Algebraic proofs of trigonometric identities
The discussion revolves around the search for purely algebraic proofs of trigonometric identities, specifically the addition/subtraction theorems such as sin(a+b) = sin(a)cos(b) + sin(b)cos(a). Participants explore various approaches, including geometric interpretations and algebraic manipulations, while debating the definitions and foundations of sine and cosine.
  • One participant proposes a geometric approach using a right triangle to derive the addition theorem, introducing variables for the triangle's sides and angles.
  • Another participant suggests that a drawing could clarify the geometric relationships involved in the proof.
  • Some participants argue that the definitions of sine and cosine affect the possibility of an algebraic proof, particularly if defined through infinite series or differential equations.
  • One participant mentions the Law of Cosines as a potential algebraic proof, while another questions its relevance to the discussion.
  • Euler's formula is presented as a method to derive the identities, though some participants express that it does not fit the criteria of a purely algebraic proof due to its reliance on complex numbers.
  • A participant shares a detailed algebraic manipulation involving coordinates and distances to derive the addition formulas for sine and cosine, emphasizing the use of Pythagorean identities.
  • Another participant discusses the limits and identities related to sine and cosine, indicating a more analytical approach to proving the identities.
Participants do not reach a consensus on the existence of a purely algebraic proof for the addition/subtraction theorems of trigonometry. Multiple competing views and methods are presented, with ongoing debate about the definitions and foundational aspects of trigonometric functions.
Some participants note that their approaches depend on specific definitions of sine and cosine, and there is uncertainty about the applicability of geometric interpretations versus purely algebraic methods. The discussion also highlights the limitations of using certain mathematical tools, such as limits and complex numbers, in the context of algebraic proofs.
KeithLucas
Hello all,
I was wondering if someone has ever found a purely algebraic proof for the addition/subtraction theorems of trigonometry, mainly sin(a+b)=sin(a)cos(b)+sin(b)cos(a). Given a right triangle:
Let x be one of the perpendicular legs and let the other leg be composed of two parts, y1 and y2. Let the line that separates angle a from angle b also be the line that separates y1 from y2 when it intersects with the perpendicular leg. Let a line segment that is perpendicular to the hypotenuse be drawn to intersect with the leg composed of y1 and y2. Call the parts of the hypotenuse on each side of the line z1 and z2 respectively.
Eq1) (z1+z2)^2 = x^2 + (y1+y2)^2
Eq2) x^2 + y1^2 = z1^2 + y2^2 - z2^2
Prove: (y1+y2)/(z1+z2)=(y1z1)/(x^2 + y1^2) + (x(y2^2 - z2^2)^0/5)/(x^2 + y1^2)
1) Any thoughts?
2) Is using latex preferable?
Mathematics news on Phys.org
how about a drawing?
It depends upon how you define sine/cosine.
If you define them using infinite series or differential equations it is impossible to give an "algebraic proof" as you have described. They are no longer the values of a picture or geometric objects, the picture and geometric objects is of the values. If that makes sense.
The Law of Cosines is the algebraic proof...
Euler's formula letrs you prove this using zero geometry
My favorite is the proof based on the Euler relation for the complex exponential,
[itex]e^{it} = cos(t) + i * sin(t)[/itex]
We have
[itex]cos(t_1+t_2) + i * sin(t_1 + t_2)[/itex]
[itex]= e^{i*(t1 + t2)}[/itex]
[itex]= e^{i*t_1} * e^{i*t_2}[/itex]
[itex]= (cos(t_1) + i*sin(t_1)) * (cos(t_2) + i * sin(t_2))[/itex]
[itex]= cos(t_1) * cos(t_2) - sin(t_1) * sin(t_2)<br /> <br /> + i (cos(t_2) * sin(t_1) + cos(t_1) * sin(t_2) )[/itex]
and then equating the real and imaginary parts of the first and last lines gives the addition formulas for cos and sin.
I suppose that's not "algebraic" in the sense that it involves the complex exponential function, but it's still a nice way to derive the formulas.
