New Reply
Classification of stars by spectrum
Share Thread Thread Tools
Jun7-12, 04:36 PM   #1
This topic is quite confusing.. In the first place, how can we classify for example all O class stars would be having the same spectrum with the same absorbtion lines... Secondly, i just need a clarification on what do these absorbtion line reprsent and upon that how can we decide whether a star is in it main sequence or not.. Whoever dominates, i am thankful to him!
PhysOrg.com
PhysOrg
astronomy news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> Detection of the cosmic gamma ray horizon: Measures all the light in the universe since the Big Bang
>> Scientists work out way to use pulsars to provide self navigation to spacecraft in solar system
Jun8-12, 03:48 PM   #2
Quote by ehabmozart View Post
The basic thought behind stellar classifications is that all stars start out as hydrogen, and that the major difference between types is the mass of the star. As a star ages, it advances in stages through burning hydrogen, helium, carbon, and heavier elements. As this happens, the spectrum of the star changes, and it becomes brighter, advancing up the Main Sequence.
The absorption lines represent chemical elements in the star's atmosphere. You can also tell a star's temperature by looking at the overall spectrum curve and applying the Stefan-Boltzmann law. When you do that, it's clear that generally the brightest stars are also the hottest. If you plot a large number of stars on a chart with brightness on one axis and temperature on the other, most stars will fall on a line called the Main Sequence. A chart like that is called a Hertzprung-Russell diagram.
The classification of stars is by temperature (which you can always determine) rather than brightness (which can be tricky). So for example, all G1 stars are the same temperature (actually, same temperature range), regardless of their brightness or whether they're on the Main Sequence or not.
New Reply
Thread Tools
Similar Threads for: Classification of stars by spectrum
Thread Forum Replies
Spectrum of Stars General Astronomy 2
spectrum of stars Astrophysics 7
how to draw laser signal power spectrum from it's phase noise spectrum(dBc/Hz) Electrical Engineering 0
Relation between spectrum in algebraic geometry and spectrum in functional analysis Linear & Abstract Algebra 0
Stars spectrum questions General Astronomy 3
