Solution of damped oscillation D.E.
The discussion focuses on solving the damped oscillation differential equation represented as d²x/dt² + 2Kdx/dt + ω₀²x(t) = 0. The solution is assumed to be of the form x = f(t)e^(-kt), which is a common approach in differential equations due to the expected exponential decay from resistive forces. The substitution leads to a standard simple harmonic motion (SHM) equation with angular frequency ω defined by ω² = ω₀² - k², applicable when ω > k. The discussion also suggests an alternative substitution x = Ae^(-kt)sin(ωt + ε) for a more straightforward solution, and mentions the use of complex numbers for advanced methods.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with concepts of simple harmonic motion (SHM) and angular frequency.
  • Knowledge of exponential functions and their role in modeling decay processes.
  • Basic grasp of complex numbers and linear combinations in mathematical solutions.
  • Study the derivation of solutions for second-order linear differential equations.
  • Learn about the characteristics of simple harmonic motion and its mathematical representation.
  • Explore the application of complex numbers in solving differential equations.
  • Investigate the physical interpretation of damping in oscillatory systems.
Students and professionals in physics and engineering, particularly those focused on dynamics, control systems, and mathematical modeling of oscillatory systems.
uday1236
d2x + 2Kdx + w0 2 x(t) = 0
dt dt
while solving this we assume the solution to be of form x = f(t)e-kt
why is this exponential taken?
Because the solution to the equation is known to be of this form! You are, if you like, assuming the form of the answer in advance! This is quite a common procedure in 'solving' differential equations.
If your physical intuition is good, you could identify the [itex]2k\frac{dx}{dt}[/itex] term as due to a resistive force, and guess that there'd be an exponential decay factor in the solution.
Once you've made the substitution [itex]x = e^{-kt} f(t)[/itex], you have a differential equation for [itex]f(t)[/itex], which is just the ordinary shm equation with angular frequency [itex]\omega[/itex] given by [itex]\omega^2 = \omega_0^2 - k^2[/itex], provided that [itex]\omega > k[/itex]. So the solution can be seen immediately, by elementary methods, to be the product of sinusoidally oscillating, and exponential damping, factors. [If [itex]\omega < k[/itex] we have a non-oscillatory fall-off in x with time.]
Making the substitution [itex]x = e^{-kt} f(t)[/itex] involves a bit of drudgery and, imo, one might as well go the whole hog and (if [itex]\omega > k[/itex]) make the substitution [itex]x=Ae^{-kt}sin ({\omega t + \epsilon})[/itex] at the outset. You'll find that this expression does fit, provided that [itex]\omega^2 = \omega_0^2 - k^2[/itex].
If you're happy with complex numbers, and the idea of linear combinations, there is a very slick method which simply requires you to substitute [itex]x=Ae^{-\alpha t}[/itex]. Alpha turns out to be complex if [itex]\omega > k[/itex], and you need to form a linear combinations of two solutions. The mathematics is a bit more advanced than that needed for the substitution [itex]x = e^{-kt} f(t)[/itex] or [itex]x=Ae^{-kt}sin ({\omega t + \epsilon})[/itex].
In previous post [itex]\omega > k[/itex] should read [itex]\omega_0 > k[/itex], and [itex]\omega < k[/itex] should read [itex]\omega_0 < k[/itex]. Sorry.
  • · Replies 17 ·
  • · Replies 131 ·
9K
  • · Replies 17 ·