You beat me to this while I was hacking the LaTeX :-)
We have
The complex exponential function use is fine, but the theorem doesn't fit what I meant by Algebra. By Algebra, I mean, without using limits or geometry other than the pythagorean identities I gave above. Euler's formula is only derived from using limits and differentiation. Maybe I need to draw a picture. How would I post a picture to the forum?
Law of Cosines is {x|-1 ≤ y ≤ +1} ?
c^2 = a^2 + b^2 -2abCos(C)
KeithLucas said:
Hello all,
1) Any thoughts?
You are going to have to be a little more specific.
Where is y1 and y2 respective to the side closer to the right angle?
Which side is x and y1 y2? Is it the larger x or y1 y1? Or are they the same length?
Where is z1 and z2 with respect to y1 and y2?
Is z1 z2 the hypotenuses created from the line perpendicular to the origonal hypotenuse?
The line perpendicular to the large hypotenuse, I'm assuming, should intersect the other perpendicular side (y1, y2) where the two line segments start, is that correct?
Finally which side of the angle are a and b on?
Or you could post a pic! ;)
I've uploaded a picture that's of admittedly very poor quality, but I think it does the job. I'm trying to use the algebraic relationships to demonstrate the trigonometric addition/subtraction theorem.
Click on the thumbnail to view the picture.
Yikes, you may want to re-take that picture :)
I think the following is what you're looking for...
so x1=cosβ; y1=sinβ; x2=cosα; y2=sinα
distance between M1 and M2 is:
d2=(x2-x1)2+(y2-y1)2=(cosα-cosβ)2+(sinα-sinβ)2=cos2α-2cosαcosβ+cos2β+sin2α-2sinαsinβ+sin2β=2-2cosαcosβ-2sinαsinβ
Now let's make a coordinate system Ox'y' rotated ccw at angle β with respect to the original one, Oxy. In this case M1(x1';y1') and M2(x2';y2') have coordinates:
x1'=1; y1'=0; x2'=cos(α-β); y2'=sin(α-β)
this time distance between M1 and M2 is:
d2=(x2'-x1')2+(y2'-y1')2=(cos(α-β)-1)2+(sin(α-β)-0)2=cos2(α-β)-2cos(α-β)+1+sin2(α-β)=2-2cos(α-β)
let's equate the two results
2-2cosαcosβ-2sinαsinβ=2-2cos(α-β)
cos(α-β)=cosαcosβ+sinαsinβ
if we substitute β with -β we get
cos(α-(-β))=cosαcos(-β)+sinαsin(-β) and you hopefully know that cos is an even or w/e it's called function and sin is not, then
cos(α+β)=cosαcosβ-sinαsinβ
if you want the sine version just...
sin(α-β)=cos([itex]\frac{\pi }{2}[/itex]-(α-β))=cos(([itex]\frac{\pi }{2}[/itex]-α)+β)=cos([itex]\frac{\pi }{2}[/itex]-α)cosβ-sin([itex]\frac{\pi }{2}[/itex]-α)sinβ=sinαcosβ-cosαsinβ
and for the last one I will use the same old trick
sin(α-(-β))=sinαcos(-β)-cosαsin(-β)
sin(α+β)=sinαcosβ+cosαsinβ
And with these plus Pythagoras' theorem expressed with trig functions you could easily get tan and cotan and other important trig identities.
Note that I don't take into account angles from quadrants other than the first.
PreliminariesThese can be seen from looking at the diagrams.
[edit]Sine and angle ratio identity
Proof: From the previous inequalities, we have, for small angles
, so
, so
, or
, so
, but
, so
[edit]Cosine and angle ratio identity
Proof:
The limits of those three quantities are 1, 0, and 1/2, so the resultant limit is zero.
[edit]Cosine and square of angle ratio identity
Proof:
As in the preceding proof,
The limits of those three quantities are 1, 1, and 1/2, so the resultant limit is 1/2.
[edit]Proof of Compositions of trig and inverse trig functions
All these functions follow from the Pythagorean trigonometric identity. We can prove for instance the function
Proof:
We start from
Then we divide this equation by
Then use the substitution , also use the Pythagorean trigonometric identity:
Then we use the identity
  • · Replies 20 ·
