Trying to Understand Light in Motion: A Frustrating Puzzle
  • Context: Undergrad
  • Thread starter Thread starter PhysicsLaura
    Light Motion Puzzle
The discussion revolves around the behavior of light in a moving train scenario, particularly focusing on how light from two flashes reaches a passenger on the train. Participants explore the implications of relativity, synchronization of events, and the mathematical framework involved in analyzing the situation. The scope includes theoretical reasoning and conceptual clarification.
  • One participant expresses confusion about how light from two flashes can reach a passenger on a moving train at the same time, suggesting a need for equations to clarify the situation.
  • Another participant describes a setup involving sensors and a light source, detailing the four-velocity and the calculations needed to determine when light reaches each sensor, indicating that synchronization affects the results.
  • A participant requests clarification on the terms gamma and beta used in the context of four-velocity, indicating a need for visual aids to understand the concepts better.
  • One participant provides a simplified table to illustrate the positions of the train and light over time, suggesting that light reaches the front of the train at a specific time based on their calculations.
  • Another participant emphasizes that the scenario involves two different frames of reference, arguing that the timing of light reaching the passenger depends on whether the flashes are emitted simultaneously in the passenger's or the ground's rest frame.
  • A participant asserts that light must hit the passenger at the same time in all directions, referencing the constancy of the speed of light and suggesting that length contraction may play a role in the scenario.
  • One participant introduces the concept of light cone diagrams to illustrate the relationship between events in different frames, indicating that the angles of the coordinates change in moving frames.
  • There is a disagreement regarding the interpretation of simultaneity in the context of relativity, with some participants arguing that the light from both flashes cannot reach the passenger at the same time under certain conditions.
Participants do not reach a consensus on whether the light from both flashes can hit the passenger at the same time, as there are competing views based on different frames of reference and interpretations of simultaneity in relativity.
The discussion highlights the complexity of synchronizing events in different reference frames and the mathematical intricacies involved in analyzing the motion of light relative to moving observers. Some assumptions about synchronization and the nature of light propagation remain unresolved.
  • #151
solarflare said:
if the passenger on the train was equidistant from the flashes when they occurred in the platform frame - then by the time the flashes moved from the source to her eyes she will have moved towards one and away from the other. so she will see two flashes but not simultaneously.
OK, so now you agree that data point 6 above (post 127) is correct?
  • #152
The lightning strikes are events that happen. They occur in all frames!
yes they are events that happen in all frames - but they happen at different times in each frame.
when you look at the stars you are seeing light that was emitted millions of years ago - not at the point when you see it.
the light strikes the train - therefore that is the starting point
the platform observer sees the light after it has traveled from the train to his eyes
the strikes do not originate in his frame
  • #153
cepheid said:
I made this spacetime diagram a while ago, and I *think* it corresponds to the original scenario that is being discussed here. Maybe it will help. The "worldline" of the train (which is its path through spacetime) is clearly indicated, and it of course coincides with the t' axis:
The worldline of the photon that is coming in from the front (i.e. from the positive side) clearly intercepts the worldline of the train before (i.e. at a smaller value of t') the worldline of photon that is coming in from the rear (negative side) does.
The coordinate grid I've drawn is for the train observer, in the primed (t',x') coordinate system.
this graph shows that at t=0 there are two strikes - indicating that the strikes wer simultaneous.
the two strikes actually happen on the train
follow the lines to the observer and he sees the flashes simultaneously also - after a set amount of time has passed.
now take this graph and make the strikes hit the platform - the platform is the platforms guys frame so that is where they originate -
he sees the light simultaneously but the train observer sees them separately.
the video has put the lightning striking in the wrong place - it should strike the platform not the train
  • #154
Sure, but for simplicity let's set r1 to some small value, say 1 cm. Then it is reasonable to neglect it and also to consider the lightning strikes to have marked both the train and the platform.
you want to neglect a key factor
and to say that the strikes mark both the train and the platform means that they must happen simultaneously also
  • #155
It's certainly true that the lightning must occur before anyone can see it, no matter what their frame. But that's a triviality. (No need for relativity to understand that!)
There are several distinct events that are of interest in this scenario:
(1) Lightning strikes the front of the train (and the section of platform under the front of the train at that moment)
(2) Lightning strikes the rear of the train (and the section of platform under the rear of the train at that moment)
(3) Light flash from the front of the train reaches the platform observer
(4) Light flash from the rear of the train reaches the platform observer
(5) Light flash from the front of the train reaches the train passenger
(6) Light flash from the rear of the train reaches the train passenger
Discuss the scenario in terms of these events (which occur in all frames, of course) and you will be less likely to stumble.
To start you off, here are the facts:
Events 1 & 2 occur at the same time in the platform frame. (This is given in the setup.)
