New Reply
PCSPIM - declaring an array of strings
Share Thread Thread Tools
Aug6-12, 10:35 PM   #1
Hey all,
So declaring integers successively in memory (using .word) in an array is all well and understandable. Since an integer is 4 bytes in length, as is a memory word.
For example:
.data
x: .word 2, -13, 24, 123 #initialization of elements 0 to 3 of array x
However, how would I go about declaring an array of strings that are three characters long in memory???
would i use:
.data
stringArray: .asciiz "the", "dog", "run"
or perhaps:
.data
stringArray: .word 't''h''e', 'd''o''g', 'r''u''n'
thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Aug8-12, 06:39 AM   #2
Hey magneto202 and welcome to the forums.
In terms of what the computer understands, and given that this is in an assembler context (correct me if I'm wrong), then the only thing that matters is the value of the data being correct and not how its represented.
If you know that the data is represented in a format (like say 8-bit ASCII) and you know the string and character representations work then I can't see why you wouldn't use this.
The important thing is that the definition and its representation in memory are the same.
Also you need to consider the functions that use the data (which I'm assuming are probably some kind of interrupt), but again I'm going to speculate and say that the data definitions will create the right kind of representations.
Alternatively if you need a specific representation, you can never go wrong with specifying a block by block representation in a per byte, or per word description of contiguous data, but the point of having multiple specifications is that the assembler does this for you anyway.
Bottom line: it doesn't matter as long the final representation in memory is right (and you can specify the same thing in many different ways).
Aug11-12, 02:20 AM   #3
Excellent. have remained with the declaration of:
Nstart: .asciiz "the","dog","run"
and has worked successfully for my simulation implementation. The string array addressing in memory is consistent when I try access byte by byte.
Thanks chiro for the input.
New Reply
Tags
memory, mips, pcspim, spim, strings
Thread Tools
Similar Threads for: PCSPIM - declaring an array of strings
Thread Forum Replies
[C++] Declaring an array within a loop Programming & Comp Sci 2
Programming C The Hangman Game - Array/Strings Help Engineering, Comp Sci, & Technology Homework 4
Declaring an array in a for loop (Java) or similar Engineering, Comp Sci, & Technology Homework 8
Inputting an array in to a function or returning an array? (C++) Programming & Comp Sci 5
converting from an array of function values to coordinate array of different length Programming & Comp Sci 3
