| New Reply |
2 slit experiment, what happen with 3,4,5...? |
Share Thread | Thread Tools |
| Jun25-12, 05:11 AM | #1 |
it's all in the question, but i'll elaborate
the scientists shot one photon each time and discover it moves through both slits, i wanna know, does the photon "divide" to countless particles or just 2? do the scientists tried the experiment with more than 2 slits? thanks
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun25-12, 05:48 AM | #2 |
I don't think "divide" would be the proper word, but, thinking along similar lines, it will take countless paths given countless slits. You just have to keep on adding the amplitudes for any number of slits and as the number of slits approaches infinity you get Feynman's path integral! I strongly recommend you to go through three or four pages of "QFT in a Nutshell" by Anthony Zee, starting from page 7 onwards, that is, the first few pages of Chapter I.2. You will get the first couple of those few pages for free here:
http://www.amazon.com/Quantum-Field-...der_0691010196 |
| Jun25-12, 07:00 AM | #3 |
This doesn't just happen for 'slits'. It happens for everything that light (in fact, all EM waves) bounces off or passes through; the phenomenon, in general, is called Diffraction and two slit interference is just the simplest example. A single photon will end up being detected at just one point in space. One way of looking at this is to say it has been spread 'everywhere' that the classical wave model would have put the wave but that it only turns up in one place. The result of a large number of photons is precisely what the classical wave model would predict. This is the 'duality' idea at work and you have to take both ideas on board at once. You can't just choose one or the other.
| Jun25-12, 07:27 AM | #4 |
Recognitions:
2 slit experiment, what happen with 3,4,5...?Our brains have no experience with observing the behavior of fundamental particles. You need to get used to the fact that every analogy we come up with to model these particles is flawed in some way. So we end up saying things like what you read above. It's the best we can do to picture what is going on. Mathematics, however, allows us to be precise and when we mathematically predict the outcome of even complicated arrangements, we find that our understanding is supported by solid, repeatable, and durable evidence. |
| Jun25-12, 08:06 AM | #5 |
Recognitions:
Going to multiple slits is then fairly trivial- even the limit where the number of slits goes to infinity and the slit width and spacing go to zero. |
| Jun25-12, 08:41 AM | #6 |
2. specific the quote: but "wave" is a term from macro world. and math applied on models we create, after imagining them in our minds we can wrap it with math, no?! |
| Jun25-12, 08:44 AM | #7 |
Mentor
http://hyperphysics.phy-astr.gsu.edu...t/mulslid.html I don't think the QM treatment and conceptual problems with single photons are any different in these cases than with two slits. |
| Jun25-12, 11:29 AM | #8 |
A so-called diffraction grating uses many slits and the pattern it produces has very wide spaced maxima and each 'order' spreads out the light into the spectrum of wavelengths. Then there is the hologram - again, it's a diffraction pattern of an object and this time the object is in three dimensions. |
| New Reply |
| Tags |
| meni is king, particle, slits experiment |
| Thread Tools | |
Similar Threads for: 2 slit experiment, what happen with 3,4,5...?
| Thread | Forum | Replies | ||
| 2-Slit Experiment: Interference dissapears when detecting which slit the photon took? | Quantum Physics | 5 | ||
| What would happen in this double slit experiment? | Quantum Physics | 3 | ||
| Young's double slit experiment (shallow slit and deep slit) | General Physics | 4 | ||
| Dual slit experiment: closing/opening a slit after the particle passes it . . . | Quantum Physics | 1 | ||
| double-slit experiment when screen distance is of same magnitude of slit separation | General Physics | 4 | ||
