| New Reply |
Supernova shockwave |
Share Thread | Thread Tools |
| May24-12, 06:45 PM | #1 |
Supernova shockwave
I was wondering if a shockwave from a supernova is finite or reacts as energy and dissipates over distance.
The reason I'm asking is because i'm wondering if a supernova could give solarsystems, planets and basically anything with matter a nudge. Then could the objects in space act like a ion drive. Where over millions of years all the supernova's would increase the expanding speed of the original big bang. ps with Ion drive I mean travelling through space with an Ion drive shooting small burst of energy. Since motion is endless in space all these tiny burst end up and in time you would be moving incredibely fast. Why would this not apply to any object and explosion in space? Even if the effect would be unmeasureably small over biljon of years that could add up? |
| May25-12, 05:30 AM | #2 |
The energy is finite. It therefore does dissipate. I'm not clear why you would think it could be any other way.
| May25-12, 06:23 AM | #3 |
Recognitions:
The "shockwave" is important for the supernova remnant itself. If it is asymmetric, it can gain significant velocity. It also affects stars and planets that are very near.
Over larger distances, the effect is unmeasurably small. Sure, it does add up, but so does gravity, which remains overwhelmingly stronger therefore. |
| May26-12, 03:19 AM | #4 |
Supernova shockwaveOnce the shock wave goes into the interstellar medium, it get's hot and dense, but things don't move very much. |
| May26-12, 03:21 AM | #5 |
| May26-12, 02:33 PM | #6 |
Recognitions:
But by "effect" I mean significant propulsion of stars or planets as in the OP, not compression of interstellar gas and such. Gas will sooner or later take all the energy of the shockwave, but solid bodies are (kinematically) not significantly affected except in the rare cases I mentioned. |
| May26-12, 11:11 PM | #7 |
The other thing is that you have thunder and lighting. The shock wave is the thunder since it moves at the speed of sound. The initial burst of radiation is the lightning and that moves at the speed of light. If you are close enough, then radiation pressure from the initial burst will push planets assuming that they don't get vaporized. Also there are a lot of high velocity objects http://en.wikipedia.org/wiki/Stellar...velocity_stars The idea is not that they were pushed by the shock wave, but rather they were orbiting around a star that went supernova and so that when the supernova went boom, they just zipped out of the system. |
| New Reply |
| Thread Tools | |
Similar Threads for: Supernova shockwave
| Thread | Forum | Replies | ||
| Is this a shockwave? | General Physics | 17 | ||
| Shockwave Question | Introductory Physics Homework | 1 | ||
| How do u reproduce a shockwave | General Discussion | 3 | ||
| Plane and shockwave | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Does 1a supernova release the same amount of neutrino as type2 supernova? | Astrophysics | 1 | ||
