New Reply
What causes rotation, a couple or a moment? (conceptual)
Share Thread Thread Tools
May14-12, 07:50 PM   #1
Does a moment have any real (physical) significance or is it just a definition/ an aid to understand and calculate a couple. Is it that the rotation is actually caused by a couple!
I know we can resolve a force causing a moment about a point into a couple and an equal force acting at that point, but what i want to know is how does this actually happen in a real world scenario.
Also,
Say if there was a body (an extended bar or rod) in space so that no force would act on its centre of mass, then if a force F was applied on one of its ends what would happen and why?
forgive me if the question sounds stupid, but this concept has ben bugging me for a very long time now!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
May14-12, 08:18 PM   #2
D H
Mentor
Quote by Sarin View Post
The object would undergo a linear acceleration per [itex]m\vec a=\vec F[/itex] and would undergo a rotational acceleration per [itex]\mathbf I \,\dot{\vec\omega} = \vec r \times \vec F - \vec{\omega}\times (\mathbf I \,\vec{\omega})[/itex] .
May14-12, 11:13 PM   #3
Quote by D H View Post
In words, it's because you apply a force "on" the COM ie. linear acceleration, but a the same time, you apply a torque about the COM ie. rotational acceleration (unless the force is applied directly on the COM, then it's just linear).
May15-12, 01:43 AM   #4
D H
Mentor
Quote by _DJ_british_? View Post
A force doesn't need to be applied directly on the CoM (center of mass) to get pure translation. It just needs to be directed "in line" with the CoM. For example, in the case of a force applied at the end of a rod, there is no torque on the rod if the force is directed toward or away from the center of the rod (i.e., if the force is collinear with the rod).
May15-12, 01:54 AM   #5
Recognitions:
Homework Helper Homework Help
These different views are equally real and produce the same answer. In many cases you can observe the cause of a force producing a moment, so it's natural to view that force as the reality. But in other cases exactly the same result could be produced by a combination of a torque and a linear force.
May15-12, 09:41 AM   #6
DH, DJ british ? and Haruspex, thanks!
lol, and DH i think DJ british meant to say the same thing when he said "directly on the COM", plz dun give him a hard time, haha.
OK i had been pondering over thisthe whole day, looked up some literature and i think i figured it out, one can even deduce this from the derivation of the "position of COM of a system".
Its just that it is very hard to imagine/ visualize the COM taking a translatory path (motion) when the force is not even acting on it/ directed towards it, i.e offset.
Anyways, I have another problem: a free body, say a bar (yet again), spins about the COM; but if we pivot a body at a point, then why does a force act on the pivot point simultaneously as a couple is generated.
I know one may argue since the forces are equal and opposite on the pivot point, they are as good as non existant (they cancel out each other), therefore it is the same thing. I know that!
I wan't to know how it happens in actuality, i.e if you pin a rod at one of it points, how is that point going to be under the influence of a force.
i know again a stupid question, my apologies.
New Reply
Thread Tools
Similar Threads for: What causes rotation, a couple or a moment? (conceptual)
Thread Forum Replies
A couple conceptual Magnetism questions Introductory Physics Homework 2
A couple basic conceptual questions Introductory Physics Homework 5
equivalent force-couple system (conceptual) Introductory Physics Homework 1
moment of a couple Classical Physics 1
A Couple of Conceptual Questions.. Need help Introductory Physics Homework 3