Events 3 & 4 occur at the same time in every frame.
Events 5 & 6 occur at different times in every frame.
What's interesting is what these facts tell us about the times of events 1 & 2 in the train frame. That's where the relativity of simultaneity comes in.
  • #156
why put r1 = r2 in the video if if its of importance?
  • #157
if they happen at the same time in the platform guys frame then the guy that made the video needs to put the strikes happening before they reach the centre of the platform.
and r1 can not = r2
  • #158
If I recall from the video correctly, r1 and r2 are the distances from the lightning strikes to the platform observer according to the platform observer. It's kind of silly to think of them as being 1 cm. Is the train that tiny?
You'll have a much easier time of it if you think of the train as being miles long.
Think of the lightning bolts as being huge sparks that hit the ends of the train and the platform (wherever the ends of the train happens to be at that moment) at the same time.
  • #159
It does not matter whether the strikes actually hit the train or the platform, solarflare. This is why someone else was saying consider the simplest case, which is when the strikes actually hit both in one event. All that matters are the x-coordinates of the strikes.
No, it doesn't mean simultaneity in the train's frame. Why do you think it does?
The strikes are events; they do not belong in any frame. You can just as easily talk about two moving, omni-directional sources of light. These sources do not have to move the same as the train--or even as the platform! All that matters is that the platform observer perceives both of them to have been equidistant from him when he receives each source's light pulse.
the strikes happen in one frame first - the trains frame
they then occur in the platform guys frame only after the light has traveled from the trains frame to the platform frame.
See above; the strikes are events that do not belong to any specific frame. They may have coordinates according to frames, but the strikes themselves (not just when the flashes from those strikes reach observers) have the same time coordinates in the platform frame, yet the forward strike has a different, earlier time coordinate from the rear strike.
  • #160
It is not a key factor.
What is r2? You defined r1 as the distance between the train tracks and the platform, but you never defined r2. According to your definition of r1, it is not important and can be made as small as we like.
I don't recall the video ever discussing the distance between the tracks and the platform, but again, no mistakes in the video eliminate the errors that YOU are making.
  • #161
finally Doc al agrees with somthing i said :-)
it wasnt me that said to think of the distance as really tiny.
  • #162
if you do not know what r2 is - then you obv have not watched the video - r2 is defined in the video as being = to r1
  • #163
the train is on the tracks - not the platform - r1 is the distance from the rear strike to the platform guy - r2 is the distance from the front strike to the platform guy
  • #164
Now that you've clarified what you think these distances are, I agree. You gave the impression you thought that r1 was the distance from the platform observer to the track, which is why I said "there is no r1". This problem is almost always done in only 1 dimension for clarity.
  • #165
OK, then this statement of yours is not correct:
solarflare said:
the train is on tracks that are a distance from the platform r1
The distance from the tracks to the platform is not the same as the distance from the rear strike to the platform guy.
For clarity, from now on, let's call the distance from the tracks to the platform d. That distance, d, can be made as small as desired and can be neglected. Also, for clarity, it would help if you would use the quote feature to identify things that you are quoting.
Do you now agree with all of the data presented in post 127?
  • #166
The graph indicates that the strikes both occur at t = 0, meaning that they were both simultaneous in the platform frame. The graph also clearly shows that the two strikes DON'T occur at the same value of t'. One occurs at t' < 0, and the other one at t' > 0, as I explained extensively in my accompanying explanation, and in the second version of the diagram that I posted later. Did you actually read any of that, or are you just interested in using the diagram to perpetuate your own false assertions?
In the scenario I envisioned, the strikes occur along the rails at x = ±4, x being position values in the platform frame, with the platform observer at x = 0. Whether the train is long enough that these strikes actually hit the front and rear of it, or whether they occur on the rails just ahead of the train and just behind it, is irrelevant.
If you're referring to the platform observer, then sure, I agree. If you're referring to the train observer, then no. The diagram clearly shows that the strikes reach the train observer at different times, because they strike at different times.
Neither of the statements in bold make any sense whatsoever. It makes no difference whether the strikes hit the train in particular, or the platform ahead of the train and behind it. ANY scenario in which the lightning strikes at points equidistant from the platform observer, and in which the positions of the platform observer and train observer coincide at the origin at t = t' = 0, will result in the spacetime diagram I drew, which shows that the strikes occur simultaneously for the platform observer, and not for the train observer.
