| New Reply |
how rear axle turns? (in cars) |
Share Thread | Thread Tools |
| May27-12, 02:15 AM | #1 |
in cars front axle turns by diffrential but how rear axle turns it is possible wite pure rolling?
| May27-12, 02:38 AM | #2 |
You sort of lost me with that question. The rear wheels are turned by a differential, unless you have a front-wheel-drive vehicle. The front ones just free-wheel, unless the brakes are applied. The opposite is true for a FWD thing. |
| May27-12, 03:30 AM | #3 |
when two wheels are rigid to axle ,how axle can turn without slip?
| May27-12, 03:37 AM | #4 |
how rear axle turns? (in cars)Check out the 'how stuff works' article on the same, or build one out of Lego to understand better. http://www.howstuffworks.com/differential.htm |
| May27-12, 03:44 AM | #5 |
in front wheel drive cars ,rear axle havent diffrrential , how it can turn?
| May27-12, 03:58 AM | #6 |
cart havent diffrential but how it can turn in corner?
| May27-12, 04:03 AM | #7 |
welcome persia
on front wheel drive cars, the rear wheels are simply wheels on bearings abd are free to rotate independatly of the drive wheels. They are just along for the ride..savvy? |
| May27-12, 04:07 AM | #8 |
if front axle need diffrential to turn (in corner) then why rear wheels doesnt?
| May27-12, 04:52 AM | #9 |
the front wheels must transmit power to the road..since rear wheels are not connected to engine..no differential is required..only independant bearings
| May27-12, 07:05 AM | #10 |
please explain what force and how cause rear axle turns in corners ??
| May27-12, 11:04 AM | #11 |
![]() This is like talking to a rock, but I'm going to assume that it's an "English as 2nd language" problem. Okay... get yourself a Hot Wheels or Matchbook toy car and check out how the wheels turn. Now imagine a differential on one end of it. That's what we're talking about. Ignore the fact that they don't have steering mechanisms; it's irrelevant here. |
| May27-12, 12:06 PM | #12 |
Front wheel drive vehicles have a differential as part of the transaxle. The rear wheels on a front wheel drive vehicle are not locked the same axle. Each one can free-wheel independent of the other.
- Rear wheel drive vehicles have a differential in the center of the rear axle. The front wheels on a rear wheel drive vehicle are obviously not locked to the same axle. If they were, steering would be impossible. - - There, I tried. |
| New Reply |
| Thread Tools | |
Similar Threads for: how rear axle turns? (in cars)
| Thread | Forum | Replies | ||
| Wheel pivoted about a frictionless axle - moment of inertia, force of axle | Introductory Physics Homework | 0 | ||
| What is a rear shock? | Introductory Physics Homework | 2 | ||
| + or X Rear fins?? | Aerospace Engineering | 5 | ||
| Forget electric cars, what about try to design photonic cars? | General Discussion | 17 | ||
| bad rear axle shocks very common? | General Discussion | 7 | ||
