| New Reply |
Proper Acceleration and Christoffel Symbols |
Share Thread | Thread Tools |
| Aug2-12, 11:23 PM | #1 |
I don't know exactly what I'm looking for in this question so I'll ask it in a vague way. What is the connection between a particle's proper acceleration and the christoffel symbol of the second kind (single contravariant and double covariant) ? Is this correct?
[itex]\frac{∂^2x^\alpha}{∂\tau^2}=-\Gamma^\alpha{}{}_\beta\gamma\frac{∂x^\beta}{∂\tau}\frac{∂x^\gamma}{∂\t au}[/itex] What are the physical meanings behind these quantities? |
| Aug3-12, 12:29 AM | #2 |
Do you understand what the Christoffel symbols mean in general?
You're trying to get toward the geodesic equation. Christoffel symbols arise in general from trying to take derivatives of vectors. A coordinate-free version can be written like this: [tex](v \cdot D) v = 0[/tex] In other words, the covariant derivative of the four-velocity along the direction of the four-velocity is zero. This encapsulates the basic idea behind there being no acceleration. When this equation is expanded out in coordinates, you get [tex](v \cdot D) v = v^i \partial_i v^j + v^i \Gamma_{ik}^j v^k[/tex] The [itex]v^i \partial_i v^j[/itex] term is identified as [itex]d^2 x/d\tau^2[/itex], in direct analogy to the flat space case. The connection is involved because of the use of the covariant derivative instead of the ordinary vector derivative, and in general because we can replace derivatives with respect to [itex]\tau[/itex] with an appropriate directional derivative in spacetime. |
| Aug3-12, 01:42 PM | #3 |
Sorry, I have to disagree with the notation being used here. A partial derivative ∂μ or ∂/∂xμ, or also a covariant derivative, can be applied only to a field. That is, to a quantity which is a function of all four coordinates and which is defined everywhere, at least in a certain region of spacetime, and therefore we can meaningfully speak of its having partial derivatives in all four directions.
But when we talk about the properties of a particle: velocity, acceleration, etc, we refer to properties that are defined only along a single curve. For example the 4-velocity vμ(s) is a function of a single parameter, usually the proper time, or in the case of a null curve an affine parameter. In this situation you cannot write ∂vμ/∂xν, and without that you can't write vν∂vμ/∂xν either. The distinction is vital. What you can write is an ordinary derivative d/ds along the curve. The covariant generalization of the ordinary derivative is called the absolute derivative, written δ/δs. The relationship between the two involves Christoffel symbols, similar to the relationship between the covariant and partial derivatives of a field. For example for covariant and contravariant vectors, δWμ/δs = dWμ/ds + ΓμνσWνvσ δWμ/δs = dWμ/ds - ΓνμσWνvσ In these terms, particle dynamics becomes quite simple. E.g. the 4-acceleration is simply aμ = δvμ/δs |
| Aug3-12, 01:49 PM | #4 |
[tex]
\frac{∂^2x^\alpha}{∂\tau^2}=-\Gamma^\alpha{}{}_\beta\gamma\frac{∂x^\beta}{∂\tau }\frac{∂x^\gamma}{∂\tau}[/tex] This is called the geodesic equation. If it is satisfied then the worldline [itex]x(\tau)[/itex] has no proper acceleration. The proper acceleration is given by ∇σuμuσ, where ∇σuμ is the covariant derivative, which uses the Christoffel symbols. uμ is [itex]\frac{∂x^\mu}{∂\tau}[/itex] |
| Aug3-12, 01:58 PM | #5 |
| Aug3-12, 02:27 PM | #6 |
It may not make sense to talk about a velocity field for a single particle, but a single particle is just a limiting case of a general matter distribution (single particle -> a delta distribution), is it not? In that light, I think it's reasonable to consider [itex]v \equiv v(x(\tau))[/itex], and the chain rule would apply.
| Aug3-12, 03:00 PM | #7 |
One would never try to solve a problem in Newtonian mechanics by replacing all the particles by little tubes of fluid, and there is no reason to do it that way in general relativity.
