Redshift and Expansion of the Universe
The discussion centers around the concept of redshift and its implications for the expansion of the universe, particularly in relation to dark energy and the "tired light" hypothesis. Participants explore the mechanisms behind redshift, including the Doppler effect and the effects of an expanding universe, while questioning the nature of light's behavior in a vacuum.
  • Some participants assert that the universe is expanding based on observed redshift of light from distant galaxies, which they relate to the Doppler effect.
  • Others argue that light does not redshift simply due to traveling through a vacuum, stating that this would violate conservation of energy.
  • The "tired light" theory is mentioned as a discredited idea that proposed light redshifts naturally over distance, which some participants challenge.
  • There is a distinction made between Doppler redshift and redshift due to the expansion of the universe, with some participants emphasizing that they are not the same phenomenon.
  • Questions arise regarding the nature of motion and reference frames, with discussions about how relative motion affects the perception of redshift.
  • Some participants express confusion about the implications of motion through space and how it relates to observed redshift, seeking clarification on these concepts.
Participants do not reach a consensus; there are multiple competing views regarding the mechanisms of redshift and the implications for the expansion of the universe. The discussion remains unresolved on several points, particularly regarding the validity of the "tired light" hypothesis and the interpretation of redshift in different contexts.
Some limitations are noted, such as the dependence on definitions of motion and reference frames, and the complexity of distinguishing between different types of redshift. There are unresolved questions about the nature of light in a vacuum and the implications of quantum mechanics on these discussions.
This discussion may be of interest to those studying cosmology, astrophysics, or anyone curious about the nature of light and the expansion of the universe.
MattRob
So, IIRC, the big deal about dark energy is that the universe appears to be expanding.
How do we know the universe is expanding?
As far as I know (and that's not much), we know because of redshifting of light on the spectrum as it moves away, as per the Doppler effect, which has been observed in distant galaxies and stars.
If I'm not mistaken, then, the single bit of evidence we have for the expansion of the universe, is that one physical phenomenon. But, what if light redshifts as it travels?
Would naturally redshifting light as it travels through a vacuum violate any known laws or observations, and would it explain the mysterious apparent acceleration of the expansion of the universe?
Astronomy news on Phys.org
There is no physics to have light red shift in a vacuum. Also it would violate conservation of energy. Finally there is plenty of evidence that it doesn't happen.
The so-called "tired light" theory was roundly discredited years ago.
Ah, alright, those responses were just the thing I was looking for. It was just kinda a thought that was bothering me, thanks for the replies.
Mathman - can you explain this for me?
Are you saying here that light does not redshift as it moves through space?
Cheers
Cheers
Classically, light acts as a wave so due to it's wave like nature it travels at different speeds in different density mediums.Vacuum and space are different things altogether.
P.S: Space is not a perfect vacuum due to various reasons...btw. can anyone clarify for me the following point: Quantum oscillators have a ZPE state , how about a perfect vacuum (which probably doesn't exist) ?
Cheers
Yes, he is saying that light does not just redshift in and of itself when traveling through unperturbed space. That's the "tired light" hypothesis that was discredited years ago.
It DOES get redshifted as it travels through expanding space, but that was not what the OP was asking about. He was espousing "tired light"
MattRob said:
... we know because of redshifting of light on the spectrum as it moves away, as per the Doppler effect, which has been observed in distant galaxies and stars.
You are confusing doppler redshift with the redshift caused by expanding distances. They are not the same, although I found that a bit hard to get my head around when I first encountered it. Doppler shift happens when two objects are moving relative to each other in the same frame of reference. The expanding universe means they don't have the same frame of reference, so the effect is not a doppler shift. This is not just semantics, because saying that the red shift is due to a doppler effect is the same as saying that the universe it not expanding.
Cheers all.
I can kind of see the complexity here :)
Are all the following statements true (just for my benefit)
The wavelength of the light emitted from a star is "set" at the stars surface as the photons escape. Its wavelength is caused by the motion of a star in a certain direction. At the "front" of the star (in the direction the star is moving), the wavelength will be shorter than that created at the rear of the star (in the direction from where the star came).
