New Reply
Our weight if the earth spins faster....
Share Thread Thread Tools
May4-12, 10:51 AM   #1
I came up with this problem in a competition. They asked what would be the effect on our weight on the earth if the earth spun any faster.
Thinking deep, I came up to a conclusion that people who live nearer to the equator than to the poles find their weight reduced since any faster spinning of the earth would push us slightly out, due to centrifugal force. Am i right?? would there be anymore effect??
PhysOrg.com
PhysOrg
astronomy news on PhysOrg.com
>> NASA builds unusual testbed for analyzing X-ray navigation technologies
>> Subaru Telescope observations and CoRoT mission unveil future of the Sun
>> Galaxy's Ring of Fire
May4-12, 12:39 PM   #2
Recognitions:
Gold Membership Gold Member
Yes, you would weigh slightly less at the poles than at the equator due to centripetal force. Acceleration due to gravity is reduced by about 0.03 m/s^2. You are also slightly closer to the center of the earth at the poles - also due to the earth's rotation [it causes the earth to bulge a bit]. The net effect is a difference of about 0.05 m/s^2 between the equator and poles - meaning a sumo wrestler who weighs 200 kg at the south pole would weigh a mere 199 kg in Padang, Indonesia.
May4-12, 10:59 PM   #3
Quote by Chronos View Post
But isnt it just the opposite of it? We weigh less at the equator due to 2 reasons: firstly, g varies and secondly due to centrifugal force (inertia) of earths rotation.
May5-12, 12:44 AM   #4
Hey - i think we weigh less at equator
As already mentioned - firstly due to the fictitious centrifugal force and also because earth's a bit more outwards at the equator
May5-12, 12:48 AM   #5
So, the reasoning that the faster spinning of earth would lighten us is correct?
May5-12, 03:06 AM   #6
Recognitions:
A dyslexic moment. Less at the equator, as asserted by the rest of my post.
May5-12, 07:53 PM   #7
So there are two factors involved in making us weigh more at the poles.
1. We are closer to earth's center due to the earth's oblateness
2. There is less centripedal force hurling us outward at the poles.
Excerpt
Taking into account both of the above effects, the gravitational acceleration is 9.78 m/s2 at the equator and 9.83 m/s2 at the poles, so you weigh about 0.5% more at the poles than at the equator.
http://curious.astro.cornell.edu/que...php?number=310
May12-12, 09:48 AM   #8
Thanks.
May12-12, 02:42 PM   #9
Recognitions:
I wonder if the centripetal acceleration actually contributes as much as v2/r? I could see this if Earth were perfectly rigid, and able to hold its spherical shape. But it can't. That's why it bulges. So not only is v2/r happening to a person standing on the equator, but its also happening to the ground they are standing on, negating most or all of the effect.
May14-12, 02:55 AM   #10
Quote by tony873004 View Post
That's quite a stumping reasoning....it can be verified experimentally too..
May14-12, 05:17 AM   #11
It is almost perfectly rigid, else we would have humongous earthquakes.
So it's not perfectly spherical, but it does hold its current shape perfectly.
May14-12, 07:45 AM   #12
Recognitions:
Retired Staff Staff Emeritus
It depends on what you mean.
If we use the formula [itex]\omega^2 r[/itex] for the centripetal acceleration instead, we can look at it this way:
As long as we are considering the Earth as it is, Then the angular velocity stays the same as we move from pole to equator, r increases, and the fact that the Earth bulges at the Equator only has the effect of increasing the maximum value of r. In this case, the formula does give us the full value of the centripetal acceleration. This is because the bulge is not actively changing.
On the other hand, assume you start with a rigid spherical Earth, and then left it "soften" so that it forms an equatorial bulge. As it does so, Its moment of inertia increases, and in order to conserve angular momentum, its angular velocity goes down. The decrease in angular velocity has a larger effect than the increase of radius and the centripetal acceleration at the Equator goes down. But this a comparison made between pre and post bulge formation. It is the change in the bulge that causes the decrease.
As far as I can tell, this discussion deals with the Earth "as is", in which case, the formula holds.
New Reply
Thread Tools
Similar Threads for: Our weight if the earth spins faster....
Thread Forum Replies
Why the engine spins faster when I accelerate? Mechanical Engineering 18
Why the atmosphere spins with the Earth Earth 7
Rotation of earth and weight of an object on the earth Classical Physics 8
Milky Way spins faster, has more mass than thought General Astronomy 5
Does the middle of the Earth spin faster than the outer part? Introductory Physics Homework 1