I also don't understand what you mean about the strikes "originating" in a particular frame. I'm not sure what you think an inertial reference frame is, but it is just a coordinate system that is rigidly attached to some unaccelerated body. You can conceptualize it as a rigid latticework of rods and clocks used for making physical measurements of distance and time. One such coordinate system (with the unprimed coordinates) is rigidly attached to the track or platform, and the other one (with the primed coordinates) is rigidly attached to the train. It's not like as if they are two alternate realities or something, so it's not possible to assert that something can "happen" in one frame and not in another. As Doc Al has repeatedly tried to convince you, the strikes are events that must occur in both frames. An event is something that occurs at a definite spacetime location. In the platform frame, it would have definite spacetime coordinates (t,x,y,z). This event must also have definite spacetime coordinates (t',x',y',z') in the train frame. What special relativity says is that these sets of coordinates are, in general, different from each other for two inertial frames that are in relative motion. I.e. the events can occur at different places and at different times as measured in the two frames. The two sets of coordinates are related to each other by a Lorentz transformation.
  • #167
if the lightning strikes the train - then it will mean that the train is considered stationary and the platform is moving
  • #168
Why in the world do you think that?
Viewed from the platform, the train is always moving; viewed from the train, the platform is moving. Nothing to do with the lightning striking the train or not.
  • #169
Nonsense. Lightning can strike moving objects.
Consider the lightning strikes to leave a char mark such that the size of the mark is greater than d. Then one strike can leave a mark on both the platform and the train.
  • #170
Here is the transcript for the first minute of the video devoted exclusively to the platform frame:
Imagine two observers, one seated in the center of a speeding train car, and another standing on the platform as the train races by. As the center of the car passes the observer on the platform, he sees two bolts of lightning strike the car - one on the front, and one on the rear. The flashes of light from each strike reach him at the same time, so he concludes that the bolts were simultaneous, since he knows that the light from both strikes traveled the same distance at the same speed, the speed of light. He also predicts that his friend on the train will notice the front strike before the rear strike, because from her perspective on the platform the train is moving to meet the flash from the front, and moving away from the flash from the rear.
This states in no uncertain terms that when the center of the car (where the passenger is) passes the platform observer, the flashes of light from the strikes reach him at the same time. Therefore, they also reach the passenger at the same time (as long as there is no distance between them which is the only way you can meaningfully interpret this statement apart from seeing the video).
And what does the video show?
At 20 seconds into the video are these three images captured in rapid succession:
  • #171
posts 164 and 165
1 agrees with me and the other doesnt
  • #172
Then the video goes back and repeats the sequence of the platform observer seeing the lightning flashes by panning up above him (unfortunately, I can only put three videos on a single post so this will be scattered among several posts):
  • #173
Notice how in the first image here, they depict the progress of the two flashes of light hitting the window in which the observer is (although they don't show her, it's the second window from the front of the train car-the second window from the right). They hit simultaneously. Then in the next image, the two flashes hit the platform observer:
  • #174
solarflare said:
posts 164 and 165
They are both pointing out that you made a mistake in calling the distance between the track and the platform "r1". Do you understand that r1 is not the same as the distance between the track and the platform, which I suggest we call "d"?
  • #175
Here's where they show that the platform observer is equidistant from the two lightning strikes that hit the moving train car (at an earlier time but they have not shown this):
  • #176
Imagine two observers, one seated in the center of a speeding train car, and another standing on the platform as the train races by. As the center of the car passes the observer on the platform, he sees two bolts of lightning strike the car - one on the front, and one on the rear. The flashes of light from each strike reach him at the same time, so he concludes that the bolts were simultaneous, since he knows that the light from both strikes traveled the same distance at the same speed, the speed of light. He also predicts that his friend on the train will notice the front strike before the rear strike, because from her perspective on the platform the train is moving to meet the flash from the front, and moving away from the flash from the rear.​
I agree, sloppy use of the term 'see' in the second sentence. And sloppy illustration of the light flash reaching the platform observer while the train just sits there.
  • #177
Now here's where they repeat the sequence again but this time it is an animation and it shows something different than what they showed earlier. And note the platform observer is not present so we can't tell exactly when he is supposed to see the flashes of light. This is further complicated by the fact that they are panning the image from left to right so the perspective is changing making it impossible to know where the platform observer is. The last image is where they "light up" the passenger to show that she sees the front flash first:
  • #178
And now with further panning, they show the rear flash arriving at the train passenger in the last of these images but note the lightning strikes have disappeared:
  • #179
Why don't we scrap the video and just discuss the scenario that the video was trying (badly) to illustrate, which is what we've actually been discussing for the most part. It's the standard Einstein train thought experiment, of course.
A train passes by a person on the platform. At the instant the center of the train passes the person, lightning strikes both ends of the train according to the platform frame. (These are the two events that I label #1 and #2 in post 155.)
Solarflare, given this setup, can you comment on my statements in post #155?
  • #180
how can you say scrap the video when my whole point is that the video is wrong ?
  • · Replies 34 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 84 ·
  • · Replies 25 ·
