 Quote by Chestermiller
But according to the definition I gave in my OP, I would not consider these objects as denizens of my own frame of reference; they would be residents of other reference frames. I know that this is not as broad a definition as the one that you are comfortable with, but it is also simpler to understand, and should not lead to any errors in SR analyses. In your opinion, is that correct?
What is your criterion for something being "in your frame of reference"? Is it only objects that are at rest relative to you? That seems like a very restrictive definition, which basically makes the concept of "frame of reference" useless, as ghwellsjr pointed out earlier. But alternatively, if objects that are moving relative to you can still be in your frame of reference, why can't *all* objects be in it?
As far as how the time direction is established to make the coordinate system 4D, you're probably not going to like what I have to say. I like to imagine the time direction as an actual spatial direction, orthogonal to the 3 spatial directions of my coordinate system (in SR). I like to consider the dot product of the coordinate basis vector in the time direction with itself to be -1, so that the Minkowski metric is automatically established.
Assuming that you also consider the dot products of spacelike basis vectors with themselves to be +1, this is all just standard SR; you don't need to "consider" it, you can just use it.
The term "spatial direction" applied to the time direction might raise some eyebrows, but as soon as you clarify the dot products, you are admitting that the time direction is different from the space directions.
(I realize that, in order for the time direction to truly be considered a bona fide spatial direction, the metric would have to be positive definite, but this small difference doesn't bother me too much).
If the word "spatial" is just to help you imagine things more easily, there's no problem. The only problem would be if you tried to infer from the word "spatial" that the time direction had properties that it doesn't actually have (like a positive dot product with itself), or that it didn't have properties that it actually does have; but it doesn't appear that you've done that.
I also like to imagine that my frame of reference is moving with the speed of light into the time direction that is assigned to my specific frame of reference.
If "moving with the speed of light into the time direction" is just another way of saying that your 4-velocity has length c (or 1 in the "natural" units usually used in relativity, where c = 1), then this is OK. But see further comments below.
In this way, my frame of reference sweeps out all of 4D space-time, at least the part into my future.
Why just into your future? You can extend everything you've said into your past as easily as into your future.
I realize that this description is, to say the least, not very acceptable to mainstream physicists.
It's not the description itself that causes problems; it's that a lot of people who see this description can't resist the temptation to draw wrong inferences from it. For example, every time a Brian Greene special airs on TV, we get a spate of threads here asking about things like the reference frame of a photon, whether everything "moves at c through spacetime", including photons, whether time dilation means you're moving "more through space and less through time", etc., etc. Then we have to spend a lot of time clearing away all the misconceptions that have arisen from the type of description you're talking about.
Ultimately, the "descriptions" don't matter; what matters is the physics--the actual predictions we make and whether or not they match experimental results. My personal view is that many of these "descriptions" are no help (at least not to me) in actually making the predictions, so I don't think they're worth spending a lot of time on; I'd rather concentrate on ways of organizing the material that *do* help me in making predictions. But your mileage may vary.
I feel that it has significant appeal, and should not lead to any trouble in solving problems related to SR.
If it helps you in generating predictions, and the predictions are correct, then yes, it should not lead to any trouble.
