New Reply
A conflicting result of Euler's formula
Share Thread Thread Tools
Jul20-12, 09:31 AM   #1
It can be shown from Euler's formula that
[tex] \left(-1\right)^x = \cos(\pi x) + i\sin(\pi x) [/tex]
However, consider [itex] x = 2/3 [/itex]. The left expression gives
[tex] \left(-1\right)^\frac{2}{3} = \left(\left(-1\right)^2\right)^\frac{1}{3} = \left(1\right)^\frac{1}{3} = 1 [/tex]
while the right expression gives
[tex] \cos\left(\frac{2\pi}{3}\right) + i\sin\left(\frac{2\pi}{3}\right) = -\frac{1}{2} + \frac{\sqrt{3}}{2}i [/tex]
What has gone wrong here? Thanks all.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jul20-12, 09:55 AM   #2
because you have not done it in general.
(-1)^x=cos(n*pi*x)+isin(n*pi*x) where n is odd integer.now put x=2/3 and n=3.
you get it equal to 1.also check out that -1 has three cube roots so just check out that that complex number is arising because of other roots.
Jul20-12, 09:55 AM   #3
Quote by Undoubtedly0 View Post
Complexpowers, roots don't behave as real ones. Read about multivaluate complex functions...or wait until the appropiate course at university.
DonAntonio
Jul20-12, 10:10 AM   #4
Quote by andrien View Post
How does one derive [itex] (-1)^x=\cos(n\pi x)+i\sin(n\pi x) [/itex]?
To derive [itex] (-1)^x=\cos(\pi x)+i\sin(\pi x) [/itex] I simply used
[tex] \ln\left((-1)^x)\right)=x\ln(-1)=x\pi i [/tex]
therefore [itex] (-1)^x = e^{x\pi i} = \cos(\pi x)+i\sin(\pi x) [/itex].
Where did I miss the general case? Thanks again.
Jul20-12, 10:13 AM   #5
can't you just verify that -1 is equal to exp(i*n*pi) when n is odd.
Jul20-12, 10:15 AM   #6
The equation, (-1)^x=cos(pi*x)+i*sin(pi*x) is derived from Euler's identity based on the assumption that 'x' is an integer. Hence substituting fractional value for 'x' in the equation will lead to erroneous results. The derivation is as follows,
e^(i*y)=cos(y)+i*sin(y).....(Original Euler's identity)
Now replacing 'y' with 'pi*x', you will end up with
e^(i*pi*x)=cos(pi*x)+i*sin(pi*x)......(1)
Assuming that 'x' is an integer, cos(pi*x)=(-1)^x and sin(pi*x)=0.
substituting them in (1)
e^(i*pi*x)=(-1)^x.......(2)
substituting (2) in (1), you will end up with (-1)^x=cos(pi*x)+i*sin(pi*x) for x is an integer.
New Reply
Thread Tools
Similar Threads for: A conflicting result of Euler's formula
Thread Forum Replies
Center of gravity - conflicting result Introductory Physics Homework 34
Odd result from an eigenvalue problem in the Euler equations Differential Equations 0
Prove Euler Identity without using Euler Formula General Math 36
Algebraic Manipulation of Euler's Identity Leads to a Strange Result General Math 3
Euler: Please verify my result ! Calculus & Beyond Homework 0
