| New Reply |
Doppler Shift for Sound Waves |
Share Thread | Thread Tools |
| May30-12, 03:18 AM | #1 |
I was considering the following question;
'A fire engine travelling at 70m/s drives past a van travelling at 30m/s. The speed of sound in air is 330m/s and the fire engine has a frequency of 200Hz when stationary. At what frequency does the van driver hear the siren?' I understand you have to use f(prime) = f((v+/-vd)/(v+/-vs)), however I find it quite difficult to decide whether to use the + or - in the calculation, when things are moving relative to one another. An explanation of when to use a + and when to use a - in each of the numerator/denominator would be most helpful. The answer is 180Hz. Thanks. |
| May30-12, 04:39 AM | #2 |
Mentor
I would write the formula this way:
[tex]f' = f\frac{v + v_d}{v - v_s}[/tex] All you have to remember is that when either source or detector moves towards the other, the observed frequency must increase thus the sign for that speed must be positive (in my version of the formula). In this problem is the source (fire engine) moving towards (+) or away (-) from the detector? Is the detector (van) moving towards or away from the source? Use that as your guide to get the proper signs. |
| May30-12, 05:18 AM | #3 |
Thanks for your explanation.
I was just wondering if at first the van is in front of the fire engine and the fire engine is approaching it from behind (the fire engine is moving faster than the van as stated in q) then the apparent frequency detected by the van would be greater, right? Then the fire engine overtakes the van and the apparent freq decreases? How does this fit into the eqn? Also, the answer for this question has a plus everywhere ie v+vd and v+vs. Many thanks. |
| May30-12, 06:03 AM | #4 |
Mentor
Doppler Shift for Sound WavesHint: Treat the motion of the detector (in the numerator) and the source (in the denominator) as separate effects which are combined by the formula. |
| May30-12, 08:28 AM | #5 |
Thanks, I have the first case settled. If we consider the situation that the source is always behind the detector, then the source moves toward the detector thus we have v+vd. The detector is always moving away from the source and so this acts to decrease apparent f. v+/-vs is in the denominator and so to make this smaller we use v+vs, as needed.
Then I considered a second case. The source has overtaken the detector and is always in front of the detector. The source therefore moves away from the detector,acting to decrease f, and so we have v-vd. The detector moves towards the source, increasing f and giving v-vs on the denominator(to divide by something smaller). I think there should be an error in this second argument because this would give an apparant freq of 230Hz. Since the source moves quicker than the detector, we should expect a decrease in freq, yes? Lastly, when answering this question how were we supposed to know whether to consider the source behind the detector or in front to get the specific freq asked for in the q? Thanks again. |
| May30-12, 09:31 AM | #6 |
Mentor
You should expect a decrease in frequency when the fire engine overtakes the van and that's just what you get. |
| May30-12, 09:42 AM | #7 |
I just reliased I had confused the two cases immediately after I had left the last post.
Everything is now clear for me. Thanks a lot! |
| New Reply |
| Thread Tools | |
Similar Threads for: Doppler Shift for Sound Waves
| Thread | Forum | Replies | ||
| sound waves and the doppler effect | Introductory Physics Homework | 2 | ||
| Doppler effect for Sound waves (clarified) | Classical Physics | 0 | ||
| Would Gravity Waves Show Doppler Shift? | Special & General Relativity | 10 | ||
| Doppler shift above speed of sound. | Introductory Physics Homework | 2 | ||
| Doppler shift and red/blue shift | General Astronomy | 4 | ||
