Halbach array.
So if there is an energy source... It won't be temporary?
If it were temporary it could last a long "temporarly" time :-p
If it is not an halbach array causing this effect then what is it? Is the shield magnetized in sections to get the effect? This is getting confusing.
A halbach array has no shield. It's a bunch of magnet segments cleverly arranged and glued to each other so one pole dominates and the other is suppressed.
A harddrive magnet with a shield on one side is doing something different. The magnetic flux from north to south is contained within the shielding material on one side and allowed to project out into space on the other.
A halbach array presents one pole on one side of the array and no pole on the other (it's there, just suppressed), a HD magnet with shield presents two poles on one side and two "contained" poles on the other.
The point of a A halbach array is to kind of "fake" a magnetic monopole, a thing that doesn't actually exist. The HD magnet with shield has two frank poles, there's no attempt at a monopole.
I now know what an halbach array is but the crux of my question is,what properties of the shielding material is causing this effect,how does it contain the flux?
I don't know how it contains the flux. All I can tell you is that it is a property of magnetic flux that it 'prefers' to concentrate itself in magnetic metals rather than space.
http://en.wikipedia.org/wiki/Magnet_keeper
I think I have it worked out? The so called shield doesn't have any special properties at all, it is really a simple bracket/short circuit device,instead of shorting electricity, it is shorting the magnetic field close to the magnet so that it can't go out into space.
That's pretty much it, yep.
14K
  • · Replies 27 ·
  • · Replies 21 ·
9K
  • · Replies 18 ·
10K
