| New Reply |
Where did all the Earths water come from? |
Share Thread | Thread Tools |
| Jul17-11, 02:11 AM | #18 |
Per here: http://en.wikipedia.org/wiki/Atmosphere_of_Earth
The amount of Hydrogen in the atmosphere averages out to be 0.55 ppm by volume. That is an extremely low amount at 0.000055%. |
| Jul17-11, 03:04 AM | #19 |
The higher altitude clouds, are really high up there. Maybe the Sprites lightning which in all honesty is rather amazing, creates just a little mist and it hovers right around where the cone forms at around 90km to 100km? Watching the video of the sprites, and I know it is bad measure to assume what is happening based on what my eyes are seeing, but it almost looks like a charge forms at the 100KM mark first, where the hydrogen is condensed, heated to a temperature exceeding it's bounding altitudes, then strikes down 80KM to the surface of the troposphere. What are the chances that it is carrying, and fusing hydrogen on it's way down, throwing water on the clouds? It almost looks like it is thrusting material down when it strikes too. |
| Jul17-11, 03:27 AM | #20 |
Fusing hydrogen? Pretty much not happening. Lightning doesn't reach anywhere near enough of a temperature for that to happen. I don't know why you keep insisting that this lightning is creating water. It is not. It is only transferring current from one area to another, not whole molecules.
| Jul17-11, 03:56 AM | #21 |
The wiki claims that atmospheric lightning can fuse silica into glass. "temperatures approaching 30,000 °C (54,000 °F), hot enough to fuse silica sand into glass" http://en.wikipedia.org/wiki/Lightning That is bolt lightning though, not sprite lightning. Sprite lighting is said to be much cooler, so perhaps you are right. http://en.wikipedia.org/wiki/Sprite_%28lightning%29 I am just sort of questioning it, mainly because they might be associated with gamma ray bursts or anti matter signatures. Which I really have no idea what the circumstances or requirements are to make. My guess though, considering they might be associated with galactic explosions, is that to create them it might require a lot of heat. It's nothing counter intuitive, this line of thinking, is it? So if the current is following the path of least resistance, and that path is different everytime, I would guess that after lightning strikes the path it follows makes it less conductive and more resistant to another possible lightning strike, correct? Maybe the re-ignition of the Sprite is an indication that it is following a different type of path? Perhaps it is following a path which is chemically conductive? perhaps nitrogen is a better conducing agent rather than oxygen? [EDIT] Okay... so what if the atmosphere is so thin where these sprites are occurring that heat cannot generate in a traditional sense, and it has to escape by another means? Is that a possibility? Would that explain why there is such a large amount of energy, enough to create Gamma ray flashes, or anti-matter signatures. Perhaps the radically different environment explains whey they could exist without causing a loud thunder clap? I have seen physics demonstrations that represent heat as molecules exciting and basically bumping around into each other more frantically. Perhaps the atmosphere is not dense enough to do this where the sprite occurs? If that is the case, would the lack of atmosphere or "heat" prevent any sort of fusion happening? Or maybe it is the perfect environment for "cold fusion"? I know that was a big science issue a while back, that's why I use the word "cold fusion" lightly. |
| Jul17-11, 06:37 AM | #22 |
| Jul17-11, 06:54 AM | #23 |
I'm not particle physicist, but I thought fusion was a technical term for the particles surrounding the nucleus of an atom to bond with another. Or to split from it's parent molecule creating new type of material. I am not really fluent with all that stuff, it sort of eludes me once the whole plum pudding model is proven to be wrong. I just don't understand how they figure the weak and strong nuclear forces or what not, and for that matter, I just have no real concept of the difference between a chemical bond and nuclear fission or fusion. They are both chemical reactions the way I see it.
