| New Reply |
Common assumption in proof for Inverse function theorem |
Share Thread | Thread Tools |
| May25-12, 11:51 AM | #1 |
I don't understand why all authors of this proof assume that Df_a = id_n, how doesn't this destroy generality?
For example, see http://www.physicsforums.com/showthread.php?t=476508. The λ in his post (and the post he quotes) is always Df_a (its not stated in that post, but in the book and the post that is quoted in that post). It doesn't seem like the answer is ever made. My attempt at an answer: I FEEL like the assumption is valid because its only a computation and therefore doesn't change the "structure" of the problem itself (i.e. the spaces are preserved). But it at first glance does seem like a pretty big leap in a proof. The same (or similar) argument is made in every proof i've seen : Spivak, and MIT's opencourse http://ocw.mit.edu/courses/mathemati...s/lecture7.pdf (i.e. Df(0) = id), also the proof given in Jerry Shurman's "Multivariable Calculus", the online book. This is a fairly simple question, could I have a simple answer? |
| May25-12, 02:09 PM | #2 |
Let f map from Rn to Rn. And suppose Df is non-singular at point a. Let Df(a) be denoted by the matrix A which, again, is nonsingular.
Okay, now let g = A^(-1)f. This is a mapping from Rn to Rn, and Dg(a) = I. Okay, suppose we manage to prove that g is locally invertible. That is g^(-1)(y) exists locally near g(a). Well f = Ag is the composition of two invertible mappings, so its inverse must exist and equal (Ag)^-1 = g^-1 A^-1. |
| May25-12, 02:25 PM | #3 |
Please try to answer the question that was asked,and not just restate the assumption without explanation. |
| May25-12, 02:57 PM | #4 |
| May25-12, 03:13 PM | #5 |
Then s/he goes on to prove IF A is invertible (assumed) and g is invertible then f^-1 = g^-1 A^-1. This DOES NOT prove that A = Id. It merely gives a value for the inverse of f given the composition of invertible functions, unless I'm severely misunderstanding.... I don't think I am, perhaps you could elaborate on why its correct (assuming it is). |
| May25-12, 03:24 PM | #6 |
| May26-12, 09:41 AM | #7 |
Just to rephrase. (We make up f, define g, and let professor's proof apply to g, showing f invertible)
Let A=Df, invertible. We define g=A-1f. Then Dg=D(A-1f)=A-1Df=I. Thus, since Dg=I, instructor says g-1 exists. Since f=Ag, it is not hard to show that g-1A-1 is the coveted f-1 we are searching for. |
| May29-12, 03:59 PM | #8 |
Okay, perhaps a simple example will clear up the logic. Let f(x) be a real valued function of 1 real variable (R into R). You want to know whether f(x) is locally invertible near x=a and you know that f'(a) = m is not zero.
According to your professor/textbook, this is known to be true IF you make the additional assumption that m=1. Well now, we have the function f(x) whose derivative is equal to m which is not zero, but not necessarily 1 either. Let g (x) = (1/m)f(x). Its derivative at a is equal to (1/m)f'(a)=m/m=1. So according to the textbook, g(x) is locally invertible with inverse g^(-1). Lets see if we can invert f. So we have the equation y=f(x)=mg(x), and we want to solve for x in terms of y. Solving, we see that y/m = g(x), and we know that g is invertible so, x = g^(-1)(y/m). Therefore, f^(-1)(y) exists and equals g^(-1)(y/m). This is exactly the same device that is used for mappings Rn to Rn, but perhaps, being easier to visualize, it is easier to see how the logic works here. |
| May29-12, 04:06 PM | #9 |
I will just add that the inverse function theorem in spirit is saying the following.
For x near a, we want to know whether we can solve the equations y=f(x) for x in terms of y. According to the definition of the derivative: y= f(a) + Df_a(x-a) + o(|x-a|) In other words, the Df_a is the closest linear approximation of our mapping (in a neighborhood of a). The inverse function theorem says that as long as Df_a is invertible, then locally you can solve the equation for y in terms of x and you get: x-a = (Df_a)^(-1)(y-f(a)) + o(|y-f(a)|) . |
| May29-12, 06:19 PM | #10 |
Recognitions:
you seem confused by the use of variables. the best statement of the principle behind the proof would have been that, if we can prove the theorem for all functions with derivative equal to the identity, then we can also prove it for all functions with invertible derivative. I.e. you are confused by what letter is being employed to represent the function, f or g.
| Jul9-12, 07:39 AM | #11 |
| Jul9-12, 02:00 PM | #12 |
If you have a function f with invertible derivative, there is g such that g(f(x))=x. and g'(f(a))f'(a)=id_n. Now prove the statement for g(f(x)). Then it will be true for f also, somehow. This is the basic idea, I didn't read the attached proof recently (this is from May). |
| Jul9-12, 04:05 PM | #13 |
Recognitions:
Suppose the inverse function theorem were true for a composition of maps,
f[itex]\circ[/itex]L where L is a non-singular linear map. Would it be true for f? |
| Jul9-12, 05:13 PM | #14 |
| Jul9-12, 08:12 PM | #15 |
Recognitions:
| Jul9-12, 09:28 PM | #16 |
Can someone explain the determinant of the derivative in the neighbourhood of a is also nonzero when derivative at a is the identity map?
I found related sentence in wikipedia ''if the Jacobian determinant at p is positive, then F preserves orientation near p; if it is negative, F reverses orientation.'' But I don't know the reason for that. Any thoughts? |
| Jul10-12, 07:36 AM | #17 |
Recognitions:
Since the determinant is a polynomial this means the determinant of the Jacobian is a continuous function. The determinant of the identity equals 1. |
| New Reply |
| Thread Tools | |
Similar Threads for: Common assumption in proof for Inverse function theorem
| Thread | Forum | Replies | ||
| Spivak Inverse Function Theorem Proof | Calculus | 3 | ||
| Inverse function theorem proof | Calculus | 1 | ||
| Inverse function Theorem | Calculus & Beyond Homework | 3 | ||
| Inverse Function Theorem | Calculus & Beyond Homework | 0 | ||
| Inverse Function Theorem | Calculus & Beyond Homework | 4 | ||
