Wing and wind turbine blade aerodynamic center?
The discussion focuses on modeling wind turbine blades in SolidWorks, specifically addressing the scaling of airfoil coordinates (x/c, y/c) based on the calculated chord length. It is established that the aerodynamic center (AC) for each section of the blade will shift when scaling from the leading edge, as the 2D AC does not remain constant in 3D. To accurately determine the 3D aerodynamic center, recalculation or estimation using Computational Fluid Dynamics (CFD) is necessary.
  • SolidWorks for 3D modeling
  • Understanding of aerodynamic centers in airfoil design
  • Knowledge of scaling techniques in CAD software
  • Familiarity with Computational Fluid Dynamics (CFD) principles
  • Learn how to recalculate the 3D aerodynamic center for wind turbine blades
  • Explore SolidWorks features for airfoil modeling and scaling
  • Study Computational Fluid Dynamics (CFD) applications in aerodynamic analysis
  • Research best practices for wind turbine blade design and optimization
Engineers and designers involved in wind turbine blade design, aerodynamicists, and anyone interested in advanced modeling techniques in SolidWorks.
mezah
Hello everyone,
Now i am trying to model wind turbine blade using solidworks.
I have the airfoil coordinates at each section of the blade, but the coordinates are distance per chord (x/c,y/c) so i have to scale it using the calculated chord.
When i scale it with respect to the origin - which is at the leading edge - the position of the aerodynamic center for each section is changed with respect to others.
Is the aerodynamic center should be along the same line??
Is this correct or should i do it another way?
Thanks in advance.
http://img713.imageshack.us/img713/6729/71671216.jpg
Well this has to be the case since the aerodynamic center you were given is the 2D aerodynamic center. The blade's true 3D aerodynamic center will change and will be along a new constant chord. You will have to recalculate the 3D AC or estimate it using CFD.
