| New Reply |
Write a Java program to convert binary numbers to decimal numbers. |
Share Thread | Thread Tools |
| Jul18-12, 09:10 AM | #1 |
Use a loop to read (charAt()) each digit (0/1 char) in the input string, scanning from right to left;
Use the loop to build the required powers of 2; Use a conditional statement to deal with 0 and 1 separately; Debug using simple input, e.g. 1, 10, 101, and print intermediate values in the loop. Use your program to find the decimal value of the following binary number: 1001010101011010111001011101010101010101 I have got as far as this: import java.lang.*; import java.io.*; public class BinaryToDecimal{ public static void main(String[] args) throws IOException{ BufferedReader bf= new BufferedReader(new InputStreamReader(System.in)); System.out.print("Enter the Binary value: "); String str = bf.readLine(); long num = Long.parseLong(str); long rem; while(num > 0){ rem = num % 10; num = num / 10; if(rem != 0 && rem != 1){ System.out.println("This is not a binary number."); System.out.println("Please try once again."); System.exit(0); } } int i= Integer.parseInt(str,2); System.out.println("Decimal:="+ i); } } But when I compile and run it only says "Enter the Binary value:" Help! :/ |
| Jul18-12, 09:23 AM | #2 |
Mentor
When you post code, put a [code] tag at the top and a [/code] tag at the bottom. This preserves your indentation, if any, and makes your code easier to read. I have done this below.
Since you didn't do much indentation, I have done so. |
| Jul18-12, 09:27 AM | #3 |
Thank you so much
Im new to this so I dont know how to use it much :S No, I couldnt enter the Binary Number because im using netbeans How is it possible to enter the number? Do i just type it in next to "Enter Binary Number" ? |
| New Reply |
| Tags |
| binary, conversion, decimal, java, loop |
| Thread Tools | |
Similar Threads for: Write a Java program to convert binary numbers to decimal numbers.
| Thread | Forum | Replies | ||
| Convert decimal to binary/octal/hex in assembly? | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Convert decimal base to binary | Engineering, Comp Sci, & Technology Homework | 6 | ||
| How do I convert signed decimal to binary | Engineering, Comp Sci, & Technology Homework | 7 | ||
| C program (string - binary to decimal conversion) | Engineering, Comp Sci, & Technology Homework | 4 | ||
| binary to decimal confusion!!! signed numbers! | Engineering, Comp Sci, & Technology Homework | 1 | ||
