| New Reply |
Temperature range at which a reaction is spontaneous, Where is the mistake? |
Share Thread | Thread Tools |
| Aug12-12, 01:59 PM | #1 |
For a chemical reaction we have, ΔH=-114.1kJ and ΔS=-146.4J/K ---> ΔS=-146.4·10[itex]^{-3}[/itex]kJ/K.
Question: Determine the temperature range at which the reaction is spontaneous. A reaction is spontaneous when ΔG is negative in the equation ΔG=ΔH-TΔS, so I do: ΔG=ΔH-TΔS 0>ΔH-TΔS -ΔH>-TΔS [itex]\frac{-ΔH}{-ΔS}[/itex]<T (the inequality sign changes direction when we multiply or divide both sides by a negative number right?) [itex]\frac{ΔH}{ΔS}[/itex]<T (signs cancel each other) [itex]\frac{-114.1kJ}{-146.4·10^-3kJ/K}[/itex]<T (we input the values) 780K<T , so this tells us that the T must be greater than 780K in order for the reaction to be spontaneous, but then when I check my answer in the original equation: ΔG=ΔH-TΔS ΔG=-114.1kJ-(900K)(-146.4·10[itex]^{-3}[/itex]kJ/K) ---> ΔG=18kJ , My inequality answer I suppose is wrong because if T is greater than 780K (in this example I used 900K) then ΔG is positive and the reaction is non spontaneous. ΔG=-114.1kJ-(200K)(-146.4·10[itex]^{-3}[/itex]kJ/K) ---> ΔG=-85kJ , In here if we use a T lower than 780K the reaction is spontaneous. I know I made a mistake somewhere because these results are not in accordance with each other, I'm guessing I made the mistake in the inequality while solving for T but I'm honestly not seeing it!, Where did I mess up?
| Aug12-12, 03:52 PM | #2 |
I prefer to stay away from negative signs when possible.
TΔS>ΔH ΔS is a negative value, correct? So to quote you, "(the inequality sign changes direction when we multiply or divide both sides by a negative number right?)" what does that do to your inequality when you divide the negative ΔS back over? |
| Aug12-12, 04:32 PM | #3 |
Hey thanks for your reply, I just finished posting something about inequalities in the General Math section, it would be great if you could check it out:
http://www.physicsforums.com/showthread.php?t=627753 maybe by doing what I describe in there the problems brought about by the minus sign and the change of direction of the inequality sign can be avoided? |
| Aug12-12, 04:43 PM | #4 |
-ΔH>-TΔS
plug values (-1)(-114.1kJ)> (-1)T(-146.4·10^−3kJ/K) multiply. do you have any negative values in your inequality? |
| Aug12-12, 04:54 PM | #5 |
| Aug12-12, 05:11 PM | #6 |
Since you have 2 negative numbers being multiplied on either side, they become positive. Now you don't have have negative numbers anymore, so you don't need to flip the inequality sign when you divide. |
| New Reply |
| Thread Tools | |
Similar Threads for: Temperature range at which a reaction is spontaneous, Where is the mistake?
| Thread | Forum | Replies | ||
| Semiconductor temperature range | Electrical Engineering | 7 | ||
| Non-spontaneous reaction and Gibbs Free Energy | Biology, Chemistry & Other Homework | 2 | ||
| temperature range in a body of liquid | General Physics | 0 | ||
| spontaneous endothermic nuclear reaction? | High Energy, Nuclear, Particle Physics | 9 | ||
| If a reaction is not spontaneous is there any of making that reaction occur? | Chemistry | 6 | ||