As we orbit the Sun, we observe different wavelengths from it at different times of the year, because the Sun has motion through space in a direction.
Is all this true?
Cheers
What matters is its motion through space relative to us, since it doesn't have motion through space. Neither do we, neither does that little green man in a spaceship traveling at .9c relative to us. A star's light can't be said to be redshifted; it can be said to be redshifted with respect to this observer. So when our component of velocity towards the sun is positive, we see a very tiny negligible blueshift, and when our component of velocity towards the sun is negative, we see a very tiny negligible redshift. It's distant galaxies that matter. The distance between us and any arbitrary distant galaxy appears to be increasing, and if you do the math, an observer on that distant galaxy would be in the exact same situation we are, with the same amount of redshift for galaxies the same distance away from them.
We have more evidence for the BBT than just redshift, we also have the Cosmic Microwave Background Radiation, and General Relativity alone would be enough to suggest a Big Bang.
"since it doesn't have motion through space"
I am afraid I don't understand that.
As I learn - I try to create images in my head if that's ok.
So in terms of your reply - for which I am grateful, how does this sound?
I am flying through space away from a star, I observe a redshift in the light it is emitting. This is because the wavelength appears to be "stretching".
If that's correct - why is this?
"Change of wavelength because of motion of the source."
definitely NOTHING to do with the motion of the observer?
If we knew the wavelength of light from a motionless source, then we would have a baseline I suppose.
It has nothing to do with two nonexistent values. It has to do with the relative motion between the source and the observer.
Can ANYTHING EVER be stationary?
In special relativity, a source and observer can be in the same inertial reference frame.
Can you just give me a quick example which explains in laymans terms "frame of reference"?
See the post
George Jones said:
I think that some care is needed; it seems that you're describing the Doppler effect, although I could be wrong. In reality, the phrase "a moving clock runs slow" does not necessarily mean "a moving clock is seen visually to run slow." A clock moving directly away from an observer appears visually to run slow, but a clock moving directly towards an observer appears visually to run fast. In both cases, what is seen visually is given by the Doppler expression, which is always different than the time dilation expression. In both cases, the time dilation expression, used appropriately, does apply.
Consider the following example.
Assume that Alice is moving with constant speed directly towards Ted. When Ted uses his telescope to watch Alice's wristwatch, he sees her watch running at a faster rate than his watch. Ted sees Alice's moving watch running fast, not slow! Ted sees this because of the Doppler shift. Because Alice moves towards Ted, the light that Ted sees from her watch is Doppler-shifted to a higher frequency. But the rate at which a clock or watch runs is like frequency, i.e., a second-hand revolves at a certain frequency, and all frequencies are Doppler-Shifted., so ted see Alice's wristwatch running fast.
To explain what "A moving clock runs slow." means, I first have to explain how Ted (with help from Bob) establishes his frame of reference.
Starting from Ted, a series of metre sticks, all at rest with respect to Ted, are laid end-to-end by Bob along the straight line joining Alice and Ted. At each joint between two consecutive metre sticks, Bob places a small clock. The metre sticks and clocks all are at rest with respect to Ted. Initially, none of the clocks are running; before turning them on, the clocks have to be synchronized. To do this, Ted directs a laser pointer along the line joining Ted and Alice, and then sends a flash of light. Each clock is turned on when the flash of light reaches it. The speed of light is not infinite, so the time taken for the light to travel from Ted to each clock has to be taken into account. To do this, the clocks' hands are set initially as follows. The clock one metre away from Ted is set to the time taken for light to travel one metre; the clock two metres away from the tower is set to the time taken for light to travel two metres; ... .
This whole setup of metre sticks and clocks establishes Ted's reference frame.
Now, As Alice moves toward Ted, Ted uses his telescope to watch Alice's wristwatch, and to watch his clocks. First, he watches one of the distant clocks in his reference frame. The time he sees on the clock is the time at which the light he sees set out from the clock, so Ted sees an earlier time on the distant clock than he sees on his wristwatch. Because the clock is stationary in his frame, Ted does, however, see the distant clock running at the same rate as his watch. Similarly, Ted's sees all the clocks in his frame running at the same rate as his watch.
