The Big Bang: Radiation Era and Hydrogen Fusing to Helium
  • Context: Graduate
  • Thread starter Thread starter g.lemaitre
    Radiation
The discussion revolves around the conditions of the early Universe during the Big Bang, specifically focusing on the radiation era and the processes of hydrogen fusing into helium. Participants explore the implications of a radiation-dominated versus a matter-dominated Universe on fusion rates and the resulting elemental abundances.
  • Some participants reference Peebles' summary, suggesting that if the early Universe had not been dominated by radiation, all superdense hydrogen would have fused into helium.
  • One participant notes that at extremely high temperatures (around 10^30 to 10^35 K), nuclear fusion is hindered due to radiation overpowering nuclear attraction, preventing fusion from occurring.
  • Another participant speculates that in a matter-dominated Universe, the cooling rate would be slower, allowing for a longer period during which fusion could occur, compared to a radiation-dominated Universe where rapid cooling would limit fusion time.
  • A participant discusses the concept of the "deuterium bottleneck," explaining that at certain temperatures, deuterium cannot form due to being broken apart, which affects helium formation.
  • Technical details are provided regarding the scaling of energy density and temperature in relation to expansion, with some participants attempting to calculate specific temperatures at given times post-Big Bang.
  • One participant introduces an external reference to Tamara Davis' work, questioning whether energy loss in an expanding Universe applies similarly to matter as it does to radiation.
  • Another participant discusses the energy:matter ratio at high temperatures, suggesting that a higher ratio would lead to more fusion, contrasting it with the actual lower ratio observed in the Universe.
Participants express differing views on the implications of radiation versus matter domination on fusion processes, with no consensus reached on the specifics of these conditions or their outcomes.
Participants acknowledge limitations in their calculations and assumptions regarding the energy:matter ratio and the conditions of the early Universe, indicating that these factors significantly influence the discussion.
g.lemaitre
This is from Harland's the Big Bang:
Peebles presented a summary of his results in a seminar at Johns Hopkins University in Baltimore, saying: (a) if the early Universe had not been dominated by the radiation of a fireball, all of the superdense hydrogen would have been fused into helium; (b) the helium abundance was a measure of the energy density at the time that the fireball ceased to be dominated by radiation: and (c) the ‘relic’ of this field should be visible as an isotropic background.@
Regarding the words in bold, why is that the case that if the early Universe had not been dominated by the radiation of a fireball, all of the superdense hydrogen would have been fused into helium?
Space news on Phys.org
At temperatures of say 100 miliion degress Kelvin, Fusion [thermonuclear] occurs...like hyrdogen combining into helium in some stellar objects...
But the big bang temperatures were on the order of 1030 or 1035, anyway, a LOT more decimal places, a LOT hotter, and so nuclear attraction could not overcome the exhorbitant heat to fuse neclei...that is, radiation blasted stuff apart.
I'm trying to find Peeble's original paper, but I'm guessing that in a matter dominated universe, the universe cools less quickly in response to expansion, which leaves the universe hot enough to fuse all of the protons to helium. In a radiation-dominated universe, the temperature goes down very quickly, and so it freezes the proton/neutron ratio.
This is a guess, and I've been trying to do scaling numbers and I haven't been able to get them to work.
g.lemaitre said:
... why is that the case that if the early Universe had not been dominated by the radiation of a fireball, all of the superdense hydrogen would have been fused into helium?
George, I think Twofish's guess is right. Radiation cools faster than matter, in an expanding volume.
So in an expanding world that is mostly radiation, cooling is quick and there is only a brief window of time when helium can be fused.
But in an expanding world that is mostly matter particles, cooling takes longer (requires more expansion) --- perhaps with a longer window there would be a danger that all the H would be fused into He. Bummer!
A partial explanation for the quicker cooling goes like this: with matter particles if you double the scale the volume goes up by 8, so the density goes down to 1/8.
(same number of particles, just in 8 times bigger volume)
But with photons of light, not only are they spread out by the expansion but they are also REDSHIFTED, SO EACH PHOTON HAS ONLY HALF THE ENERGY. So doubling the scale cuts the density of energy down to 1/16 what it was. There are only 1/8 as many photons per unit volume and each one is only worth half as much energy.
When people estimate the amount of expansion (and cooling) after one second, two seconds, etc. they get that the temperature was only right for making helium between 3 and 20 minutes. So there was only a 17 minute window.
See if you can get this toy to work. It's not perfect by a long shot but it does seem to convert from seconds of expansion time into what temperature it was. Just type 180 into the seconds box (leave the power of ten box blank) and then click anywhere else on the spreadsheet.
http://hyperphysics.phy-astr.gsu.edu/hbase/astro/expand.html#c3
It is a spreadsheet relating time to temperature. Put in 180 seconds and see if you can get the temperature. It should come out around 1.4 billion Kelvin.
Hotter (i.e. earlier) than that, a necessary intermediate product (deuterium) would not stay together, so helium could not form. The deuterium would keep getting knocked apart. This is called "the deuterium bottleneck".
Then put in 20 minutes, i.e. 1200 seconds and see if you can get the temperature. It should come out around 0.5 billion Kelvin. Colder (i.e. later) than that helium would not form because the deuteriums weren't being banged together hard enough to make them fuse together.
"Radiation domination" is just a technical codeword for how much cooling to expect from a given amount of expansion. You have to know whether to expect energy density to go down to 1/8 or to 1/16 when you double the distance scale.
It's nearly 1 AM here. Maybe I'll say this better tomorrow, or someone else will. Got to sleep now.
Interesting... I think Tamara Davis may disagree...what do you think:
Is the Universe Leaking Energy?
Tamara Davis
http://www.physics.uq.edu.au/downloa...iAm_Energy.pdf
Photons traveling in an expanding universe appear to lose energy via cosmological redshift. What about matter: You find that the de Broglie wavelength of particles increases by exactly the same proportion as a photon’s wavelength does! Thus light and matter seem to behave in exactly the same way.
can't stay back tomorrow...
must we consider particle momentum slows to Hubble flow expansion rate??
For both radiation and matter solutions of ρ(t), with curvature = 0, ρ [itex]\propto[/itex] 1/t2 (although the radiation value of ρ is 9/8 of ρ for a matter-only solution). For radiation, a [itex]\propto[/itex] t1/2, whereas for matter only, a [itex]\propto[/itex] t2/3. For both solutions, the temperature scales as 1/a. Therefore it's easy to run the numbers, although you need to plug in a matter:energy ratio at a selected time.
Assume there was lots of matter (as ionized hydrogen) compared to energy at a time when T= 109 K. At this temp (kT~100 keV), the maximum possible energy:matter ratio would have been ~ 10,000:1 because the proton and electron thermal energy would have radiated photons, and the particles also had thermal energy. In the real universe, the matter:energy ratio at the time when T = 109 K was more like 1:105. This is much lower matter density than the hypothetical high ratio of 10,000:1. The high ratio (matter-dominated) solution would therefore yield much more fusion, because the hydrogen density would have been much higher at the time the temperature passed a billion K.
  • · Replies 28 ·
9K
9K
