| New Reply |
Subset problem |
Share Thread | Thread Tools |
| May2-12, 12:40 PM | #18 |
Subset problemP.S.: Please compare the output of the following Python program (Python is almost pseudo-code, so it should be "understandable"), to see if this is what you expect. (I need some time to explain to myself why this seems to work; my subconscious tends to work faster --though not always right-- than my rational part, I guess.) At first I thought this program would run in linear time because, while the problem is subdivided in two and recursively solved, I thought the left branch of the tree would extinguish pretty quickly. When trying with larger numbers I see that this is not really true. It's still way faster than the brute-force approach of generating all subsets and counting them. Output: Code:
1 0 2 0 3 0 4 2 5 7 6 19 7 46 8 104 9 224 10 470 11 970 12 1979 13 4009 14 8083 15 16248 16 32600 17 65330 18 130820 19 261838 20 523918 Code:
#!/usr/bin/python def main(): for n in range(1, 21): print n, count(n) def count(n): return compare(n, n - 1) def compare(n, p): if n <= 0: return 2**p - 1 if p <= 0: return 0 return compare(n - p, p - 1) + (p > n) + compare(n, p - 1) main() |
| May2-12, 03:13 PM | #19 |
Here is some rationale as to why the above program appears to work. Consider, for example, the case N=5, where you want all subsets of {1,2,3,4} whose sum is larger than 5. I have listed all subsets below.
Code:
Sum
1 { 1} 1
2 { 2 } 2
3 { 2 1} 3
4 { 3 } 3
5 { 3 1} 4
6 { 3 2 } 5
7 { 3 2 1} 6
8 {4 } 4
9 {4 1} 5
10 {4 2 } 6
11 {4 2 1} 7
12 {4 3 } 7
13 {4 3 1} 8
14 {4 3 2 } 9
15 (4 3 2 1} 10
And notice that, by construction, all sums *after* the middle row are equal to 4 plus the corresponding sums *before* the middle row. Therefore, the sums larger than 5 are: - the sums after the middle (rows 9-15) larger than 5, which are as many as the sums before the middle (rows 1-7) that are larger than 5-4 = 1; - plus 1 if the middle row were larger than 5, which it isn't; so nothing added here; - plus the sums before the middle (rows 1-7) which are larger than 5. So we are referring now *only* to the sums in the first rows (1-7). These sums before the middle can be figured out recursively, as they follow the same pattern: Code:
Sum
1 { 1} 1
2 { 2 } 2
3 { 2 1} 3
4 {3 } 3
5 {3 1} 4
6 {3 2 } 5
7 {3 2 1} 6
The final line in the 'compare' function Code:
return compare(n - p, p - 1) + (p > n) + compare(n, p - 1) |
| May2-12, 03:17 PM | #20 |
However those results aren't quite right... should be 2, 7, 19, 47, 108, 236, 501, onward
| May2-12, 03:20 PM | #21 |
| May2-12, 03:26 PM | #22 |
some raw output: http://justpaste.it/yc5
| May2-12, 03:34 PM | #23 |
Ahhh... I was always using {1,2,3,...,N} (with all integers from 1 to N) as my primary set of length N. If you choose an arbitrary set of length N, then the count for N will obviously depend on the particular set, not just on N or on the largest integer in the set.
Edit: Oh, wait, you said in post #6 that the list comes from a specific recurrence sequence. Also, I see now that I have the comparison criterion wrong: a subset is valid if the largest element in the subset (not N, nor the largest in the original set) is smaller than the sum of the others; this renders my subdivision strategy useless. |
| May2-12, 05:01 PM | #24 |
right, the subset,sorry for the confusion
| May2-12, 05:20 PM | #25 |
Hmm, not all is lost. Here is a variation of the program; it produces the output below in under a second, but it will get terribly slower for larger N, it is not linear.
Output: Code:
4 2 5 7 6 19 7 47 8 108 9 236 10 501 11 1045 12 2149 13 4378 14 8869 15 17892 16 35988 17 72254 18 144886 19 290271 20 581207 Code:
#!/usr/bin/python def main(): sequence = [1,2,3] for n in range(4, 21): addOneMore(sequence) print n, count(sequence, n) def addOneMore(sequence): sequence.append(sequence[-1] + sequence[-3]) def count(sequence, n): sum = 0 for largest in range(3, n): sum += compare(sequence, sequence[largest], largest) return sum def compare(sequence, top, p): if top <= 0: return 2**p - 1 if p <= 0: return 0 return compare(sequence, top - sequence[p - 1], p - 1) \ + (sequence[p - 1] > top) \ + compare(sequence, top, p - 1) main() |
| May2-12, 05:39 PM | #26 |
sum-k's fall into an arithmetic progression across N's... but it's not clear how to derive them otherwise
| May2-12, 05:47 PM | #27 |
| May2-12, 05:53 PM | #28 |
say N=5 or [1, 2, 3, 4, 6]
and we count invalid solutions instead: there are X ways to have an inner sum of k: there are 4 ways to have an inner sum of 1 (1, 2) (1, 3) (1, 4) (1, 6) there are 3 ways to have an inner sum of 2 (2, 3) (2, 4) (2, 6) there are 5 ways to have an inner sum of 3 (1, 2, 3) (1, 2, 4) (1, 2, 6) (3, 4) (3, 6) there are 3 ways to have an inner sum of 4 (1, 3, 4) (1, 3, 6) (4, 6) and so forth |
| May4-12, 11:01 AM | #29 |
lots of patterns but they all seem random
| May7-12, 11:37 AM | #30 |
Does anyone have any further thoughts on this problem?