As Alice approaches Ted, she whizzes by clock after clock of Ted's reference frame. Using his telescope, Ted sees that Alice is beside a particular clock, and he notes the time on her watch and the time on the clock adjacent to her. Some time later, Ted sees Alice beside a different clock, and he again notes the time on her watch and the time on the clock adjacent to her.
Ted checks his notes, and he finds that the time that elapsed on Alice's watch as she moved between these two clocks of his frame is less than the difference of the readings of the two clocks. This what is meant by "A moving clock runs slow."
Unfortunately, "time dilation" in general relativity and "time dilation" in special relativity often have different operational meanings. Suppose observer A hovers at a large distance from a Schwarzschild black hole, and that observer B hovers near the event horizon. If observer A uses a telescope to observe B's watch, A will see B's watch running more slowly than his own watch. In this context, gravitational time dilation is something that is seen visually.
Sorry double post I didnt see that reply.
No, both Newtonian/Galilean and Special Relativity quite clearly state that what you just asked means nothing. If you had asked if anything could be stationary with respect to a certain (inertial) reference frame, then the answer would be yes.
Read this. It's an excellence source for understanding Special relativity for those who don't wish indulge into the detailed mathematics , covers bit of a historical background.
One of the postulates of Einstein's theory is that no reference frame is superior to another , in other words we can't subject a particular reference frame as absolute.
EDIT: OH sorry about that : http://www.thebigview.com/spacetime/relativity.html
It's alright for the general readers , however, at the end the article gave me an impression of dealing with meta-physics..
This is EXACTLY the kind of thing I hate so much about trying to learn something.
From the link above...
""Relativity teaches us the connection between the different descriptions of one and the same reality."
This view of Relativity, that there are different realities,"
Look at the state of that drivel. E says "one and the same reality" - the author of the article then spews forth with "there are different realities"
Its no wonder its hard to learn with authors like that. Why can't people learn HOW to teach before they attempt to start teaching.
You see my problem now?
Are there multiple realities? or is there one reality?
Its a joke. What is actually happening when I read something like that is my brain is diving off in all directions making my brain cells form incorrect pathways and connections which results - I hate to discover - in my ultimate demise - a bottomless pit of meaningless irrelevant questions.
This comes from using English, or any other every-day human language, to describe things that are best described with math.
I'd say his "multiple realities" is an English language conceit whereby what I see is reality for me and what you see is reality for you. As for the physical event, only one thing happened, so in that sense there is only one reality.
I agree wholeheartedly. I would have written (infact E says it perfectly clearly) - but anyway - I would have said...
"This view of Relativity, that there are different perceptions of the same reality."
Oh dear god - I just had a thought - what if General Relativity means different things for different observers. Oh - I just had another thought - it does!
Eeeeek
Relational Quantum Mechanics (an interpretation of Quantum Mechanics) takes that to a whole new level. Just prepare yourself for different observers observing different things.
You seem to be arguing over semantics . I don't see any conflict with that particular statement.Author was highlighting towards the phenomena of SR, if we measure a string of wire in a moving refrence frame in comparison to a stationary one then its length would appear shorter to the observer in the moving R.F ... so you see both the stationary and moving are observers are right in concluding different lengths of the same wire , call it A.
The inclusion of gamma factor brings this phenomena of ' length contraction'.
Given by: L= [itex]L_{0}/\sqrt{1-v^2/c^2}[/itex]
Is there a way to discern between the two redshift effects without preconceived knowledge of the radiation's state of motion? Or is most of the redshifting that we see simply assumed to be from the cosmic expansion?
I am not aware of any way to tell the difference. As to relative contributions, I had always thought that it was almost entirely due to expansion, but I was told by someone on this forum that it is about 50/50. I have no idea if that is right but it seems to me to be absolutely wrong.
  • · Replies 23 ·
