New Reply
should the rear wheel be larger
Share Thread
Jun20-12, 04:29 AM   #1
Generally all cars have equal sized wheels but few like batmobile (the tumbler from dark knight) have larger rear wheel. What is the advantage of larger rear wheel.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Jun20-12, 04:47 AM   #2
In the case of a drag racer you want your rear wheels to have the maximum possible surface area touching the ground.
[The more surface area, the less force per unit area. The less force per unit area the softer the compound you can use. The softer the compound you use, the stickier you can make it]
On the other hand if you are building a dragster, you want your front wheels to have low aerodynamic drag and to be as light as possible.
In the case of a Batmobile, the overriding motivation is almost certainly to look cool and to give an impression of "there must be some physical principle that they're taking advantage of".
Jun20-12, 05:04 AM   #3
If the rear wheels are larger, then you're always rolling downhill and don't need any power! ;)
Jun20-12, 05:15 AM   #4
Quote by phyzguy View Post
Didn't really get you! Do you mean that a car with larger rear wheel will start moving on its own!
Jun20-12, 05:17 AM   #5
Quote by jbriggs444 View Post
can't get you. I am unfamiliar to many words you are saying. It will b a great help if you please explain yourself.
Jun20-12, 06:15 AM   #6
I guess that's why those high wheelers came out of style. Going uphill all the time was annoying.
Jun20-12, 06:38 AM   #7
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by ashishsinghal View Post
It was a joke.
Jun20-12, 08:53 AM   #8
Recognitions:
Why not?
Gimee one good reason. haha
Jun20-12, 11:25 AM   #9
Math 2012
Recognitions:
An obvious DISadvantage is that you need two spare wheels and two spare tires. But I guess Batman has some special powers to fix that problem
Jun20-12, 12:12 PM   #10
Recognitions:
Homework Helper Homework Help
Some rear wheel drive sport cars (Corvette Z06, Ford GT, Viper), and almost all street motorcycles (rear wheel drive) have larger rear tires. Part of the reason could the rear tire is providing force to overcome drag when ever the vehicle is moving, so it's a wear issue. Otherwise the forces are related to acceleration and braking.
Formula 1 rules regulate tire size and front tire is smaller. The possible factors include aerodynamic drag since it's an open wheel car and more slippage at the rear tires in racing conditions, plus the constant force on the rears to overcome drag.
f1 wheels and tires .htm
On the other hand, Lemans Prototype race cars have large front tires and they appear to be about the same size as the rear tires. Audi's R18 e-tron quattro is a diesel + electric hybrid, and uses electric motors at the front for all wheel drive.
wiki audi r18 e-tron quattro.htm
Jun20-12, 05:29 PM   #11
Weight distribution is also a factor. In a street car you want the front and rear tyres to stick equally.
New Reply
Similar discussions for: should the rear wheel be larger
Thread Forum Replies
Rear-wheel steered vehicles Mechanical Engineering 20
Rear Wheel Torque Equations Mechanical Engineering 4
Monorail problem with coefficient of fiction and front and rear wheel drive Introductory Physics Homework 13
Friction and the difference between rear-wheel, front-wheel and four-wheel Engineering, Comp Sci, & Technology Homework 3
Proving that larger side corresponds to larger angle Precalculus Mathematics Homework 9