I am asking to learn. Not to magically make something happen that otherwise would not be happening. I am not a magician. In any event. How do Red Sprites create anti-matter signatures? I thought anti-matter was an indirect observation of matter production. Gamma Rays being the result of two atoms colliding and forming matter, like fusion. The only thing I know about Gamma Rays and how they are produced is from reading about pair production... which is a form of intense energy forming matter. Maybe the scale of thinking on that is wrong, maybe that is sub-atomic, when really the only requirement is some sort of chemical requirement? See? Pair production, Gamma Rays - http://en.wikipedia.org/wiki/Gamma-ray_generation On the list is fusion too... so I am just wondering why lightning produces them as well... maybe I have concepts mixed up... I really don't know... |
| Jul17-11, 07:18 AM | #24 |
| Jul17-11, 07:37 AM | #25 |
I am reading the wiki... that's how I'm learning, that and forum threads help sort things through... and I do appreciate you helping.
So... This was mentioned in the thread already which I think is interesting. "University of Florida lightning expert Dr. Martin Uman says, "Observers of thunderstorms, from antiquity to the present, have noted that a heavy gush of rain often reaches ground a minute or two after a lightning flash and its accompanying thunder." He explains that questions about the relationship between lightning, thunder and rain gushes were finally resolved in the 1960s, when radar observations of precipitation in clouds before and after lightning confirmed that, in some cases, a gush followed the flash. Researchers postulate that cloud droplets near a lightning channel and its many branches acquire such intense charge that they repel each other, flying outward and colliding with non-charged drops, thereby growing large and falling as a rain gush." http://blog.chicagoweathercenter.com...in-follow.html (There are papers on it too, but that is clearer) So this seems probable in the sense that perhaps lightning causes rain droplets to charge and bounce into each other. However, wouldn't this basically mean that during every lightning flash, we should expect a gush of rain to follow? I mean during the downpour, once a flash occurs that would charge the rain causing it to drop faster? And during periods of non-lightning, and non-thunder the rain would be a lighter downpour. It should be predictable to one degree or another, in rhythm for a lack of a better term, correct? |
| Jul17-11, 06:25 PM | #26 |
I have no idea. I have never noticed anything like this myself, nor have I ever heard of it until now.
| Jul26-11, 07:07 PM | #27 |
I think water was around long before the Earth, at least according to this Time article on black holes.
It seems the Universe is predisposed to create water whenever H2 and O2 meet, at least if they meet with the relatively slight amount of energy required for combustion. |
| Jul26-11, 08:17 PM | #28 |
| Jul26-11, 08:30 PM | #29 |
| Jul27-11, 05:29 AM | #30 |
| Jul27-11, 08:26 AM | #31 |
Yes all the oxygen and hydrogen were around pre-Earth, but that doesn't necessarily mean it was all in the form of water yet. Got it. One thing the OP should consider is that water is a very common substance in the universe, partly because its components are common and partly because those components have a huge affinity for each other (one of the strongest on the periodic table) which means they need little energy to combine (one of the reasons we use them for rocket fuel). |
| Jul16-12, 12:38 PM | #32 |
http://www.sciencedaily.com/releases...0712144743.htm
Some new info I found on Science Daily. Hope this is helpful. |
| Apr13-13, 07:13 AM | #33 |
Looks like the Swiss have invented technology which uses lasers to create rain with the available molecules in the sky.
http://inhabitat.com/swiss-team-crea...-into-the-sky/ Anyways... here is another article claiming red sprites have this much energy... And another article claiming the energy amount in the lasers used to create rain clouds... http://inhabitat.com/shooting-laser-...e-rain-clouds/ |
| New Reply |
| Thread Tools | |
Similar Threads for: Where did all the Earths water come from?
| Thread | Forum | Replies | ||
| any more earths??? | Earth | 24 | ||
| what if there other earths out there? | General Discussion | 13 | ||
| How many Earths would fit into the Sun? | Introductory Physics Homework | 1 | ||
| Mass of Earths water (simply) | Introductory Physics Homework | 1 | ||
| CO2 in Earths Crust | Earth | 3 | ||
