New Reply
Weird fortran problem (Assigned variable value doesn't match up with output)
Share Thread Thread Tools
May23-12, 03:55 PM   #1
I ran into a kind of strange thing today while coding. I needed Pi in a program, so I used 2*accos(0.0) to pull it out, but my answers were slightly off. I checked the Pi calculated and it was off after a few decimal places.
"Odd", I thought, and just decided to put in Pi as an assigned number. However, this still didn't solve the problem! No matter how I inputted it, it was being altered somehow by the program. I whipped up a really quick program to demonstrate what I'm talking about.
program probs
real(kind=8)::v
v=3.141592653589793238462643
write(*,*)v
end
if you check the output( assuming it's not just my machine or compiler for some reason) you'll see the values for v and the number inputted for it are not the same.
I'm guessing it has something to do with using the kind flag, but I'm not much of a comp sci person, and my searches didn't turn up anything useful.
Anyone have any clue how to fix this? If it is related to kind, how can I keep high precision while avoiding this problem?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May23-12, 10:12 PM   #2
The reason being the value you are assigning is one type and the variable on the left is a different type....if you are going to be declaring variables of different types that the default, you need to assign value of different type than the default; in fact, they should be declared of the exact same type...follow? maybe an example:
Code:
program probs
integer, parameter :: rrr=SELECTED_REAL_KIND(15,307)
real(KIND=rrr) :: v
v=3.141592653589793238462643_rrr
write(*,*)v
end
Here, we first declare a "type"...that's the integer variable rrr.
Then, we declare the variable v of that kind
Then, in order to assign a literal constant to that variable with suffix it with the same "type"...with '_rrr'
Now, test this program and you will see.
May24-12, 06:40 AM   #3
Math 2012
Recognitions:
Or, the "traditional" way is to make sure your constants are double precision.
2*accos(0.0d0)
v=3.141592653589793238462643d0
accos(0.0) will use the single precision version of the function because its argument is single precision, so the result will only be accurate to about 5 decimal places. acos(0.0d0) should be accurate to about 15 places.
May24-12, 08:16 AM   #4
Thanks guys! I was just kind of confused because the output of the variables of real(kind=8) goes to the correct amount of decimal places. I never really thought it through to declare my assigned values as some type, I just assumed it would assign whatever value I placed there the correct type. It's working now tho
New Reply
Thread Tools
Similar Threads for: Weird fortran problem (Assigned variable value doesn't match up with output)
Thread Forum Replies
Dyna result doesn't match Test result Mechanical Engineering 1
Dyna result doesn't match Test result Materials & Chemical Engineering 0
Formatted output problem in Fortran Programming & Comp Sci 2
Susskind's story doesn't match Krauss'? Cosmology 19
