PeterDonis
Mentor
- 50,141
- 26,172
Ben Niehoff said:There is nothing wrong with "Minkowski space with a point removed, and flat metric" as a mathematical object, and yes, it is a solution to Einstein's equations, because Einsteins equations are local.
I can certainly see that, at every point except the one that was "removed", the flat metric will solve the EFE. But...
Ben Niehoff said:The base topology is "R^4 with a point removed", and the metric tensor is the obvious one.
By "R^4 with a point removed", do you mean S^3 x R? That's a different topological space, even at your level 1.
Ben Niehoff said:The feature this psuedo-Riemannian manifold is missing is that it is not "complete"; i.e., there are geodesics that leave the manifold at finite affine parameter (i.e., geodesics of finite length that leave the manifold).
Yes, agreed. This is why I said the removed point acts like a singularity.
Ben Niehoff said:One may consider the "maximal extension" of this manifold, which is where you follow all the geodesics to infinite length, and fill the rest of the manifold in by analytic continuation. The result is that the missing point will be put back, giving standard Minkowski space.
I understand how this would work regarding the metric, since the manifold starts out flat, so there's zero curvature along all of the incomplete geodesics, and therefore completing them as you say doesn't involve any curvature singularities. However, it does change the underlying topological space, from S^3 x R to R^4. In other words, analytic continuation can change the underlying topological space. Is that correct?
Ben Niehoff said:Kruskal coordinates are an example of a coordinate chart that covers the total Schwarzschild spacetime; in the RN and Kerr cases, one still needs multiple coordinate charts.
I thought the Penrose diagrams even for R-N and Kerr could cover the entire maximal extension with a single chart. You just have to let the timelike coordinate have infinite range instead of finite. (Actually, the Penrose chart I'm used to thinking about for Kerr only covers the equatorial plane, so that one may be a bad example.)
