Diffusion model using gas pressure decay
The discussion focuses on modeling gas diffusion in a liquid using a cylinder experiment filled with helium at 100 bars pressure. Key questions include calculating helium solubility at high pressure using Henry's Law, determining the theoretical amount of helium in the liquid over time based on diffusion rates, and modeling the diffusion gradient across the liquid. The Henry's law constant for helium is crucial for these calculations, and the diffusion problem parallels transient conduction heat transfer principles.
  • Understanding of Henry's Law and its application to gas solubility
  • Knowledge of diffusion rates and their significance in liquid-gas interactions
  • Familiarity with transient conduction heat transfer concepts
  • Basic principles of gas laws and pressure measurements
  • Research how to calculate Henry's law constant for various liquids
  • Learn about diffusion modeling techniques in liquid systems
  • Explore transient conduction heat transfer equations and their applications
  • Investigate experimental methods for measuring gas solubility under varying pressures
Researchers in physical chemistry, experimental physicists, and engineers designing gas-liquid interaction experiments will benefit from this discussion.
QforK
Hi,
This isn't a homework problem - this is to help with the design of an experiment. I know the questions below are probably fairly simple physics questions, but I've got lost in laws and units! Please help me out.
The experiment
A cylinder 20cm long and 2cm wide is filled with 6cm of liquid so that there is 14cm for gas available above the liquid. From the top, the cylinder is filled with helium until the gas pressure is 100 bars. Then the cylinder is sealed. The pressure in the cylinder drops with time, which in a closed system is assumed to result from diffusion of the gas into the liquid.
So...
The problem
1) If I know the solubility of helium in the liquid at atmospheric pressure, how can I arrive at the solubility at high pressure? If it's using henry's law (as far as I've got) then how do I get the henry's constant for a liquid?
2) If I know D, the diffusion rate, of helium in this liquid, how can I calculate the theoretical amount of helium (mol) in the liquid with time?
3) How can I arrive at a modeled diffusion gradient across the 6cm of liquid at the end of the experiment? Let's say the experiment lasts 12 hours.
Thanks so much for your help,
QforK
The Henry's law constant for most gases is available in the literature. The concentration in the liquid at the interface is equal to the pressure in the gas times the Henry's law constant. Below the interface, you have a transient diffusion problem analogous mathematically to the transient conduction heat transfer problem for a bar.
14K
  • · Replies 109 ·
10K
  • · Replies 69 ·