| May18-12, 02:34 AM | #31 |
Recognitions:
This is connected with partition numbers, in particular, restricted partitions: http://en.wikipedia.org/wiki/Partiti...ted_partitions.
Let PD(n) be the number of partitions of n into distinct positive integers. An 'invalid' set in the OP is one in which the largest in the set, Y, exceeds or equals the sum, X, of the rest. For a given X and any N >= Y >= X, there are PD(X) of these. (Except, when Y=X we have to exclude the partition of X as just X, otherwise the invalid set would consist of the same number twice.) So in total there are N.PD(1) - 1 + (N-1).PD(2) - 1 + ... + 1.PD(N) - 1 that are subsets of {1..N}. Check: N = 5: 5.PD(1) + 4.PD(2) + 3.PD(3) + 2.PD(4) + 1.PD(5) - 5 = 5.1 + 4.1 + 3.2 + 2.2 + 1.3 - 5 = 17 But these are only the invalid sets of 2 or more numbers. Any single member set is necessarily invalid, for a total of 22. The number of valid sets = 31 - 22 = 9, which I believe is correct. |
| May18-12, 09:36 AM | #32 |
For starts try to find a formula that will tell you exactly how many subsets of S have totals that are exactly equal to a(n). For any of these subsets, if you add an extra a(i) to it, it will form the basis for one of the subsets you're counting. So for each of these subsets check how many ways you can add to them without creating duplicates. The case of S'=(1,2,3,...,n) is interesting though. |
| May18-12, 10:51 AM | #33 |
Can you provide an example ? Not sure I understand
| May18-12, 03:38 PM | #34 |
Let's take the general case of count(n) so that S={a(1),a(2),a(3),...a(n-3),a(n-2),a(n-1),a(n)}
Now we know the a(i) are positive and increasing, and you should be able to prove it if needed. We also know that a(n)=a(n-1)+a(n-3). But they are increasing so a(n-2)>a(n-3). So it follows that after we add a(n-1) to both we get a(n-1)+a(n-2)>a(n-1)+a(n-3)=a(n). In other words any subset of S that contains both a(n-1) and a(n-2) is one we should count. The other smaller elements can either be present or not present (two possibilities) and there are exactly n-3 of these other elements so there are 2^(n-3) different subsets that go into our count so far (where 2^(n-3) should be read as 2 to the power of (n-3)). Of course that isn't all by a long shot. So far we just have the subsets counted that contain both a(n-1) and a(n-2). Let's stick with a(n-1) and drop a(n-2). Now as we started out noticing a(n)=a(n-1)+a(n-3). So if we take any subset that contains a(n-1) and a(n-3) and at least one more element then we have a subset of S we should count. If the subset contained a(n-2) we would have already counted it in our previous steps, so there are only n-4 other elements that might be present or not. The only possibility we don't want to count is where they all aren't present and just leave us with {a(n-3),a(n-1)} which isn't quite enough and so we have (2^(n-4))-1 additional subsets to count. So far we have count(n)=(2^(n-3))+(2^(n-4))-1+??? Have we counted everything that contains a(n-1)? We've counted everything that contains a(n-1) and either a(n-2) or a(n-3) or both. Are there other combinations that add up greater than a(n-3) (so that when combined with a(n-1) will be greater than a(n))? Why yes there are. You should be able to see there are count(n-3) of them because of the way count is defined. So we now have count(n)=(2^(n-3))+(2^(n-4))-1+count(n-3)+??? with just having counted the Subsets containing a(n-1). Can you take it from there??? |
| New Reply |
| Thread Tools | |
Similar Threads for: Subset problem
| Thread | Forum | Replies | ||
| Set Theory| Proof if A subset B then f(A) subset f(B) | Calculus & Beyond Homework | 5 | ||
| Could someone check this proof?! If c\b subset c\a, then prove a subset b | Calculus & Beyond Homework | 2 | ||
| Another countable dense subset problem | Calculus & Beyond Homework | 2 | ||
| Maximal disjoint subset problem | Programming & Comp Sci | 2 | ||
| subset and proper subset | Set Theory, Logic, Probability, Statistics | 6 | ||