Surely you would not try to find the deflection of light by considering a tube filled with an electromagnetic field. This is just making an easy problem difficult. It's preferable to just use notation that is a) simpler and b) makes physical sense. |
| Aug3-12, 03:15 PM | #8 |
In Stephani's book, he writes [itex]\dot{u}=u_{i;n}u^n=D\dot{u}/D\tau[/itex] (page 175). |
| Aug3-12, 03:31 PM | #9 |
| Aug3-12, 03:57 PM | #10 |
v·D = δ/δs is well defined, but D by itself is not -- the notation is misleading. More importantly, it's also misleading to think that general relativity deals only with continuous matter, and that any problem which is discrete must be represented by a delta function. These are test particles we're talking about. They're not made of anything smaller, they just trace out the geometry.
Perhaps the reason you think δ/δs is "another" derivative that's "superficially similar" is that you're less familiar with it. In fact it's more basic than the covariant derivative, and should be introduced first. One should use the tool that's appropriate to the problem at hand, and δ/δs is what's appropriate for any situation where test particles are involved. In addition to geodesic motion this includes such things as parallel transport, Fermi-Walker transport, geodesic deviation, etc. It would be quite cumbersome to do these in terms of continuous matter distributions. |
| Aug3-12, 04:05 PM | #11 |
Bill, I think your distinction is superfluous in the case the covariant derivative is the Levi-Civita connection of a certain metric, then the geodesics for the connection are precise
ly the geodesics of the metric that are parametrised by arc length(proper time). The geodesic equation equates the covariant derivative of the metric tensor field to the d/ds derivative along a curve. Your distinction is valid in the general case though. |
| Aug3-12, 04:07 PM | #12 |
I don't think I agree with the notion that [itex]D[/itex] by itself can't be defined. This is like saying, given [itex]a \cdot \nabla[/itex], the directional derivative in flat space, you can't define [itex]\nabla[/itex] by itself. We know that's not true; you just do [itex]e^i e_i \cdot \nabla = \nabla[/itex] and you're done. The same can be done with [itex]D[/itex].
The notion for [itex]D[/itex] comes from basic ideas about coordinate transformations and rotations. How does the absolute derivative operator come about in a more fundamental way? |
| Aug3-12, 07:13 PM | #13 |
Ok, I'll say it again, Muphrid, but this is the last time. D can only be applied to a field, a function of four variables φ(x, y, z, t). It cannot be applied to a function which is defined only along a curve, such as vμ(τ), and that is what we're dealing with. If you still don't see the distinction, sorry. But here's an example, the 4-velocity for a particle in a circular orbit:
vμ = (γa cos ωτ, γa sin ωτ, 0, γa) If you really think that Dvμ has meaning, please calculate it for this curve. |
| Aug3-12, 09:04 PM | #14 |
I didn't mean to imply that [itex]D[/itex] by itself makes sense in this particular situation; I realize now that was what you must've meant, so my apologies in that regard.
| Aug3-12, 09:33 PM | #15 |
| Aug4-12, 06:33 AM | #16 |
I understood the OP to be in the context of GR and the geodesic equation that he wanted to relate proper acceleration(a 3-vector, not a 4-acceleration) to the Christoffel symbols.
In that context with vanishing proper acceleration, that is geodesic motion, ((v.D)v=0 in Muphrid notation) one can use indistinctly the covariant derivative of the metric field and the absolute derivative along the geodesic curve. In other circumstances like calculating any other non-vanishing 4-acceleration this is not the case of course, but I (and i guess Muphrid and Mentz) interpreted the OP to refer to the one situation where this can be done so he could relate easily " the connection between a particle's proper acceleration and the christoffel symbol" and since this is the relativity forum in the context of GR, and the EFE are anyway only exactly solvable for test particles in vacuum. It is actually useful to take into account also that this doesn't hold in the general case, so Bill's point is pertinent. |
| Aug4-12, 07:13 AM | #17 |
Mentor
I would recommend chapter 3 of Carroll's lecture notes:
http://arxiv.org/abs/gr-qc/9712019/ |
| New Reply |
| Thread Tools | |
Similar Threads for: Proper Acceleration and Christoffel Symbols
| Thread | Forum | Replies | ||
| Can someone please explain to me what the Christoffel symbols symbols are? | Special & General Relativity | 4 | ||
| Christoffel symbols | Differential Geometry | 5 | ||
| Christoffel symbols | Special & General Relativity | 5 | ||
| Christoffel Symbols | Advanced Physics Homework | 12 | ||
| Christoffel Symbols | Advanced Physics Homework | 5 | ||
