New Reply
Metric of a static, spherically symmetric spacetime
Share Thread Thread Tools
Jul10-12, 12:48 AM   #1
The (0,0) and (r,r) components are: [itex]g_{00}= -e^{2\phi}[/itex],[itex]g_{rr}=e^{2\Lambda}[/itex]. From the first component, combined with the fact that the dot product of the four velocity vector with itself is -1, one can find in the MCRF, [itex]U^0=e^{-\phi}[/itex]. What does this mean? In the MCRF, the rate of the two clocks is the same, hence in Minkowski spacetime, U0=1. Here, in this case, it isn't so.
From the (r,r) component, one can deduce that if dt=dθ=d[itex]\phi[/itex] =0, i.e the proper radial distance is dl=[itex]e^\Lambda[/itex]dr. Again, what does this mean? In Minkowski space, the proper distance betwenn r2 and r1 is r2-r1.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jul10-12, 04:31 AM   #2
Mentor
It means that Schwarzschild coorinate time is not equal to proper time and that Schwarzschild r coordinate is not equal to proper distance.
Jul10-12, 07:17 AM   #3
So the coordinate time is the time measured at infinity and time measured at radius r is [itex]e^\phi t[/itex] which is always less than t. Is that correct? Don't understand the significance of [itex]\Lambda[/itex] though. Why would the radial coordinate be anything other than the proper radial distance?
Jul10-12, 07:39 AM   #4
Quote by vin300 View Post
The Schwarzschild r coordinate is defined as circumference of a circle centered on the star divided by 2π. Because space is not Euclidean, this is not the same as the radius of the circle (proper radial distance).
Jul11-12, 05:33 AM   #5
I understand why a circle drawn on a non Euclidean surface like a sphere has a circumference lesser than 2πr but a circle centered on the centre of the star lies in a Euclidean plane.
Jul11-12, 06:06 AM   #6
The space enclosed by the circle is non Euclidean. This is quantified by the difference between the proper radial distance and the radial Schwarzschild coordinate. Look at:
http://en.wikipedia.org/wiki/Schwarz...27s_paraboloid
Here the exterior and interior spatial Schwarzschild geometry combined:
From: http://de.wikipedia.org/wiki/Schwarz...ld-L.C3.B6sung
Jul13-12, 07:38 AM   #7
I see how the surface θ=π/2, t=constant should have been a flat plane in flat spacetime but it's a paraboloid in Schwarzschild spacetime. What happens at r=rs? Flamm's paraboloid only depicts the non-Euclidean equatorial plane. Is there nothing that can be done to show the curvature of all such planes(entire space)?
Jul13-12, 03:04 PM   #8
Mentor
It is hard to draw a 4D curved Lorentzian manifold on a 2D Euclidean flat display device.
Jul13-12, 05:42 PM   #9
Recognitions:
Gold Membership Gold Member
I'm not sure whether you have grasped the point that the diagrams in post #6 represent the geometry of a 2D slice of 3D space around a black hole (Flamm's paraboloid) or a star/planet (the yellow diagram). If you were near the planet you would perceive the "slice" as a flat plane, but if you measured the geometry of the plane using rulers and protractors, you find the geometry was as if you were on the illustrated curved surface embedded in Euclidean 3D space. In these diagrams, the vertical dimension doesn't represent any direction in 3D space: it's an extra "fictitious" dimension we add to the diagram to illustrate the curvature within the 2D surface.
As DaleSpam says, you'd need (at least) a 4D diagram to show the curvature of 3D space.
The other point is that you can't extend the paraboloid inside the event horizon because we are looking at space from the point of view of an observer who is at rest relative to the black hole. No such observers can exist on or inside the horizon.
Jul14-12, 12:23 AM   #10
Quote by DrGreg View Post
If the curvature can be represented only with the aid of an additional fictitious dimension, how could it be measured using rulers and protractors?
Thanks. I had been thinking of it as a real dimension.
Why does the paraboloid shown on wiki have an open end? It should be closed like the one in post #6.
Jul14-12, 07:34 AM   #11
Mentor
I don't understand the relationship you think exists between the dimensionality of a quantity and the devices used to measure it. Suppose you had a quantity which required 6 rulers and 4 protractors to measure at each point in space. How would you plot that quantity?
The one on wiki shows only the exterior Schwarzschild curvature, and the diagram of the exterior solution falls apart at a certain radius. The one here shows the exterior and the interior solution.
Jul14-12, 08:10 AM   #12
Recognitions:
One example: Pick three points (not all lying on the same line). Because three points determines a plane, these three points will necessarily all lie in the same plane. Connect the three points with straight lines to form a triangle. Now use your protractor to measure the three internal angles of the triangle. Do they add up to 180 degrees? If not, you've just measured curvature, even though there's no way of representing (that is, drawing a picture of) the curvature without adding an additional fictitious dimension. But that representation is just an aid to visualizing the curvature; it's not needed to measure it, nor to work with it mathematically.
Another example appears further up in this thread: You have a circle, you measure its circumference with your ruler, then you measure its diameter. If the diameter isn't equal to the circumference divided by ∏... you've measured curvature.
Jul14-12, 10:19 AM   #13
Recognitions:
I thought I had answered that:
New Reply
Thread Tools
Similar Threads for: Metric of a static, spherically symmetric spacetime
Thread Forum Replies
Transformation to get a Lorentzian spherically symmetric metric to the Sylvester form Differential Geometry 2
spherically symmetric metric form Special & General Relativity 14
Metric outside a spherically symmetric source. Special & General Relativity 11
spherically symmetric metric in isotropic coordinates ??? Special & General Relativity 0
Static spherically symmetric perfect fluid solutions Special & General Relativity 0
