| New Reply |
fortran on ubuntu using f95 code help |
Share Thread | Thread Tools |
| Jun13-12, 10:08 AM | #1 |
I have the following code with error- I want this general flow. Errors I get are missing ')' at the do while line,
syntax error on the line started with ****(not part of program added after fact) and expecting END Program statement at line end do counter=1 user_reaction =3 do while (counter .le. 3 .and. user_reaction .ne. 1 .and. user_reaction .ne. 2) counter= counter+1 print *, "What reaction would like to look at:" print *, "1)GP to EP" print *, "2)GP to Klo" if (counter.eq. 3) then **** print *, "Please type a '1' for reaction GP to EP" & "and '2' for the reaction GP to Klo" end if read *, user_reaction end do if (user_reaction .ne. 1 .and. user_reaction .ne. 2) print *, "Failed to get a valid result. Program terminates in error." STOP end if |
| Jun13-12, 10:49 AM | #2 |
Code:
program bkent
implicit none
integer :: counter, user_reaction
counter=1
user_reaction =3
do while ((counter .le. 3) .and. (user_reaction .ne. 1) .and. &
(user_reaction .ne. 2))
counter = counter + 1
print *, "Please type a 1 for reaction GP to EP", &
"and 2 for the reaction GP to Klo"
end if
end do
if ((user_reaction .ne. 1) .and. (user_reaction .ne. 2)) then
STOP
end if
stop
return
end program bkent
| Jun13-12, 12:50 PM | #3 |
still seeing an error. something else must be off. here is the whole (non commented out) program. I am compiling using the command f95 -o extract extract_file.f
program extract_file C this program is designed to obtain data from the two files for my two reactions C user input variables integer user_reaction double precision user_energy, user_binWidth integer counter c values obtained from data files are stored in these variables integer num_data_at_mmtm integer r real momentum_val integer gpep, gpklo, SGTi, DSGi real min_energy(2) character headerline*50, obs*3 !there is a headerline that I don't want ! obs=observable for given data C file names and creation character directory*24 character*9 subdirectory(2) character*10 filename(2) directory = '/home/usersname/Desktop/' !usersname entered later on--> temp line subdirectory(1) = 'GP to EP' subdirectory(2) = 'GP to KLo' filename(1) = 'gpep072211' filename(2) = 'gpkl060311' c open (unit=gpep,file=filename(1),blank='null') c open (unit=gpklo,file=filename(2),blank='null') c open (unit=SGTi,file=gpep_SGT,status='new') c open (unit=DSGi,file=gpep_DSG,status='new') C this section pertains to user selected reaction type to analyze counter=1 user_reaction =3 do while ((counter .le. 3) .and. (user_reaction .ne. 1) .and. & (user_reaction .ne. 2)) counter = counter + 1 print *, "What reaction would like to look at:" print *, "1)GP to EP" print *, "2)GP to Klo" if (counter.eq. 3) then print *, "Please type a 1 for reaction GP to EP", & "and 2 for the reaction GP to Klo" end if read *, user_reaction end do if ((user_reaction .ne. 1) .and. (user_reaction .ne. 2)) then print *, "Failed to get a valid result. Program terminates in error." STOP end if stop return end program extract_file |
| Jun13-12, 01:20 PM | #4 |
Try gfortran. Also, why you get the missing ) error is because fortran code can only be 71 or 81 (I can't remember) column spaces long. You need to do a continuation.
| Jun16-12, 09:57 PM | #5 |
Works perfectly OK (compiles without any errors) in gfortran on Ubuntu 12.04.
| New Reply |
| Tags |
| f95, fortran, ubuntu |
| Thread Tools | |
Similar Threads for: fortran on ubuntu using f95 code help
| Thread | Forum | Replies | ||
| fortran code | Engineering, Comp Sci, & Technology Homework | 1 | ||
| [ubuntu] Can't boot into anything after installing Ubuntu on Windows 7 | Computers | 2 | ||
| Error compiling in Fortran (Ubuntu) | Programming & Comp Sci | 2 | ||
| Problem with Fortran g77 code | Programming & Comp Sci | 4 | ||
| Convert latex code to fortran code? | Math & Science Software | 1 | ||
